[JAVACARD_ERR] Javacard reset response timeout C= 1000 when i use direct mode for soff Sending oem writesecureflag 0 ... (bootloader) SecuritySDInit counter = 3 (bootloader) t6ul_init_sd, SD card already power on (bootloader) sdhw_7xxx_open: id=0 (bootloader) [ERR] Cmd5 polling status timed out, MCI_STATUS: 0xC0000 (bootloader) [ERR] sdcc_command: sdcc_poll_status error, rc: 2 (bootloader) [ERR] Cmd8 polling status timed out, MCI_STATUS: 0xC0000 (bootloader) [ERR] sdcc_command: sdcc_poll_status error, rc: 2 (bootloader) [ERR] Cmd8 polling status timed out, MCI_STATUS: 0xC0000 (bootloader) [ERR] sdcc_command: sdcc_poll_status error, rc: 2 (bootloader) [ERR] Cmd8 polling status timed out, MCI_STATUS: 0xC0000 (bootloader) [ERR] sdcc_command: sdcc_poll_status error, rc: 2 (bootloader) sdcc_init_memory_device done (bootloader) SD clock freq = 19MHz.... (bootloader) [Tuxera] No exFAT partition found (bootloader) [FAT_ERROR] can not find FAT16/32 partition (bootloader) [FAT_ERROR] fat_open_file: can not find SMART_IO.CRD (bootloader) [JAVACARD_ERR] SMART_IO.CRD cann't find (bootloader) writesecureflag: Permission denied, value 1 OKAY but when use simlock via phone show chek keycard failed i try format and write img file but not slove |
Hello, The error itself means not connection with the smartcard, so first make sure smartcard is correctly inserted. You can eject it, gently clean and put it back. Second thing you can try it to change the flex cable, as if it's damaged it may cause such problems. Please let us know the results! |
