Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > xtc2cliP
Old 05-06-2019, 12:32   #1 (permalink)
saeed-gsm's Avatar
Member: 44742
Thanks Meter: 293
Red face [JAVACARD_ERR] Javacard reset response timeout C= 1000
when i use direct mode for soff
Sending oem writesecureflag 0
... (bootloader) SecuritySDInit counter = 3
(bootloader) t6ul_init_sd, SD card already power on
(bootloader) sdhw_7xxx_open: id=0
(bootloader) [ERR] Cmd5 polling status timed out, MCI_STATUS: 0xC0000
(bootloader) [ERR] sdcc_command: sdcc_poll_status error, rc: 2
(bootloader) [ERR] Cmd8 polling status timed out, MCI_STATUS: 0xC0000
(bootloader) sdcc_init_memory_device done
(bootloader) SD clock freq = 19MHz....
(bootloader) [Tuxera] No exFAT partition found
(bootloader) [FAT_ERROR] can not find FAT16/32 partition
(bootloader) [FAT_ERROR] fat_open_file: can not find SMART_IO.CRD
(bootloader) [JAVACARD_ERR] SMART_IO.CRD cann't find
(bootloader) writesecureflag: Permission denied, value 1
OKAY
but when use simlock via phone show
chek keycard failed
i try format and write img file but not slove
Old 05-06-2019, 21:09   #2 (permalink)
Member: 2416253
Thanks Meter: 4,103
Hello,
The error itself means not connection with the smartcard, so first make sure smartcard is correctly inserted. You can eject it, gently clean and put it back.
Second thing you can try it to change the flex cable, as if it's damaged it may cause such problems.
Please let us know the results!
Page generated in 0.18993 seconds with 7 queries
