05-26-2019, 00:50 | #1 (permalink) |
Junior Member Join Date: Mar 2008
Member: 728011 Status: Offline Thanks Meter: 1 | i want xtc team help me but not can do any opration all faild i have d630n i want to make s off but fail i want to remove fro but fail Sending oem writesecureflag 0 ... (bootloader) SecuritySDInit: counter = 2 (bootloader) a16dwg_init_sd, SD card already power on (bootloader) a16dwg_init_sd, SD card io already power on (bootloader) sdhci_open: id=0 (bootloader) Initializing MMC host data structure and clock! (bootloader) mmc slot#2 clock enabled (bootloader) sdhci_set_clock: slot 2, freq 192000000 (bootloader) GPLL0 is enabled (bootloader) clock_update_cfg_sd is done (bootloader) sd clock set done (bootloader) sdhci_set_bus_width: bus width 0 (bootloader) sdhci_clk_supply: freq 400000 (bootloader) Error: Command never completed (bootloader) Error: Command timeout error (bootloader) Error: Command completed with errors (bootloader) The response for CMD8 does not match the supplied value (bootloader) Decoded CID fields: (bootloader) Manufacturer ID: 7f (bootloader) OEM ID: 0x0 (bootloader) Product Name: 5270 (bootloader) Product revision: 5.2 (bootloader) Product serial number: B4E (bootloader) Manufacturing date: 2 2015 (bootloader) sdhci_clk_supply: freq 50000000 (bootloader) sdhci_set_bus_width: bus width 1 (bootloader) Done initialization of the card (bootloader) erase_grpsize: 0 (bootloader) erase_grpmult: 96 (bootloader) wp_grpsize: 1 (bootloader) wp_grpen: 1 (bootloader) perm_wp: 0 (bootloader) temp_wp: 0 (bootloader) Error: DATA time out error (bootloader) Error: Command completed with errors (bootloader) Failed Reading block @ 0 (bootloader) [SD_ERR] sd_read_sector: read sector failed (0 1) (bootloader) [Tuxera][Error] Failed to read MBR (bootloader) Error: DATA time out error (bootloader) Error: Command completed with errors (bootloader) Failed Reading block @ 0 (bootloader) [SD_ERR] sd_read_sector: read sector failed (0 1) (bootloader) [FAT_ERROR] fat_open_file: load bpb fail(-5) (bootloader) [JAVACARD_ERR] SMART_IO.CRD cann't find (bootloader) writesecureflag: Permission denied, value 1 OKAY finished. total time: 44.070s htc_fastboot finished Operation finished Phone DISconnected |
05-28-2019, 19:59 | #6 (permalink) |
No Life Poster Join Date: Jun 2015
Member: 2416253 Status: Offline Thanks Meter: 4,163 | According to the log - there is a problem in communication. If you did the filesystem repair and you sure that flex is OK, the last thing you can try is to open the clip and carefully resolder EEPROM chip. We had several reports when this operation helped. Sorry for troubles. |
