03-30-2019, 18:38 | #1 (permalink) |
No Life Poster Join Date: May 2009 Location: Srilanka
Member: 1026122 Status: Offline Sonork: 100.1640842 Thanks Meter: 184 | Need flash file For M9 J15 [SOLVED] Need the flash file for this Reading common information (bootloader) kernel: lk (bootloader) product: htc_himauhl (bootloader) version: 1.0 (bootloader) imei: 357++++++++++ (bootloader) version-main: 3.35.401.32 (bootloader) boot-mode: download (bootloader) version-baseband: 01.01_U11440792_97.00.51203G_F (bootloader) version-bootloader: 1.0.0.0000 (bootloader) mid: 0PJA10000 (bootloader) cid: HTC__J15 . (bootloader) Device security level S-ON OKAY Need the flash file for this but in the support not found. only ! PARTIAL FLASH file with HTC Europe 4.14.401.7 Pls give the 4.14.+++ or 4.28.++++ file to flash the set. i have the problem on gallery..can not view photo.Even Hard reset not help Tx |
03-30-2019, 19:46 | #2 (permalink) |
No Life Poster Join Date: Jun 2015
Member: 2416253 Status: Offline Thanks Meter: 4,162 | Hello, We have all files for this model, you don't need partial, partial is only MAY be required, if you want to upgrade from 3.x to 4.x Your releases are *.401.*, like 3.35.401.32 (file 487248 on support) and 4.41.101.7 (file 490768 on support) and 4.28.401.3 (file 498151 on support) Try original version first, it if doesn't help - upgrade. |
The Following User Says Thank You to xtc2clip For This Useful Post: |
03-31-2019, 10:13 | #3 (permalink) | |
Member: 1026122 Status: Offline Sonork: 100.1640842 Thanks Meter: 184 | Quote:
What is the exact steps to s-off and super cid 111111 for M9 Could you pls advice me because in the forum here and there many confusion Tx | |
03-31-2019, 13:27 | #4 (permalink) |
Member: 1026122 Status: Offline Sonork: 100.1640842 Thanks Meter: 184 | I s-oof and make super cid 11111111 and flash with 464289...I got error 22 RU_HEADER_ERROR FAIL22 RU_HEADER_ERROR But if I go to support by pressing model ID 0PJA10000 then no file 498151 , 487248 but 490768 is there (patial flash file) Also If I check flash by model then the above files are there but NO MIS(S) measns no model 0PJA10000 Please advice me beacse now phone is on logo after flash with 464289 3.36.709.3 Tx |
03-31-2019, 15:10 | #6 (permalink) |
Member: 1026122 Status: Offline Sonork: 100.1640842 Thanks Meter: 184 | thanks bro It is done via s-off and super cid then flash with 487248. But Dear Supporter how we know that 487248 file MID and CID because in the support it is not display only empty space please advice bro Tx |
04-03-2019, 13:57 | #8 (permalink) | ||
Pls advice me that how to find the mid from the file Tx | ||
04-03-2019, 14:44 | #9 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Chandigarh,India Age: 40
Member: 220603 Status: Offline Thanks Meter: 1,164 | match product id like htc_himauhl if mid is unknown to you also you can search by model name like m9u but always go with fastboot or download mode info for safety |
The Following User Says Thank You to deepakgarg For This Useful Post: |
