12-11-2018, 17:02 | #1 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Pakistan/UAE/WorldWide
Member: 417298 Status: Offline Sonork: 100.1578269 Thanks Meter: 18,268 | M9 Flashing Error . how to fix [SOLVED] Code: Reading information... Using Fastboot mode... Reading common information (bootloader) kernel: lk (bootloader) product: htc_himawhl (bootloader) version: 1.0 (bootloader) imei: 990005027725622 (bootloader) version-main: 4.27.651.4 (bootloader) boot-mode: RUU (bootloader) version-baseband: 4.00.C1310411@70106 (bootloader) version-bootloader: 1.0.0.0000 (bootloader) mid: 0PJA20000 (bootloader) cid: SPCS_001 all: finished. total time: 0.012s htc_fastboot finished Reading CID information ... (bootloader) cid: SPCS_001 OKAY finished. total time: 0.012s htc_fastboot finished Reading MEID information ... (bootloader) meid: 990005027xxxxxx OKAY finished. total time: 0.008s htc_fastboot finished Reading IMEI1 information ... (bootloader) imei: 990005027725622 OKAY finished. total time: 0.018s htc_fastboot finished Reading IMEI2 information ... (bootloader) imei2: OKAY finished. total time: 0.008s htc_fastboot finished Reading secure flag information ... (bootloader) Device security level S-ON OKAY finished. total time: 0.024s htc_fastboot finished Reading serial number information ... (bootloader) Device Serial No. is HT5ACSV01155 OKAY finished. total time: 0.014s htc_fastboot finished Reading color information ... (bootloader) COLOR ID: DEF00 OKAY finished. total time: 0.007s htc_fastboot finished Read information completed. Code: Starting flash process... target rom version: 4.27.651.4 found large-zip header, file count: 6 processing file 1/6... sending 'zip' (103623 KB)... OKAY [ 7.292s] writing 'zip'... (bootloader) HOSD CL#695981 (bootloader) ERR check AES encrypted magic string failed. (bootloader) end@Done FAILED (remote: 12 RU_ZIP_ERROR ) finished. total time: 9.324s Flash process completed. Flash not successfull, reboot will not be done Br |
The Following User Says Thank You to Mohsin-* For This Useful Post: |
12-11-2018, 18:03 | #2 (permalink) |
Member: 417298 Status: Offline Sonork: 100.1578269 Thanks Meter: 18,268 | Problem Solved . I got Solution for This Issue . please remove Br Mohsin-* |
