03-11-2016, 18:58 | #18 (permalink) |
No Life Poster Join Date: Nov 2006 Location: (United States Of Islam) Age: 37
Member: 399832 Status: Offline Sonork: Faheem Anjum Thanks Meter: 24,310 | For data on sprint in some brands need to modify rom to get working data I know only about lg phones |
The Following User Says Thank You to Faheem Anjum For This Useful Post: |
03-29-2016, 19:16 | #19 (permalink) |
No Life Poster Join Date: Jun 2015
Member: 2416253 Status: Offline Thanks Meter: 4,162 | I'm getting G (HDSPA?) internet on A9 Sprint without any additional actions. Can't test LTE, as we don't have LTE bands supported by this A9. So I'm a bit lost here, why you are not getting internet connection at all. |
10-05-2016, 05:19 | #20 (permalink) |
Junior Member Join Date: Mar 2015 Location: Santo Domingo
Member: 2360925 Status: Offline Thanks Meter: 12 | cant connect to internet via mobile I unlocked (xtc2Clip) 10 cell htc one a9 ... 8 functions well and data network (HSDPA) perfect. but there are 2 that only works call, cant connect to internet via mobile |
10-05-2016, 17:47 | #21 (permalink) | |
Member: 2416253 Status: Offline Thanks Meter: 4,162 | Quote:
Because Sprint phones may not work on LTE/internet without convertion. | |
10-05-2016, 20:45 | #22 (permalink) | |
Member: 2360925 Status: Offline Thanks Meter: 12 | Quote:
yes Htc one a9 sprint ,software version 1.10.401.7,, (In some works the data in others not,. always says offline) Those Who Have the problem of data, the upgrade to the latest version Sprint_1.60.651.4, but nothing without data | |
11-08-2016, 19:25 | #24 (permalink) |
Junior Member Join Date: Sep 2016
Member: 2620840 Status: Offline Thanks Meter: 6 | Let me share my experience with my A9 sprint. It was converted to developers and then back to sprint, after all it had no data.. couple of days playing with different settings, resetting a lot I found that in APN settings Bearer is set to - UNSPECIFIED. I unchecked it and checked manually everything down below: LTE, HSPAP, HSPA, HSUPA, HSDPA etc.. It started catching data and now works as it should... I hope it will help (maybe with htc 10 as well ) forgot to mention I am on GSM |
The Following 3 Users Say Thank You to bandura For This Useful Post: |
11-10-2016, 20:03 | #25 (permalink) |
Insane Poster Join Date: Nov 2015
Member: 2484103 Status: Offline Thanks Meter: 3 | i recommend you to update but do s-off then update the phone when i first bought one htc one a9 from sprint on that time i wasnt able to use it with one carrier but with another one i was able. after one update i was able to use with all the carriers but i found one trick that could maybe help you. turn the data off even if you dont have and then power off the phone,reboot it and it showed data with that carrier. but also when turning off the phone again remember to turn off data. if not you will end up with no data again. |
01-19-2017, 18:24 | #27 (permalink) |
Member: 2360925 Status: Offline Thanks Meter: 12 | Solution data connection network htc one a9 Solution thanks to ,jianC, Convert Sprint/Boost HTC One A9 to Dev Unlock -I flashed the updated Unlocked 1.57.617.60 (RUU Unlock_1.57.617.60 ). The RUU version should not make a significant difference. -After the RUU is flashed, the device will reboot. It is optional to wait for the device to finish the initial boot. The device will not be in a usable state as the IMEI will be missing, radio won't work, and have some other critical bugs. -Reboot the device into bootloader mode. -the Sprint radio (extracted from 1.60.651.4 RUU sprint) What this fixes: No mobile data (but have voice/sms) on sprint firmware after sim unlock Missing IMEI/random reboots after Unlocked RUU flash My device specs: Model: 2PQ9300 htc_hiaeul PVT S-OFF (was previously htc hiaewhl before conversion) CID-11111111 MID-2PQ912000 RADIO-1.0.U00297.1 60310 (Sprint radio) OS-1.57.617.60 |
01-09-2018, 18:06 | #28 (permalink) |
Junior Member Join Date: Jan 2016
Member: 2523314 Status: Offline Thanks Meter: 1 | I have a sprint A9 software version 2.18.651.2, successfully unlocked GSM but no data. I tried all the suggestions in this thread without success. Any idea how to enable data. Thanks |
