HTC_One M8 MID change Does anybody have a fast and smooth solution how to change Model ID on M8, At the moment im running Europe MID, but would like to change it into AT&T So I could get rid of the demo and perform system update in the system. Please help |
Hello, With XTC 2 Clip connected to the phone, boot to fastboot (VOL_DOWN+PWR), run XTC 2 Tool, open "Direct mode commands" and press " Write MEID". That's all! |
I want it to change into this MEID 0P6B12000 but it gave me an error, saying it must be 14-digits long. Sorry if i don't know the basics yet, im a beginner. |
follows the tutorial on XDA, not so hard, only by entering some adb commands |
[how to] change your MID without an eng boot… | HTC One (M8) I tried the AT&T option, and it gave me an error stating that dd is not recognized as a command or smth. Would be much more easier if i could do it with xtc2clip. |
It's not a good idea to follow some xda threads, while you already have a handy tool like XTC 2 Tool. |
I tried it with direct mode already, had an error:Error: MEID must be 14 digits |
As to MID - don't do this. You can do it in fastboot mode by using 'oem writemid XXXXXXXX", but I do NOT recommend you to do this. Firmwares are NOT interchangeable, so, for example, M8_UL cannot be properly flashed to M8_WHL, etc. |
So the only solution to get rid of demo, is to still use supercid and unlocked/developer ruu? There is only android 5.0.2 version out there of unlocked version. But i need 6.0 , so the system would say"there are no updates" instead of "software is modified" |
I also tried this command 'oem writemid XXXXXXXX" because i have nothing to lose, but it still gave me an error :( |
No, i don't have 6.0 ruu.exe |
I just need a solution to change model id into at&t , so when i give the phone at&t cid, it will update itself in the system. I don't know if 6.0 is out as a ruu. But i know that m8-s will get 6.0 |
