05-25-2016, 09:40 | #1 (permalink) |
No Life Poster Join Date: Dec 2005 Location: Ha Noi - Viet Nam Age: 18
Member: 207400 Status: Offline Sonork: 100.1582556 Thanks Meter: 262 | Pls help M8 verizon s-off, CID Code: 5/25/2016 3:27:55 PM Phone connected [HT438SF00580] *** Fastboot mode 5/25/2016 3:27:57 PM Reading information... 5/25/2016 3:27:57 PM Using Fastboot mode... 5/25/2016 3:27:57 PM Reading common information 5/25/2016 3:27:57 PM (bootloader) version: 0.5 (bootloader) version-bootloader: 3.19.0.0000 (bootloader) version-baseband: 1.12.20.1211 (bootloader) version-cpld: None (bootloader) version-microp: None (bootloader) version-main: 4.17.605.5 (bootloader) version-misc: PVT SHIP S-ON (bootloader) serialno: HT438SF00580 (bootloader) imei: 99000499814xxxx (bootloader) imei2: Not Support (bootloader) meid: 9900049981xxxxx (bootloader) product: m8_wlv (bootloader) platform: hTCBmsm8974 (bootloader) modelid: 0P6B20000 (bootloader) cidnum: VZW__001 (bootloader) battery-status: good (bootloader) battery-voltage: 0mV (bootloader) partition-layout: Generic (bootloader) security: on (bootloader) build-mode: SHIP (bootloader) boot-mode: FASTBOOT (bootloader) commitno-bootloader: f2489bd1 (bootloader) hbootpreupdate: 11 (bootloader) gencheckpt: 0 all: Done! Execution time is 10(ms) 5/25/2016 3:27:57 PM Reading secure flag information 5/25/2016 3:27:57 PM ... (bootloader) secure_flag: 3 OKAY Execution time is 3(ms) 5/25/2016 3:27:57 PM Reading CID information 5/25/2016 3:27:57 PM ... (bootloader) cid: VZW__001 OKAY Execution time is 3(ms) 5/25/2016 3:27:57 PM Reading MEID information 5/25/2016 3:27:58 PM ... (bootloader) meid: 9900049981xxxx OKAY Execution time is 2(ms) 5/25/2016 3:27:58 PM Read information completed. 5/25/2016 3:28:05 PM Sending oem writesecureflag 0 5/25/2016 3:28:05 PM ... (bootloader) SecuritySDInit: counter = 3 (bootloader) m8wl_init_sd, SD card already power on (bootloader) [SPEW] GPIO 0 status is 0 (bootloader) sdhci_open: id=0 (bootloader) Initializing MMC host data structure and clock! (bootloader) mmc slot#2 clock enabled (bootloader) sdhci_set_clock: slot 2, freq 192000000 (bootloader) GPLL0 is enabled (bootloader) clock_update_cfg_sd is done (bootloader) sd clock set done (bootloader) sdhci_set_bus_width: bus width 0 (bootloader) sdhci_clk_supply: freq 400000 5/25/2016 3:28:06 PM (bootloader) Error: Command never completed (bootloader) Error: Command timeout error (bootloader) Error: Command completed with errors (bootloader) The response for CMD8 does not match the supplied value (bootloader) Decoded CID fields: (bootloader) Manufacturer ID: 7f (bootloader) OEM ID: 0x0 (bootloader) Product Name: 5270 (bootloader) Product revision: 5.2 (bootloader) Product serial number: B4E (bootloader) Manufacturing date: 2 2015 (bootloader) sdhci_clk_supply: freq 50000000 (bootloader) sdhci_set_bus_width: bus width 1 (bootloader) Done initialization of the card (bootloader) erase_grpsize: -16777216 (bootloader) erase_grpmult: 261078256 (bootloader) wp_grpsize: 1 (bootloader) wp_grpen: 1 (bootloader) perm_wp: 0 (bootloader) temp_wp: 0 (bootloader) [Tuxera][Error] No exFAT partition found 5/25/2016 3:28:09 PM (bootloader) writesecureflag: KeyCard remain count 10000 (bootloader) PID:266 (bootloader) Start Verify: 3 5/25/2016 3:28:09 PM (bootloader) [PGFS] partition_update_pgfs: pg1fs_security (bootloader) TZ_HTC_SVC_ENC ret = 0 (bootloader) [PGFS] partition_update_pgfs: pg2fs_sec_recovery OKAY Execution time is 4(s) 5/25/2016 3:28:09 PM Operation finished 5/25/2016 3:28:12 PM Sending oem writecid 11111111 5/25/2016 3:28:12 PM ... (bootloader) Start Verify: 0 (bootloader) Input CID is super CID (bootloader) Start Verify: 0 OKAY Execution time is 14(ms) 5/25/2016 3:28:12 PM Operation finished 5/25/2016 3:28:20 PM Sending reboot-bootloader 5/25/2016 3:28:20 PM rebooting into bootloader... OKAY Execution time is 11(ms) 5/25/2016 3:28:20 PM Operation finished 5/25/2016 3:28:21 PM Phone DISconnected |
05-25-2016, 14:44 | #3 (permalink) |
Crazy Poster Join Date: Apr 2016
Member: 2553855 Status: Offline Thanks Meter: 5 | Predefine your settings. Connect XTC2 clip to the com port of your computer. Go to SD editor and change cid to super CID. S/off value should be 0. And put your Imei no inside the imei Box and save to drive. Now second method is to put that flex cable directly to your Micro SD card slot and run fastboot mode and select simlock option. Now go way down to select yes option by selecting vloume up button. And reboot. Select simlock option again if you dont see big execution list. Make sure to place your flex cable on SD adapter slot and push gently inside your phone. Sent from my SAMSUNG-SM-G870A using Tapatalk |
05-30-2016, 09:26 | #6 (permalink) |
Member: 207400 Status: Offline Sonork: 100.1582556 Thanks Meter: 262 | But phone still same , nothing change. Maybe phone's emmc has problem because it require type password to decrypt storage |
05-30-2016, 15:37 | #7 (permalink) | |
No Life Poster Join Date: Jun 2015
Member: 2416253 Status: Offline Thanks Meter: 4,162 | Quote:
Also try to do master reset or enter wrong pass 30 times, it should reset. | |
