05-14-2016, 15:47 | #5 (permalink) | |
No Life Poster Join Date: Feb 2007 Location: Armenia
Member: 448264 Status: Offline Thanks Meter: 78 | Quote:
What is wrong i do???? | |
05-16-2016, 13:27 | #6 (permalink) | |
No Life Poster Join Date: Jun 2015
Member: 2416253 Status: Offline Thanks Meter: 4,162 | Quote:
You should not see the FTM mode. 2 possible problems: 1. Clip is not correctly attached. Solution - boot to download mode first and make sure you don't get the "SD NOT MOUNTED/CONNECTED" message. 2. Do filesystem repair (http://forum.gsmhosting.com/vbb/f961...t-etc-1964648/) and then do copy files again. 2. File system is damaged | |
The Following User Says Thank You to xtc2clip For This Useful Post: |
05-17-2016, 07:38 | #7 (permalink) | |
05-17-2016, 13:15 | #8 (permalink) | |
You should NOT see FTM, and you should NOT use "Simlock" in FTM. Since the clip is attached and recognized, it means that files are not copied in "Special unlock / IMEI" tab. | |
05-18-2016, 07:35 | #10 (permalink) |
Member: 448264 Status: Offline Thanks Meter: 78 | your clip can't unlock HTC M9 T-Moblie locked already no need your help i convert T-Mobile to AT&T(change cid to BS_US001 mid 0PJA11000 and flash 0PJAIMG_HIMA_UL_M60_SENSE70_ATT_MR_NA_Gen_Unlock_3 .35.617.12_Radio_01.01_U11440792_97.00.51203G_F_re lease_464227_signed_2_4) then phone ask me enter unlock code .I buy unlock code by imei and type on phone.Pone Unlocked |
05-18-2016, 10:24 | #11 (permalink) | |
It can unlock both T-Mobile and AT&T M9 and there was no need to spend money for codes. Anyway it's up to you and thanks for reporting your results. | |
05-20-2016, 08:54 | #12 (permalink) | |
which step i do wrong? | |
05-23-2016, 03:06 | #14 (permalink) |
Crazy Poster Join Date: May 2007
Member: 504430 Status: Offline Thanks Meter: 14 | @juve2106 The clip can definitely sim unlock the HTC m9 T-mobile phone. I have done many many of these phones. You do this through the FTM mode but you should not see the FTM menu if you correctly copied the files to the XTC 2 Clip. Also you asked, "if files not copied how i do S-OFF ?? Reset FRP?? Change imei? change cid???" For the HTC M9 you can do all of those things without copying the special files to the clip. To sim unlock you will need to copy the special M9 specific files to the clip. Its really easy. Read the instructions, if you still don't understand then let me know I can write up a step by step guide. Hope this helps Gene |
The Following User Says Thank You to gszeto99 For This Useful Post: |
05-31-2016, 15:11 | #15 (permalink) | |
Freak Poster Join Date: Aug 2003 Location: Abidjan
Member: 38050 Status: Offline Thanks Meter: 61 | Quote:
I was in same situation like juve2106 ,but after do filesystem repair HTC M9 tmobile unlock succes. | |
The Following User Says Thank You to dan0007 For This Useful Post: |
