04-13-2019, 13:27 | #1 (permalink) |
Junior Member Join Date: May 2008
Member: 783157 Status: Offline Thanks Meter: 0 | Two issues after HTC One M9 conversion OTA updates function OK, but two problems exist: 1. There is the 'red text' showing on the initial boot screen. 2. Unable to change from s-off to s-on. Shows FAILED (remote: Partition verify fail -9) Can anyone help to resolve these issues? |
04-13-2019, 14:33 | #3 (permalink) |
Member: 783157 Status: Offline Thanks Meter: 0 | Yes, changed MID and CID then flashed first the partial 4.14.401.7 and after the full 4.14.401.7 Further updates via OTA. By the way the full 4.14.401.7 file on the server gives a MD5 mismatch! |
04-14-2019, 14:47 | #4 (permalink) | |
No Life Poster Join Date: Jun 2015
Member: 2416253 Status: Offline Thanks Meter: 4,162 | Quote:
As to MD5 mismatch - thank you, the MD5 on the site was corrected. | |
The Following User Says Thank You to xtc2clip For This Useful Post: |
01-25-2020, 11:50 | #5 (permalink) |
Member: 783157 Status: Offline Thanks Meter: 0 | The phone has been in storage since the conversion and now I want to use it I notice that there's no network signal. Radio is off and can't be turned on. Do I need to flash something like 3.35.617.12 for example? |
02-02-2020, 13:07 | #6 (permalink) |
Member: 783157 Status: Offline Thanks Meter: 0 | So I've tried all versions of 617 and 401 files and on none of them can the radio be turned on. Airplane mode is always showing 'Turning off'. Is there a fix for this or is it this likely to be due to a hardware problem? |
