09-09-2015, 09:42 | #1 (permalink) |
Insane Poster Join Date: Aug 2003 Location: lusaka, zambia
Member: 37104 Status: Offline Thanks Meter: 8 | Poor quality of xtc2clip flex-cables I FOLLOWED THE MANUAL AND UPDATED SUCCESSFULLY. I HAVE TRIED TO SP UNLOCK, S-OFF OR REPAIR IMEI BUT FAILED. I HAVE COME TO REALIZE THAT THE ONLY PROBLEM THAT I HAVE ARE ALL THE THREE(3) CABLES THAT CAME WITH IT. IT PAINS TO READ ABOUT SUCCESS STORIES FROM OTHER MEMBERS AND TO ONLY PACK MY RECENTLY AQUIRED BOX IN MY DRAWERS BECAUSE TO LUCK OF QUALITY FLEX-CABLES THAT I WAS SUPPLIED WITH. XTC2CLIP TEAM HHAVE TO DO A LOT BETTER ON THEIR FLEX-CABLES. THE FOLLOWING IS WHAT IT SHOWS ON DIRECT MODE--- Sending oem writesecureflag 0 ... (bootloader) SecuritySDInit: counter = 3 (bootloader) a11chl_init_sd, SD card already power on (bootloader) a11chl_init_sd, SD card io already power on (bootloader) sdhci_open: id=0 (bootloader) Initializing MMC host data structure and clock! (bootloader) mmc slot#2 clock enabled (bootloader) clock_config_mmc: slot 2, freq 192000000 (bootloader) GPLL0 is enabled (bootloader) clock_update_cfg_sd is done (bootloader) sd clock set done (bootloader) sdhci_set_bus_width: bus width 0 (bootloader) sdhci_clk_supply: freq 400000 (bootloader) Error: Command never completed (bootloader) Error: Command timeout error (bootloader) Error: Command completed with errors (bootloader) The response for CMD8 does not match the supplied value (bootloader) Decoded CID fields: (bootloader) Manufacturer ID: 7f (bootloader) OEM ID: 0x0 (bootloader) Product Name: 5270 (bootloader) Product revision: 5.2 (bootloader) Product serial number: B4E (bootloader) Manufacturing date: 2 2015 (bootloader) sdhci_clk_supply: freq 50000000 (bootloader) sdhci_set_bus_width: bus width 1 (bootloader) Done initialization of the card (bootloader) erase_grpsize: 1854296576 (bootloader) erase_grpmult: 49152 (bootloader) wp_grpsize: 1 (bootloader) wp_grpen: 1 (bootloader) perm_wp: 0 (bootloader) temp_wp: 0 (bootloader) [SD_ERR] sd_read_sector: read sector failed (778135908 1) (bootloader) [Tuxera][Error] Primary partition 0 (778135908/1141509631): (bootloader) failed to read sector #778135908 (bootloader) [SD_ERR] sd_read_sector: read sector failed (168689522 1) (bootloader) [Tuxera][Error] Primary partition 1 (168689522/1936028240): (bootloader) failed to read sector #168689522 (bootloader) [SD_ERR] sd_read_sector: read sector failed (1869881465 1) (bootloader) [Tuxera][Error] Primary partition 2 (1869881465/1936028192): (bootloader) failed to read sector #1869881465 (bootloader) [Tuxera][Error] No exFAT partition found (bootloader) [FAT_ERROR] FAT12 is not supported! (bootloader) [FAT_ERROR] FAT12 is not supported! (bootloader) [FAT_ERROR] fat_open_file: can not find SMART_IO.CRD (bootloader) [JAVACARD_ERR] SMART_IO.CRD cann't find (bootloader) writesecureflag: Permission denied, value 1 Execution time is 1125(ms) OKAY Operation finished Phone DISconnecteD PLEASE ADVICE |
09-09-2015, 11:14 | #3 (permalink) |
Member: 37104 Status: Offline Thanks Meter: 8 | hi. thanks for your prompt help. I tried according to what you had sent to me on skype and i further comfirm that everything is working well after doing it. thanks a lot. |
The Following User Says Thank You to abraham For This Useful Post: |
