01-16-2019, 12:43 | #19 (permalink) | |
No Life Poster Join Date: Jun 2015
Member: 2416253 Status: Offline Thanks Meter: 4,162 | Quote:
This phone doesn't respond to bl unlock command for some reason. Let me check something and I'll get back to you. | |
01-16-2019, 12:54 | #20 (permalink) | |
Please reboot to download mode and issue this command in terminal: oem get_identifier_token and paste the result | |
01-16-2019, 13:02 | #22 (permalink) |
No Life Poster Join Date: Oct 2006
Member: 380870 Status: Offline Thanks Meter: 159 | thi is terminal command oem get_identifier_token Enjoy *** Command started *** ... (bootloader) [KillSwitch] : /dev/block/bootdevice/by-name/frp (bootloader) [KillSwitch] Last Byte is 0X00, disable unlock (bootloader) [KillSwitch] oem unlock Turn Off! OKAY finished. total time: 0.023s htc_fastboot finished *** Command finished *** |
01-16-2019, 13:28 | #23 (permalink) | |
You can't flash recovery separately because of locked bootloader. You can't flash other fw because of the CID. You can't downgrade. You can't boot to OS and enable oem unlock. I will try to find a flash file for you, that's the only way I see at the moment. P.S. In the mean time you can download any other OCEAN_UHL O80 flash and try to flash it. | |
The Following User Says Thank You to xtc2clip For This Useful Post: |
02-02-2019, 17:38 | #26 (permalink) | |
OTA files are meant to be flashed from recovery only, they can't be flashed from download mode. I don't have any solution at the moment, sorry. | |
05-20-2021, 08:10 | #28 (permalink) |
No Life Poster Join Date: Oct 2011 Location: srilanka Age: 32
Member: 1674096 Status: Offline Thanks Meter: 49 | hello i have the same problem but i have higer version android 9.my mobile version is android so first need to flash partial flash after i can flash.but problem is i can't find partial flash for android 9 cid_801 htc u 11 au 2PZ OCEAN_UHL |
