One A9 flashing error....
I Got this phone with error "
Photos has stopped Close app"
Google Play service has stopped"
2PQ9IMG_HIA_AERO_UHL_N70_SENSE80GP_MR_hTC_Asia_WWE _2.18.707.1_Radio_1.1.U40062.1@61209_60.00_F_relea se_500657_signed_2_4.zip
While Writing this firmware i get the following Error.
Starting flash process...
target rom version: 2.18.707.1
found large-zip header, file count: 21
processing file 1/21...
sending 'zip' (98798 KB)...
OKAY [ 4.981s]
writing 'zip'...
(bootloader) HOSD CL#901480
(bootloader) GPT (gpt_main_32g.img) is up-to-dated. [17408]
(bootloader) Perform pre-update
(bootloader) WARN Skip partition_info due to unmatched partition name
(bootloader) WARN Skip backup_android-info.txt due to unmatched partitio
(bootloader) n name
(bootloader) get 25 images from zip(zip_type=3)
(bootloader) start@25
(bootloader) apppreload.img@BYPASS
(bootloader) aboot_signed.img@100%
(bootloader) cota.img@BYPASS
(bootloader) sbl1-8952-1.img@100%
(bootloader) ERR [hosd] CRC ERROR
(bootloader) ERR should be 0x2b7a3d40, calculated 0x2bb0a17d
(bootloader) hosd_signed.img@FAIL
(bootloader) rpm-8952-1.img@100%
(bootloader) boot_signed.img@BYPASS
(bootloader) recovery_signed.img@BYPASS
(bootloader) adsp.img@BYPASS
(bootloader) dsp.img@BYPASS
(bootloader) wcnss.img@BYPASS
(bootloader) rcdata.img@BYPASS
(bootloader) rfg_3.img@BYPASS
(bootloader) modemst1.img@BYPASS
(bootloader) modemst2.img@BYPASS
(bootloader) fsc.img@BYPASS
(bootloader) tz-8952-1.img@100%
(bootloader) hyp-8952-1.img@100%
(bootloader) cmnlib32.img@100%
(bootloader) keymaster.img@100%
(bootloader) pg2fs_ship_signkey.img@100%
(bootloader) sensor_hub.img@BYPASS
(bootloader) tp_SYN3708.img@BYPASS
(bootloader) splash1.nb0@BYPASS
(bootloader) radio.img@BYPASS
(bootloader) ERR [SD_UPDATE_ERR] int do_update_zip_buf(int): unzip_and_f
(bootloader) lash_images fail, err 11
(bootloader) ERR [SD_UPDATE_ERR] update_fb_ZIP_buf: fail to flash zip: 1
(bootl
oader) ERR [SD_UPDATE_ERR] sddownload failed: 11
(bootloader) ERR Update zip file failed.
(bootloader) Update zip file OK
(bootloader) ERR ZIP ERROR CODE, 11
(bootloader) end@Done
FAILED (remote: 11 RU_CHECKSUM_FAIL invalid rom-pack )
finished. total time: 9.351s
HBoot pre-update sequence
Flash process completed.
Flash not successfull, reboot will not be done
This is the Fastboot Info of the phone before flashing The Phone.
Reading information...
Using Fastboot mode...
Reading common information
(bootloader) kernel: lk
(bootloader) product: htc_hiaeuhl
(bootloader) version: 1.0
(bootloader) max-download-size: 1164800000
(bootloader) serialno: HT5C1BE01430
(bootloader) slot-count: 0
(bootloader) current-slot:
(bootloader) imei: 352636072883460
(bootloader) version-main: 2.18.707.1
(bootloader) boot-mode: RUU
(bootloader) version-baseband: 1.1.U40062.1@61209
(bootloader) version-bootloader: 1.0.0.0000
(bootloader) mid: 2PQ910000
(bootloader) cid: 11111111
