Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > xtc2cliP
Old 06-25-2017, 15:57   #76 (permalink)
Member: 2589530
Thanks Meter: 2
cannot unlock bootloader with poweradapter?
Starting bootloader unlock procedure
Phone detected, reading token...
Token detected successfully
Checking server connection...
Communicating with the XTC 2 Clip ...
ERROR: Clip communication error 10
Old 06-26-2017, 04:28   #77 (permalink)
Member: 179026
Sonork: 100.1667796
Thanks Meter: 15
I try D530 s-off
Sending oem writesecureflag 0
... (bootloader) HTC KEY CARD VERSION: 7
FAILPERMISSION DENY (GT_CONNECT_FAIL)
FAILED (remote: PERMISSION DENY (GT_CONNECT_FAIL))
Execution time is 1(s)
Operation finished
How fix it, or any step wrong?
Old 06-26-2017, 07:05   #78 (permalink)
Member: 179026
Sonork: 100.1667796
Thanks Meter: 15
I try two model D530 and U Ultra s-off use PowerAdapter.
But got error
Operation finished
What's problem?
Old 06-26-2017, 08:54   #79 (permalink)
Member: 1656411
Sonork: Scott Probert
Thanks Meter: 29
But got error
What's problem?
See post #73
Sent from my 2PYB2 using Tapatalk
Old 06-26-2017, 09:20   #80 (permalink)
Member: 2487890
Thanks Meter: 72
Originally Posted by xtc2clip View Post
XTC 2 PowerAdapter is an add-on for your XTC 2 Clip, it's not a standalone product.
Internet connection is required for operation.
Everything are ready, and how do i do "online operation" with this adapter?
If replace old smart card with adapter and do it as usual, you will only get this error.
And you can not get access to support site with the adapter inserted.
I've notice that adapter has a microusb connector, seems we need a new software to do operations, right?
The Following User Says Thank You to sabpprook For This Useful Post:
Old 06-26-2017, 09:29   #81 (permalink)
Member: 2487890
Thanks Meter: 72
Found something interesting...
It shows the UI, but the functions are not implemented yet..
Old 06-26-2017, 09:46   #82 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 12,343
Originally Posted by scotty85 View Post
Internet connection should not be required for offline mode.
The clip works the same with the power adapter as it did the original sim
You are Wrong, "Power Adapter" is one Add On and NOT work Standalone, Must requisite "INTERNET CONNECTION", for this goes Connected to Pc with XTC2CLIP.... and no one has thinked that also Y Cable Existe.
Old 06-26-2017, 09:57   #83 (permalink)
Member: 1656411
Thanks Meter: 29
you have no idea if im wrong or not. you are taking a comment and assuming its most literal meaning.
the clip currently needs an internet connection to work. but it still has an offline mode.
since the "power adapter" is nothing more than a new eng sim,stands to reason the clip can still be used in an offline mode. this is a reasonable assumption.
maybe the power adapter does need a constant connection via the micro sd port,we dont really know. as usual,support and information about this new product is vauge at best
Old 06-26-2017, 10:09   #84 (permalink)
allumts's Avatar
Member: 1564612
@scotty85, i'm tired of answer to you, so please Wait when "Product Manager" show you and other one Video or clear some Error...
Good lucky
Old 06-26-2017, 10:13   #85 (permalink)
Member: 2487890
Thanks Meter: 72
So, do you have the adapter and get work with "HTC KEY V7" phone???
Old 06-26-2017, 10:20   #86 (permalink)
Member: 1656411
Thanks Meter: 29
Good lucky
im tired of answer you too. you answer without any knowledge. do you have the power adapter? have you successfully used it to s off u ultra,play or 11??
wait for product manager is the best advice you have given so far.
Old 06-26-2017, 10:51   #87 (permalink)
Member: 2491182
Sonork: 90025891
I've got the PowerAdapte, but there is no response to the XTC 2 clip. Please follow the instructions. Thank you!
Old 06-26-2017, 12:02   #88 (permalink)
Member: 2545921
Thanks Meter: 7
This is how I read this
Please connect XTC 2 PowerAdapter to your PC (via micro USB cable AND), to XTC 2 CLIP (remove old smart card and insert power adapter) and connect phone in download mode Press WRITE SECURITY (S-OFF)
So Power adapter is inserted into XTC2clip and plug micro USB into the other end of power adapter (hence called power adapter????)
If you look at the power adapter "sim part" it has separate circuits as apposed to the smart card
Then use selection on program
LMK how you get on HTC u11 arrived today and Power Adapter on the way
The Following User Says Thank You to Deeblog For This Useful Post:
Old 06-26-2017, 12:21   #89 (permalink)
Member: 2545921
Thanks Meter: 7
In summary.....
PC > Micro usb cable > Power Adapter > Smartcard Slot on XTC2CLIP > Flex ribbon > SD Card Slot
Phone in download mode.
Old 06-26-2017, 20:34   #90 (permalink)
Member: 2527714
In summary.....
1-connect XTC 2 PowerAdapter to your PC, to XTC 2 Clip
2-connect your phone in download mode to the computer.
3-Then select desired operation and perform it.
Page generated in 0.24911 seconds with 8 queries
