Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > xtc2cliP
Old 02-11-2016, 22:54   #1 (permalink)
Member: 886703
Thanks Meter: 20
M7 Sprint M7_WLS unlock problem [SOLVED]
Need help on this, I got an M7_WLS and I'm trying to unlock it, first I did S-OFF and changed CID to Super CID, that was ok
Then I read SPC ok
Diagnostics ports enabled ok
but when I try to unlock get this message::
Trying to connect in Sprint mode...
Trying to connect on COM356
Checking server connection...
Communicating with the XTC 2 Clip ...
Connecting to the server...
Please wait, generating unlock hash...
Server connection failed
I restarted pc, used another pc, rebooted wifi modem, etc but keeps giving that message.
Any advice?
Old 02-12-2016, 14:23   #2 (permalink)
Member: 2416253
Thanks Meter: 3,756
Hello,
Please try now.
Old 02-12-2016, 19:05   #3 (permalink)
Member: 886703
Thanks Meter: 20
Originally Posted by xtc2clip View Post
Hello,
Please try now.
Thanks, I worked and XTC 2 clip did its work, but after restarting the handsed it is still locked, any thing to do on this now?
BR.
Old 02-13-2016, 06:49   #4 (permalink)
Member: 2311244
please how to s-off m7 sprint hboot 1.61
Old 02-13-2016, 15:56   #5 (permalink)
Member: 886703
Thanks Meter: 20
Using sd_editor and Y cable
Old 05-16-2018, 11:33   #6 (permalink)
Member: 2771305
Thanks Meter: 35
I got the same problem here!
I'm using a original ycable, but can't s-off... sd init fail
The M7 information:
16/05/2018 10:07:36 Reading information...
16/05/2018 10:07:36 Using Fastboot mode...
16/05/2018 10:07:36 Reading common information
16/05/2018 10:07:36 (bootloader) version: 0.5
(bootloader) version-bootloader: 1.61.0000
(bootloader) version-baseband: 1.01.20.1225
(bootloader) version-cpld: None
(bootloader) version-microp: None
(bootloader) version-main: 6.23.651.7
(bootloader) version-misc: PVT SHIP S-ON
(bootloader) serialno: FA3ABS905697
(bootloader) imei: 990001461985376
(bootloader) meid: 99000146198537
(bootloader) product: m7_wls
(bootloader) platform: HBOOT-8064
(bootloader) modelid: PN0720000
(bootloader) cidnum: SPCS_001
(bootloader) battery-status: good
(bootloader) battery-voltage: 3911mV
(bootloader) partition-layout: Generic
(bootloader) security: on
(bootloader) build-mode: SHIP
(bootloader) boot-mode: FASTBOOT
(bootloader) commitno-bootloader: dirty-0e2a13e5
(bootloader) hbootpreupdate: 11
(bootloader) gencheckpt: 0
all: Done!
The steps i made was:
SD mode > New Sec 0 > Save to drive
Conect ycable to M7 > Conect XTC 2 Clip to female USB ( microSD adapter ) > Conect PowerBank to USB > in fastboot reboot bootloader > Fastboot > SIM Unlock
Thanks in advance!
Old 05-16-2018, 12:33   #7 (permalink)
deepakgarg's Avatar
Member: 220603
Sonork: 100.1624258
Thanks Meter: 1,072
y-cable or sdcard problem most probably
Old 05-16-2018, 14:11   #8 (permalink)
Member: 2771305
Thanks Meter: 35
Thanks for your comment!
The ycable i think is original ( bought with XTC 2 Clip ), i will try with other SD card reader.
Old 05-16-2018, 17:34   #9 (permalink)
Member: 2771305
Thanks Meter: 35
I try and use a different adapter and this time it reads the SD but its a false positive. I mean, it continuous to stay on S-ON.
It hangs on reading the card, and i have to force to shutdown or reboot Check keycard failed
Any ideas?
Thanks in advance!
Old 05-16-2018, 21:48   #10 (permalink)
Member: 2771305
Thanks Meter: 35
After hours struggling i have managed to s-off and CID. I did all ... unlock by sd mode, even try by SPC code. I can't unlock, the SIM card is not recognized, don't do nothing when i insert in. Any ideas?
Thanks in advance!
Old 05-16-2018, 22:43   #11 (permalink)
deepakgarg's Avatar
Member: 220603
Sonork: 100.1624258
Thanks Meter: 1,072
Use sprint tab for sim unlock
Old 05-16-2018, 23:23   #12 (permalink)
Member: 2771305
Thanks Meter: 35
I already did that... please that a look to my steps.
16/05/2018 22:03:33 Detected MEID: 99000428905711
16/05/2018 22:03:34 SPC for this MEID is 980141
16/05/2018 22:03:43 rebooting...
16/05/2018 22:04:20 Opening special menu
16/05/2018 22:04:30 Please check your phone screen:
16/05/2018 22:04:30 DM Command Service Should appear
16/05/2018 22:04:30 wrong - please enter manually.
16/05/2018 22:04:30 Please wait...
16/05/2018 22:04:34 If you see 'Diag enabled'
16/05/2018 22:05:00 Trying to connect in Sprint mode...
16/05/2018 22:05:00 Trying to connect on COM33
16/05/2018 22:05:00 Checking server connection...
16/05/2018 22:05:00 Communicating with the XTC 2 Clip ...
16/05/2018 22:05:06 Connecting to the server...
16/05/2018 22:05:06 Please wait, generating unlock hash...
16/05/2018 22:05:06 Process finished SUCCESSFULLY
16/05/2018 22:05:06 Please restart your phone for the changes to take effect
16/05/2018 22:05:06 Note: If your phone is M7 - please do S-OFF first and then unlock again
16/05/2018 22:05:06 In case of calls/network problems, please do reset by:
16/05/2018 22:05:06 Open phone dialer, type ##786#, wait for the menu to appear
16/05/2018 22:05:06 Press MENU in top right corner and select RESET
16/05/2018 22:05:06 Enter SPC code
16/05/2018 22:05:06 Wait for the phone to verify the code and reboot
16/05/2018 22:08:45 Sending reboot-bootloader
16/05/2018 22:08:46 Phone DISconnected
After RESET and REBOOT the same thing, i can't get a reading after i insert SIM card.
Am i doing something wrong?! I got two phones with this can't pass by that...
Old 05-17-2018, 08:47   #13 (permalink)
deepakgarg's Avatar
Member: 220603
Sonork: 100.1624258
Thanks Meter: 1,072
do not reset phone after unlock
reset makes it relock again
The Following User Says Thank You to deepakgarg For This Useful Post:
Old 05-17-2018, 18:52   #14 (permalink)
Member: 2771305
Thanks Meter: 35
Didn't knew that, thanks!
I did that when the SIM card wasn't detected, and after i reset i tried again but doesn't recognize at all.
Old 05-17-2018, 20:01   #15 (permalink)
Member: 2771305
Thanks Meter: 35
I am trying to clean, since the phone is a swiss cheese now with all the modification. But i can't!
Fastboot info:
(bootloader) version-baseband: 1.00.20.1108
(bootloader) version-main: 4.06.651.4
(bootloader) version-misc: PVT SHIP S-OFF
(bootloader) cidnum: 11111111
(bootloader) battery-voltage: 3997mV
(bootloader) security: off
(bootloader) boot-mode: RUU
(bootloader) commitno-bootloader: dirty-7661b1d7
Thanks in advance!
Page generated in 0.50382 seconds with 7 queries
