09-27-2018, 13:00 | #1 (permalink) |
No Life Poster Join Date: Jan 2006 Age: 40
Member: 224075 Status: Offline Thanks Meter: 69 | s-off problem i try many times to s-off this pone but i have problem in direct mode Sending oem writesecureflag 0 ... (bootloader) SecuritySDInit: counter = 3 (bootloader) a16dwg_init_sd, SD card already power on (bootloader) a16dwg_init_sd, SD card io already power on (bootloader) sdhci_open: id=0 (bootloader) Initializing MMC host data structure and clock! (bootloader) mmc slot#2 clock enabled (bootloader) sdhci_set_clock: slot 2, freq 192000000 (bootloader) GPLL0 is enabled (bootloader) clock_update_cfg_sd is done (bootloader) sd clock set done (bootloader) sdhci_set_bus_width: bus width 0 (bootloader) sdhci_clk_supply: freq 400000 (bootloader) Error: Command never completed (bootloader) Error: Command timeout error (bootloader) Error: Command completed with errors (bootloader) The response for CMD8 does not match the supplied value (bootloader) Decoded CID fields: (bootloader) Manufacturer ID: 7f (bootloader) OEM ID: 0x0 (bootloader) Product Name: 5270 (bootloader) Product revision: 5.2 (bootloader) Product serial number: B4E (bootloader) Manufacturing date: 2 2015 (bootloader) sdhci_clk_supply: freq 50000000 (bootloader) sdhci_set_bus_width: bus width 1 (bootloader) Done initialization of the card (bootloader) erase_grpsize: 0 (bootloader) erase_grpmult: 96 (bootloader) wp_grpsize: 1 (bootloader) wp_grpen: 1 (bootloader) perm_wp: 0 (bootloader) temp_wp: 0 (bootloader) [Tuxera][Error] No exFAT partition found (bootloader) [JAVACARD_ERR] get Decrease Renew Cycle fail, SW= 6986 (bootloader) writesecureflag: Permission denied, value 8 OKAY Execution time is 4(s) Operation finished i power adpter mode 1. Checking phone connectivity....... Phone connection confirmed! Requested card version not detected, version 6 will be used 2. Checking Server connectivity... Server connection confirmed! 3. Checking PowerAdapter connectivity... Process started PowerAdapter connected, processing request to adapter... Starting operation... Sending oem writesecureflag 0 ... (bootloader) SecuritySDInit: counter = 5 (bootloader) a16dwg_init_sd, SD card already power on (bootloader) a16dwg_init_sd, SD card io already power on (bootloader) sdhci_open: id=0 (bootloader) Initializing MMC host data structure and clock! (bootloader) mmc slot#2 clock enabled (bootloader) sdhci_set_clock: slot 2, freq 192000000 (bootloader) GPLL0 is enabled (bootloader) clock_update_cfg_sd is done (bootloader) sd clock set done (bootloader) sdhci_set_bus_width: bus width 0 (bootloader) sdhci_clk_supply: freq 400000 Building connection Data exchange sequence (bootloader) Error: Command never completed (bootloader) Error: Command timeout error (bootloader) Error: Command completed with errors (bootloader) The response for CMD8 does not match the supplied value (bootloader) Decoded CID fields: (bootloader) Manufacturer ID: 7f (bootloader) OEM ID: 0x0 (bootloader) Product Name: 5270 (bootloader) Product revision: 5.2 (bootloader) Product serial number: B4E (bootloader) Manufacturing date: 2 2015 (bootloader) sdhci_clk_supply: freq 50000000 (bootloader) sdhci_set_bus_width: bus width 1 (bootloader) Done initialization of the card (bootloader) erase_grpsize: 0 (bootloader) erase_grpmult: 96 (bootloader) wp_grpsize: 1 (bootloader) wp_grpen: 1 (bootloader) perm_wp: 0 (bootloader) temp_wp: 0 (bootloader) [Tuxera][Error] No exFAT partition found Data exchange sequence Requesting information from server (bootloader) [JAVACARD_ERR] Wait for card response timedout.C= 5000 (bootloader) writesecureflag: Permission denied, value 4 OKAY Execution time is 15(s) Request sent, waiting for reply ... 1 second Processing... Data exchange completed Releasing adapter. Request completed i try to use a new xtc2clip flex cableand i have same problem i try to use Win32 Desk Manger and write image2015.imgand rewrite s-off to my clip and i have same problem ihave this problem for many htc phones last days and i didnt know how to solve this |
10-01-2018, 13:34 | #4 (permalink) |
Member: 224075 Status: Offline Thanks Meter: 69 | Sending oem writesecureflag 0 ... (bootloader) SecuritySDInit: counter = 3 (bootloader) a56djdugl_init_sd, SD card already power on (bootloader) a56djdugl_init_sd, SD card io already power on (bootloader) sdhci_open: id=0 (bootloader) Initializing MMC host data structure and clock! (bootloader) mmc slot#2 clock enabled (bootloader) sdhci_set_clock: slot 2, freq 192000000 (bootloader) GPLL0 is enabled (bootloader) clock_update_cfg_sd is done (bootloader) sd clock set done (bootloader) sdhci_set_bus_width: bus width 0 (bootloader) sdhci_clk_supply: freq 400000 (bootloader) Error: Command never completed (bootloader) Error: Command timeout error (bootloader) Error: Command completed with errors (bootloader) The response for CMD8 does not match the supplied value (bootloader) Decoded CID fields: (bootloader) Manufacturer ID: 7f (bootloader) OEM ID: 0x0 (bootloader) Product Name: 5270 (bootloader) Product revision: 5.2 (bootloader) Product serial number: B4E (bootloader) Manufacturing date: 2 2015 (bootloader) sdhci_clk_supply: freq 50000000 (bootloader) sdhci_set_bus_width: bus width 1 (bootloader) Done initialization of the card (bootloader) erase_grpsize: 0 (bootloader) erase_grpmult: 96 (bootloader) wp_grpsize: 1 (bootloader) wp_grpen: 1 (bootloader) perm_wp: 0 (bootloader) temp_wp: 0 (bootloader) [Tuxera][Error] No exFAT partition found (bootloader) [JAVACARD_ERR] get Decrease Renew Cycle fail, SW= 6986 (bootloader) writesecureflag: Permission denied, value 8 OKAY Execution time is 4(s) Operation finished 1. Checking phone connectivity....... Phone connection confirmed! Requested card version not detected, version 6 will be used 2. Checking Server connectivity... Server connection confirmed! 3. Checking PowerAdapter connectivity... Process started PowerAdapter connected, processing request to adapter... Starting operation... Sending oem writesecureflag 0 ... (bootloader) SecuritySDInit: counter = 4 (bootloader) a56djdugl_init_sd, SD card already power on (bootloader) a56djdugl_init_sd, SD card io already power on (bootloader) sdhci_open: id=0 (bootloader) Initializing MMC host data structure and clock! (bootloader) mmc slot#2 clock enabled (bootloader) sdhci_set_clock: slot 2, freq 192000000 (bootloader) GPLL0 is enabled (bootloader) clock_update_cfg_sd is done (bootloader) sd clock set done (bootloader) sdhci_set_bus_width: bus width 0 (bootloader) sdhci_clk_supply: freq 400000 Building connection (bootloader) Error: Command never completed (bootloader) Error: Command timeout error (bootloader) Error: Command completed with errors (bootloader) The response for CMD8 does not match the supplied value (bootloader) Decoded CID fields: (bootloader) Manufacturer ID: 7f (bootloader) OEM ID: 0x0 (bootloader) Product Name: 5270 (bootloader) Product revision: 5.2 (bootloader) Product serial number: B4E (bootloader) Manufacturing date: 2 2015 (bootloader) sdhci_clk_supply: freq 50000000 (bootloader) sdhci_set_bus_width: bus width 1 (bootloader) Done initialization of the card (bootloader) erase_grpsize: 5 (bootloader) erase_grpmult: 96 (bootloader) wp_grpsize: 1 (bootloader) wp_grpen: 1 (bootloader) perm_wp: 0 (bootloader) temp_wp: 0 (bootloader) [Tuxera][Error] No exFAT partition found Data exchange sequence. Request sent, waiting for reply ... 3 second(s) Processing... Data exchange completed Data exchange sequence. (bootloader) writesecureflag: Permission denied, value 4 OKAY Execution time is 14(s) Operation completed! Releasing adapter. Request completed i still have problem please advice me what i can do Last edited by Ehab_se; 10-01-2018 at 13:41. |
10-01-2018, 19:30 | #5 (permalink) |
No Life Poster Join Date: Jun 2015
Member: 2416253 Status: Offline Thanks Meter: 4,162 | PowerAdapter is ONLY for new (2017+) models like U11, etc. Do NOT try to use it with old models please, it's not going to work. Use regular smartcard. Your original log is with normal smartcard, please use it again. |
