M7 Sprint M7_WLS unlock problem [SOLVED] Need help on this, I got an M7_WLS and I'm trying to unlock it, first I did S-OFF and changed CID to Super CID, that was ok Then I read SPC ok Diagnostics ports enabled ok but when I try to unlock get this message:: Trying to connect in Sprint mode... Trying to connect on COM356 Checking server connection... Communicating with the XTC 2 Clip ... Connecting to the server... Please wait, generating unlock hash... Server connection failed I restarted pc, used another pc, rebooted wifi modem, etc but keeps giving that message. Any advice? |
Hello, Please try now. |
BR. |
please how to s-off m7 sprint hboot 1.61 |
I'm using a original ycable, but can't s-off... sd init fail The M7 information: 16/05/2018 10:07:36 Reading information... 16/05/2018 10:07:36 Using Fastboot mode... 16/05/2018 10:07:36 Reading common information 16/05/2018 10:07:36 (bootloader) version: 0.5 (bootloader) version-bootloader: 1.61.0000 (bootloader) version-baseband: 1.01.20.1225 (bootloader) version-cpld: None (bootloader) version-microp: None (bootloader) version-main: 6.23.651.7 (bootloader) version-misc: PVT SHIP S-ON (bootloader) serialno: FA3ABS905697 (bootloader) imei: 990001461985376 (bootloader) meid: 99000146198537 (bootloader) product: m7_wls (bootloader) platform: HBOOT-8064 (bootloader) modelid: PN0720000 (bootloader) cidnum: SPCS_001 (bootloader) battery-status: good (bootloader) battery-voltage: 3911mV (bootloader) partition-layout: Generic (bootloader) security: on (bootloader) build-mode: SHIP (bootloader) boot-mode: FASTBOOT (bootloader) commitno-bootloader: dirty-0e2a13e5 (bootloader) hbootpreupdate: 11 (bootloader) gencheckpt: 0 all: Done! The steps i made was: SD mode > New Sec 0 > Save to drive Conect ycable to M7 > Conect XTC 2 Clip to female USB ( microSD adapter ) > Conect PowerBank to USB > in fastboot reboot bootloader > Fastboot > SIM Unlock Thanks in advance! |
y-cable or sdcard problem most probably |
The ycable i think is original ( bought with XTC 2 Clip ), i will try with other SD card reader. |
It hangs on reading the card, and i have to force to shutdown or reboot Check keycard failed Any ideas? Thanks in advance! |
After hours struggling i have managed to s-off and CID. I did all ... unlock by sd mode, even try by SPC code. I can't unlock, the SIM card is not recognized, don't do nothing when i insert in. Any ideas? Thanks in advance! |
Use sprint tab for sim unlock |
16/05/2018 22:03:33 Detected MEID: 99000428905711 16/05/2018 22:03:34 SPC for this MEID is 980141 16/05/2018 22:03:43 rebooting... 16/05/2018 22:04:20 Opening special menu 16/05/2018 22:04:30 Please check your phone screen: 16/05/2018 22:04:30 DM Command Service Should appear 16/05/2018 22:04:30 wrong - please enter manually. 16/05/2018 22:04:30 Please wait... 16/05/2018 22:04:34 If you see 'Diag enabled' 16/05/2018 22:05:00 Trying to connect in Sprint mode... 16/05/2018 22:05:00 Trying to connect on COM33 16/05/2018 22:05:00 Checking server connection... 16/05/2018 22:05:00 Communicating with the XTC 2 Clip ... 16/05/2018 22:05:06 Connecting to the server... 16/05/2018 22:05:06 Please wait, generating unlock hash... 16/05/2018 22:05:06 Process finished SUCCESSFULLY 16/05/2018 22:05:06 Please restart your phone for the changes to take effect 16/05/2018 22:05:06 Note: If your phone is M7 - please do S-OFF first and then unlock again 16/05/2018 22:05:06 In case of calls/network problems, please do reset by: 16/05/2018 22:05:06 Open phone dialer, type ##786#, wait for the menu to appear 16/05/2018 22:05:06 Press MENU in top right corner and select RESET 16/05/2018 22:05:06 Enter SPC code 16/05/2018 22:05:06 Wait for the phone to verify the code and reboot 16/05/2018 22:08:45 Sending reboot-bootloader 16/05/2018 22:08:46 Phone DISconnected After RESET and REBOOT the same thing, i can't get a reading after i insert SIM card. Am i doing something wrong?! I got two phones with this can't pass by that... |
do not reset phone after unlock reset makes it relock again |
I did that when the SIM card wasn't detected, and after i reset i tried again but doesn't recognize at all. |
I am trying to clean, since the phone is a swiss cheese now with all the modification. But i can't! Fastboot info: (bootloader) version: 0.5 (bootloader) version-bootloader: 1.61.0000 (bootloader) version-baseband: 1.00.20.1108 (bootloader) version-cpld: None (bootloader) version-microp: None (bootloader) version-main: 4.06.651.4 (bootloader) version-misc: PVT SHIP S-OFF (bootloader) serialno: FA3ABS905697 (bootloader) imei: 990001461985376 (bootloader) meid: 99000146198537 (bootloader) product: m7_wls (bootloader) platform: HBOOT-8064 (bootloader) modelid: PN0720000 (bootloader) cidnum: 11111111 (bootloader) battery-status: good (bootloader) battery-voltage: 3997mV (bootloader) partition-layout: Generic (bootloader) security: off (bootloader) build-mode: SHIP (bootloader) boot-mode: RUU (bootloader) commitno-bootloader: dirty-7661b1d7 (bootloader) hbootpreupdate: 11 (bootloader) gencheckpt: 0 Thanks in advance! |
