Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > xtc2cliP
Old 03-29-2016, 14:43   #1 (permalink)
Member: 2365163
Thanks Meter: 20
HTC A9 frp unlock [solved]
Hello
The special unlock feature for HTC A9 seems not to be working, it copies the files on the drive, after inserting the sd card and writing data over in factory mode the bootloader remains locked with s-on.
The same method worked perfectly when i tried it on HTC M9.
Please help.
Old 03-29-2016, 17:39   #2 (permalink)
Member: 2416253
Thanks Meter: 4,162
Hello,
FRP unlock, SIM unlock, S-OFF and bootloader unlock are 4 DIFFERENT operations.
So please make S-OFF first, then you can remove FRP.
Old 03-30-2016, 07:16   #3 (permalink)
Member: 2365163
Thanks Meter: 20
Hello!
I copied the files on sd card as the manual said and booted the phone into test mode, but the bootloader didnt unlock. Due to that i could't perform s-off.
Old 03-30-2016, 18:59   #4 (permalink)
Member: 2416253
Thanks Meter: 4,162
Originally Posted by Sukavanucci View Post
Hello!
S-OFF is done in download mode, see here:
http://forum.gsmhosting.com/vbb/f961...6-etc-2022417/
The Following 3 Users Say Thank You to xtc2clip For This Useful Post:
Old 04-01-2016, 13:05   #5 (permalink)
Member: 2365163
Thanks Meter: 20
Hello again
Thank you very much!
Your manual worked
The Following User Says Thank You to Sukavanucci For This Useful Post:
Page generated in 0.15678 seconds with 8 queries
