07-01-2015, 15:39 | #1 (permalink) |
No Life Poster Join Date: Jun 2015
Member: 2416253 Status: Offline Thanks Meter: 4,162 | IMPORTANT: How to repair filesystem after format, etc IMPORTANT: Starting from XTC 2 Tool version 1.38 you no longer need to download win32diskimager and follow this guide! This option is built-in into XTC 2 Tool software@ NOTE: August 25, a new image has been uploaded. It will prevent Android from creating system files. Many customers are trying to format the clip with wrong fs, which leads to a corrupted file system. File system can also be corrupted by the wrong ejection from USB, etc. We have a procedure that you may use to restore your clip to factory state: 1) Download this application: Download Win32 Disk Imager from SourceForge.net 2) Download filesystem image: https://xtc2.net/downloads/image2017s.img (short version, faster flashing) https://xtc2.net/downloads/image2015.img (full version, in case short doesn't help) 3) Run Win32 Disk Imager 4) In the "Image file" select downloaded "image2015.img" 5) Connect XTC2Clip to the microSD reader. 6) Select the correct disk drive in the "Device" droplist. WARNING! Make a careful selection. If you choose a wrong drive, you can erase data on one of your disks. 7) Press "Write" and wait for the operation to complete. It may take 1-2 minutes. 8) Reconnect clip Done. Please recreate the files you need (e.g. sf.txt, etc) and you may start using the clip as usual. here the simple steps of animation video : Last edited by xtc2clip; 04-17-2019 at 15:05. Reason: Updated links with secure connection |
The Following 36 Users Say Thank You to xtc2clip For This Useful Post: |
07-29-2015, 14:01 | #11 (permalink) | |
Member: 2416253 Status: Offline Thanks Meter: 4,162 | Quote:
image.img | |
The Following 5 Users Say Thank You to xtc2clip For This Useful Post: |
08-10-2015, 15:54 | #13 (permalink) | |
Freak Poster Join Date: Sep 2008 Location: INDIA
Member: 868990 Status: Offline Sonork: 100.1615913 Thanks Meter: 23 | Quote:
The Following 4 Users Say Thank You to ..RISHI.. For This Useful Post: |
09-30-2015, 06:05 | #15 (permalink) |
Junior Member Join Date: Sep 2015
Member: 2461053 Status: Offline Thanks Meter: 1 | Help me...!!! "An error ocurred when attempting to write data to handle. Error 2: El sistema no puede encontrar el archivo especificado". PC formatted. No applications. No antivirus. What do I do? NOTE: Please answer in spanish. |
The Following User Says Thank You to eze021188 For This Useful Post: |
