05-17-2019, 18:28 | #1 (permalink) |
Freak Poster Join Date: Jun 2008 Location: lima peru
Member: 787364 Status: Offline Sonork: 100.1617985 Thanks Meter: 9 | problem repair imxx U11 *this equipment already repaired before I always did, everything went well. used version 1.38 and 1.37 Change flex etc etc 1. Checking phone connectivity....... Phone connection confirmed! HTC KEY CARD VERSION: 7 2. Checking Server connectivity... Server connection confirmed! 3. Checking PowerAdapter connectivity... Process started PowerAdapter connected, processing request to adapter... Starting operation... Sending oem writeimei 357888888778773 ... (bootloader) [ERR] Command error !!! OKAY finished. total time: 0.007s htc_fastboot finished Operation completed! Releasing adapter. Request completed Starting PowerAdapter procedure: Detected model: HTC U11 (Android 8.x) Special recovery file is available 1. Checking phone connectivity....... Phone connection confirmed! HTC KEY CARD VERSION: 7 2. Checking Server connectivity... Server connection confirmed! 3. Checking PowerAdapter connectivity... Process started PowerAdapter connected, processing request to adapter... Rebooting to boot-loader: Waiting for the phone... Phone DISconnected Phone connected [FA7B90500687] *** Fastboot mode Phone DISconnected Executing operation... Starting operation... Operation completed! Releasing adapter. Request completed |
05-17-2019, 23:33 | #2 (permalink) | |
Member: 787364 Status: Offline Sonork: 100.1617985 Thanks Meter: 9 | Quote:
done, everything done, but it is not allowed to repair the imei. It was repaired before. | |
05-20-2019, 17:56 | #4 (permalink) | |
I'm sending the logos that I have! | |
05-20-2019, 22:35 | #6 (permalink) | |
I receive an error (comand error) and then I use power adapter tool (it stays on the black screen!) the phone is unlocked the boot loader it changes cid 1111111 now the imei is 0 I pass the recovery but as it does not record the imei! | |
05-23-2019, 22:33 | #8 (permalink) | |
repair the file system flash my phone My case is similar to this man's. What I need is to downgrade the version ... not found rom 7.1.1 (2.42.617.7):confuso: http://forum.gsmhosting.com/vbb/f961...-imei-2532077/ | |
05-24-2019, 19:55 | #9 (permalink) | |
No Life Poster Join Date: Jun 2015
Member: 2416253 Status: Offline Thanks Meter: 4,162 | Quote:
You can downgrade to any 7.x version, it's available on our support. Are you using XTC 2 Tool 1.38? | |
