07-13-2015, 10:16 | #1 (permalink) |
Insane Poster Join Date: Jul 2012 Location: Salisbury UK
Member: 1785021 Status: Offline Sonork: 100.1618898 Thanks Meter: 65 | Legacy Phones (Desire HD) unable to detect COM Port [ solved ] Trying to swtich into modem mode ... Sending oem rtask c Phone DISconnected After this drivers are installed as follows. Qualcomm HS-USB Diagnostics Port (COM 209) Qualcomm HS-USB NMEA 9002 (COM 211) But software doesnt detect the COM ports and I am unable to continue unlock process. Any ideas why this is happening? |
07-13-2015, 10:23 | #2 (permalink) | |
No Life Poster Join Date: Jan 2010 Location: China
Member: 1222089 Status: Offline Sonork: 100.1583019 Thanks Meter: 2,688 | Quote:
here the steps for legacy phones http://forum.gsmhosting.com/vbb/11156262-post1.html | |
07-13-2015, 10:40 | #3 (permalink) | |
No Life Poster Join Date: Jun 2015
Member: 2416253 Status: Offline Thanks Meter: 4,163 | Quote:
Let me know please, so I can provide further assistance. | |
07-13-2015, 10:52 | #4 (permalink) |
Member: 1785021 Status: Offline Sonork: 100.1618898 Thanks Meter: 65 | Thanks for pointing that out! I have checked the modem ports and I can see that the modem drivers are installed correctly and the modem is on COM port 208, but its not possible to select this port in the XTCClip software window (even after clicking refresh). Any ideas? |
07-13-2015, 11:10 | #5 (permalink) | |
07-13-2015, 11:49 | #6 (permalink) |
Member: 1785021 Status: Offline Sonork: 100.1618898 Thanks Meter: 65 | Tried this as well, but the software is not finding the com port. i have set com port to com6, I can communicate with the modem by sendinfg commands etc from modem properties, but xtc software doesnt find or allow me to choose com port. Trying to swtich into modem mode ... Sending oem rtask c Phone DISconnected Tried on two different PCs with same result. |
07-13-2015, 14:28 | #7 (permalink) | |
07-13-2015, 18:02 | #8 (permalink) |
Member: 1785021 Status: Offline Sonork: 100.1618898 Thanks Meter: 65 | Im using Windows 7 32 Bit, also tried on 64bit with same result. Ive also tried the same operation on a Desire S (Saga) with same problem. COM port remains blank (even after installing drivers and clicking refresh). Thanks for your help! |
07-14-2015, 07:42 | #10 (permalink) |
Member: 1785021 Status: Offline Sonork: 100.1618898 Thanks Meter: 65 | Whoops! Schoolboy error!! That's solved it!! Thanks. Just managed to S-off, Unlock and change CID on the Saga, allthough I needed to click the s-off button, change cid and unlock buttons twice for some reason. It might also help to add a status bar as the software appears to do nothing at first. Thanks for you great support! EDIT: Have now also managed to do the same with several Desire HD's (without needing to click the buttons twice, however I notice when you change phones and connect next phone in Fastboot mode you need to close down the software and reopen it in order to start work on next phone. Last edited by unlockingshop; 07-14-2015 at 07:52. |
The Following User Says Thank You to unlockingshop For This Useful Post: |
