[javacard_err] Hi sir my clip have problem for s-off and super cid m8 and 826h and m9 [Tuxera][Error] No exFAT partition found (bootloader) [JAVACARD_ERR] verify javacard: get signature fail, SW= i repair clip with win32disk but upgrad with xtc2client1.4 not actived. i change flex cable . but problem not solve. Sending oem writesecureflag 0 ... (bootloader) SecuritySDInit: counter = 8 (bootloader) m8_init_sd, SD card already power on (bootloader) [SPEW] GPIO 0 status is 0 (bootloader) sdhci_open: id=0 (bootloader) Initializing MMC host data structure and clock! (bootloader) mmc slot#2 clock enabled (bootloader) sdhci_set_clock: slot 2, freq 192000000 (bootloader) GPLL0 is enabled (bootloader) clock_update_cfg_sd is done (bootloader) sd clock set done (bootloader) sdhci_set_bus_width: bus width 0 (bootloader) sdhci_clk_supply: freq 400000 (bootloader) Error: Command never completed (bootloader) Error: Command timeout error (bootloader) Error: Command completed with errors (bootloader) The response for CMD8 does not match the supplied value (bootloader) Decoded CID fields: (bootloader) Manufacturer ID: 7f (bootloader) OEM ID: 0x0 (bootloader) Product Name: 5270 (bootloader) Product revision: 5.2 (bootloader) Product serial number: B4E (bootloader) Manufacturing date: 2 2015 (bootloader) sdhci_clk_supply: freq 50000000 (bootloader) sdhci_set_bus_width: bus width 1 (bootloader) Done initialization of the card (bootloader) erase_grpsize: -16777216 (bootloader) erase_grpmult: 261078040 (bootloader) wp_grpsize: 1 (bootloader) wp_grpen: 1 (bootloader) perm_wp: 0 (bootloader) temp_wp: 0 (bootloader) [Tuxera][Error] No exFAT partition found (bootloader) [JAVACARD_ERR] verify javacard: get signature fail, SW= 6f00 (bootloader) writesecureflag: Permission denied, value 4 OKAY Execution time is 2(s) Operation finished |
Hello, Please PM your clip ID. |
