problem with xtc2clip [SOLVED] xtc2clip not s-off eror Sending oem writesecureflag 0 ... (bootloader) SecuritySDInit: counter = 2 (bootloader) a3ul_init_sd, SD card already power on (bootloader) a3ul_init_sd, SD card io already power on (bootloader) a3ul_init_sd: SKU AHD#1 or AHD#2 (bootloader) sdhw_7xxx_open: id=0 (bootloader) clock_update_cfg_sd is done (bootloader) sd clock set done (bootloader) clock_update_cfg_sd is done (bootloader) sd clock set done (bootloader) [DEBUG] Cmd8 polling status timed out, MCI_STATUS: 0xC0000 (bootloader) [DEBUG] sdcc_command: sdcc_poll_status error, rc: 2 (bootloader) [DEBUG] Cmd8 polling status timed out, MCI_STATUS: 0xC0000 (bootloader) [DEBUG] sdcc_command: sdcc_poll_status error, rc: 2 (bootloader) [DEBUG] Cmd8 polling status timed out, MCI_STATUS: 0xC0000 (bootloader) [DEBUG] sdcc_command: sdcc_poll_status error, rc: 2 (bootloader) sdcc_init_memory_device done (bootloader) SD clock freq = 19MHz.... (bootloader) GPLL0 is enabled (bootloader) clock_update_cfg_sd is done (bootloader) sd clock set done (bootloader) [Tuxera][Error] No exFAT partition found (bootloader) [JAVACARD_ERR] get Decrease Renew Cycle fail, SW= 6986 (bootloader) writesecureflag: Permission denied, value 8 OKAY finished. total time: 3.009s htc_fastboot finished Operation finished |
Hello! Please run XTC 2 Client 1.4 and then PM me with your clip ID, we will fix it. Thanks! |
where is clip id? go is inactive in my software |
xxxxxx is my dongle serial number |
You may now run XTC 2 Client once again and re-activate your clip. |
thanks solve problem |
