Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > xtc2cliP
Old 12-20-2017, 20:59   #1 (permalink)
Member: 1048485
Sonork: 100.1664362
Thanks Meter: 2
Exclamation [javacard_err]
Hi sir
my clip have problem for s-off and super cid m8 and 826h and m9
[Tuxera][Error] No exFAT partition found
(bootloader) [JAVACARD_ERR] verify javacard: get signature fail, SW=
i repair clip with win32disk but upgrad with xtc2client1.4 not actived.
i change flex cable .
but problem not solve.
Sending oem writesecureflag 0
... (bootloader) SecuritySDInit: counter = 8
(bootloader) m8_init_sd, SD card already power on
(bootloader) [SPEW] GPIO 0 status is 0
(bootloader) sdhci_open: id=0
(bootloader) Initializing MMC host data structure and clock!
(bootloader) mmc slot#2 clock enabled
(bootloader) sdhci_set_clock: slot 2, freq 192000000
(bootloader) GPLL0 is enabled
(bootloader) clock_update_cfg_sd is done
(bootloader) sd clock set done
(bootloader) sdhci_set_bus_width: bus width 0
(bootloader) sdhci_clk_supply: freq 400000
(bootloader) Error: Command never completed
(bootloader) Error: Command timeout error
(bootloader) Error: Command completed with errors
(bootloader) The response for CMD8 does not match the supplied value
(bootloader) Decoded CID fields:
(bootloader) Manufacturer ID: 7f
(bootloader) OEM ID: 0x0
(bootloader) Product Name: 5270
(bootloader) Product revision: 5.2
(bootloader) Product serial number: B4E
(bootloader) Manufacturing date: 2 2015
(bootloader) sdhci_clk_supply: freq 50000000
(bootloader) sdhci_set_bus_width: bus width 1
(bootloader) Done initialization of the card
(bootloader) erase_grpsize: -16777216
(bootloader) erase_grpmult: 261078040
(bootloader) wp_grpsize: 1
(bootloader) wp_grpen: 1
(bootloader) perm_wp: 0
(bootloader) temp_wp: 0
(bootloader) [Tuxera][Error] No exFAT partition found
(bootloader) [JAVACARD_ERR] verify javacard: get signature fail, SW= 6f00
(bootloader) writesecureflag: Permission denied, value 4
OKAY
Execution time is 2(s)
Operation finished
Old 12-22-2017, 13:00   #2 (permalink)
Member: 2416253
Thanks Meter: 4,162
Hello,
Please PM your clip ID.
Page generated in 0.11143 seconds with 9 queries
