IMPORTANT: How to repair filesystem after format, etc Hello, IMPORTANT: Starting from XTC 2 Tool version 1.38 you no longer need to download win32diskimager and follow this guide! This option is built-in into XTC 2 Tool software@ NOTE: August 25, a new image has been uploaded. It will prevent Android from creating system files. Many customers are trying to format the clip with wrong fs, which leads to a corrupted file system. File system can also be corrupted by the wrong ejection from USB, etc. We have a procedure that you may use to restore your clip to factory state: 1) Download this application: Download Win32 Disk Imager from SourceForge.net 2) Download filesystem image: https://xtc2.net/downloads/image2017s.img (short version, faster flashing) https://xtc2.net/downloads/image2015.img (full version, in case short doesn't help) 3) Run Win32 Disk Imager 4) In the "Image file" select downloaded "image2015.img" 5) Connect XTC2Clip to the microSD reader. 6) Select the correct disk drive in the "Device" droplist. WARNING! Make a careful selection. If you choose a wrong drive, you can erase data on one of your disks. 7) Press "Write" and wait for the operation to complete. It may take 1-2 minutes. 8) Reconnect clip Done. Please recreate the files you need (e.g. sf.txt, etc) and you may start using the clip as usual. here the simple steps of animation video : http://www.smart-gsm.net/xtc2clip/Xt...ile_system.gif |
i tried to flash it it giving me error an error occurrd when attempting to write data to handle error 23 data error (cyclic redundancy check) |
I get this Error 1117: The request could not be performed because of an I/O device error |
after several attempts its solved now!!! thanks |
pleaseee set image file |
the img file is mising from support or support is down or file corupted unable to download image.img from link |
image.img |
thanks for the tutorial xtc2clip. it really helped a lot. |
Help me...!!! "An error ocurred when attempting to write data to handle. Error 2: El sistema no puede encontrar el archivo especificado". PC formatted. No applications. No antivirus. What do I do? NOTE: Please answer in spanish. |
