Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > xtc2cliP
Old 07-18-2018, 15:50   #1 (permalink)
Member: 1026122
Sonork: 100.1640842
Thanks Meter: 184
M8 Flash failed.
Dear Bro
pls check this
I check this CID..it is J15
So I download this file
0P6BIMG_M8_UL_M60_SENSE70_MR_HTC_Europe_6.12.401.4 _R_Radio_1.29.214500021.12G_20.72.4196t.01_F_relea se_464423_signed_2_4
Any help bro to flash the set
Tx
Old 07-18-2018, 16:36   #2 (permalink)
Member: 1026122
Sonork: 100.1640842
Thanks Meter: 184
Could you please give me a correct flash file.OR partial file
Tx
Old 07-18-2018, 17:21   #3 (permalink)
deepakgarg's Avatar
Member: 220603
Thanks Meter: 1,164
partial file u can try 460122 from support
Old 07-19-2018, 10:05   #4 (permalink)
Member: 1026122
Sonork: 100.1640842
Thanks Meter: 184
How to do this partial file bro becasue no J15 CID
So did i need to s off and make the super cid?
Tx
Old 07-19-2018, 10:49   #5 (permalink)
deepakgarg's Avatar
Member: 220603
Thanks Meter: 1,164
Tx
yes need super cid and s-off
Old 07-19-2018, 15:43   #6 (permalink)
Member: 1026122
Sonork: 100.1640842
Thanks Meter: 184
I have the error
SD init fail !!!
So is it possible to use direct with out micro sd insert
Tx
Old 07-19-2018, 16:33   #7 (permalink)
Member: 1026122
Sonork: 100.1640842
Thanks Meter: 184
I need the partial file for CID-J15
Please upload the file to support
Tx
Old 07-19-2018, 16:41   #8 (permalink)
deepakgarg's Avatar
Member: 220603
Thanks Meter: 1,164
http://forum.gsmhosting.com/vbb/f961...ample-1967566/
try insert clip correctly in sd slot
The Following User Says Thank You to deepakgarg For This Useful Post:
Old 07-24-2018, 06:27   #9 (permalink)
Member: 1026122
Sonork: 100.1640842
Thanks Meter: 184
I can not make the cid 111111 and s-off.
Could you please give the kitkat J15 flash file
Tx
Old 07-24-2018, 13:29   #10 (permalink)
deepakgarg's Avatar
Member: 220603
Thanks Meter: 1,164
flash same version as in phone than if update required use ota via wifi
Page generated in 0.18936 seconds with 8 queries
