Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > xtc2cliP
Old 12-19-2016, 22:35   #16 (permalink)
islam01's Avatar
Member: 299831
Thanks Meter: 142
I'm looking. Any user has not reached the solution with this method. There are always negative comments from users. Different solutions need to be found.
Old 12-20-2016, 10:29   #17 (permalink)
Member: 2416253
Thanks Meter: 4,162
This is the only possible and 100% working solution.
It will not work ONLY if your phone has EMMC problem.
Old 02-13-2017, 09:45   #18 (permalink)
Member: 91834
Thanks Meter: 11
I can confirm eMMC problem with these phones. Just revived two M9 0PJA100 with dead Hynix chips. HOSD files weren't helping. After eMMC replacement both HOSD worked right away.
Hynix is bad. Hynix is very bad.
The Following User Says Thank You to Radiotrance For This Useful Post:
Old 02-13-2017, 10:17   #19 (permalink)
Member: 91834
Thanks Meter: 11
This is how bad eMMC looks like.
Processing file...C:\W\Samsung eMMC BGND3R_15_12_2016_16_51_55.bin
Writing as RAW data
Z3X EasyJtag Software ver. 2.5.0.7
Skip loading eMMC Addon Firmware
CMD Pullup Level:2763 mV
CMD Active Level:2743 mV
Input file : C:\W\Samsung eMMC BGND3R_15_12_2016_16_51_55.bin
Writing 004D800000 bytes to 00000000 ...ROM1 (USER ROM)
Full Verify Enabled!
Write Block Failed, Reason: Write Block Verify Error
Done.
Old 02-13-2017, 12:30   #20 (permalink)
Member: 2036352
Thanks Meter: 2
Hi,
Has every M9 these chips or are this hynix chips only
in some devices installed?
Can I check if I have this chips in system info in download mode?
emmc chip in my case is samsung or iīm wrong with this conclusion?
Old 02-13-2017, 15:46   #21 (permalink)
Member: 91834
Thanks Meter: 11
As far as I know you can't check eMMC type by any way other than disassemling the phone.
I got 3 M9 here and all of them have Hynix H26M64103EMR.
Old 02-13-2017, 17:12   #22 (permalink)
Member: 2416253
Thanks Meter: 4,162
Well, in download mode it should show the info, but since we can't get to download mode, there is no way I guess.
Old 02-13-2017, 17:34   #23 (permalink)
Member: 91834
Thanks Meter: 11
There is NO info about eMMC vendor anywhere, including Download Mode.
Old 02-13-2017, 17:37   #24 (permalink)
Member: 2036352
Thanks Meter: 2
No donīt get me wrong I don't have this issue (not yet) Iīm only interessted if
all devices could be affected and if I could check wich emmc it has in download mode
when device is running normal.
For example:
The M9 I have here is showing emmc: samsung...xxx
So my thought is......is this device "safe"
Edit:
ok dontīt get your post before mine was ready..thx
Old 02-13-2017, 18:11   #25 (permalink)
Member: 2566174
Thanks Meter: 9
Hi sir
any solution for A9 29Q9300 ? same problem no downlaod mode only bootloader mode
thx
Old 02-14-2017, 18:15   #26 (permalink)
Member: 2036352
Thanks Meter: 2
This is only for the protocol...
It seems that some of us are lucky....if you look at this:
https://de.ifixit.com/Teardown/HTC+O...Teardown/39166
look at step 10
there are no hynix chips installed...only samsung emmc like printed correctly in download mode /system info ( I suspect)
Old 03-23-2017, 10:14   #27 (permalink)
Member: 2698636
i try this but nothing happenes
can you help me
Old 04-01-2017, 20:16   #28 (permalink)
Member: 791223
where are file???? no xtc clip soport, no gsmhosting found. please
Old 04-01-2017, 22:24   #29 (permalink)
Member: 2647496
Thanks Meter: 40
I hope you are not trying to tell us that you are an alien from the moon?
Old 04-03-2017, 16:52   #30 (permalink)
Member: 2416253
Thanks Meter: 4,162
Hello,
hosd files are located on our support.
File no. are 900001 and 900002
The Following User Says Thank You to xtc2clip For This Useful Post:
Page generated in 0.19841 seconds with 10 queries
