09-04-2016, 14:42 | #1 (permalink) |
Freak Poster Join Date: Nov 2004 Location: Factory Unlocked :D Age: 44
Member: 91995 Status: Offline Thanks Meter: 76 | HtC M9 S-OFF still flashing error i have HTC M9 S-OFF when i try to phone flash getting this error here is the logs Code: Starting flash process... < waiting for device > Phone DISconnected target rom version: 3.35.401.12 Phone connected [HT51VYJ00111] *** Fastboot mode found large-zip header, file count: 8 processing file 1/8... Phone DISconnected sending 'zip' (134725 KB)... OKAY [ 8.362s] writing 'zip'... (bootloader) HOSD CL#671758 Phone connected [HT51VYJ00111] *** Fastboot mode (bootloader) ERR Model ID not matched (bootloader) ERR [SD_UPDATE_ERR] MODEL ID NOT ALLOWED (bootloader) ERR [SD_UPDATE_ERR] sddownload failed: 10 (bootloader) ERR Update zip file failed. (bootloader) ERR ZIP ERROR, exit read zip loop (bootloader) Update zip file OK (bootloader) ERR ZIP ERROR CODE, 10 (bootloader) end@Done FAILED (remote: 10 RU_MODELID_FAIL modelid in android-info mismatched ) finished. total time: 10.852s Flash process completed. Flash not successfull, reboot will not be done Phone DISconnected |
09-04-2016, 15:23 | #5 (permalink) |
Member: 91995 Status: Offline Thanks Meter: 76 | i'm using these 2 files 0PJAIMG_HIMA_UHL_M60_SENSE70_MR_HTC_Europe_3.35.40 1.12_Radio_01.01_U11440792_97.00.51203G_F_release_ 464236_signed_2_4 0PJAIMG_HIMA_UHL_L51_SENSE70_MR_HTC_Europe_2.10.40 1.1_Radio_01.04_U11440601_71.02.50709G_F_release_4 44118_signed_2_4 here is the getvar details C:\Program Files (x86)\Minimal ADB and Fastboot>fastboot getvar all < waiting for device > (bootloader) kernel: lk (bootloader) product: htc_himauhl (bootloader) version: 1.0 (bootloader) imei: 357228060031099 (bootloader) version-main: 1.32.710.7 (bootloader) boot-mode: download (bootloader) version-baseband: 01.01_U11440261_56.01.50303G_3_F (bootloader) version-bootloader: 1.0.0.0000 (bootloader) mid: 0PJA12000 (bootloader) cid: 11111111 all: finished. total time: 0.033s |
09-04-2016, 15:53 | #6 (permalink) | |
Crazy Poster Join Date: Aug 2014
Member: 2249672 Status: Offline Thanks Meter: 17 | go support area nd download this ruu flash your devices Quote:
09-04-2016, 17:07 | #7 (permalink) |
Member: 91995 Status: Offline Thanks Meter: 76 | downloaded and flash new error.. Starting flash process... Phone DISconnected target reported max download size of 800000000 bytes Invalid sparse file format at header magi |
09-04-2016, 17:47 | #8 (permalink) | |
Member: 2249672 Status: Offline Thanks Meter: 17 | Quote:
rename your above to 0PJAIMG put to sdcard nd boot yur mobile into bootloader mode will process automatically | |
09-05-2016, 10:05 | #9 (permalink) | |
No Life Poster Join Date: Jun 2015
Member: 2416253 Status: Offline Thanks Meter: 4,162 | Quote:
You cannot flash in bootloader mode, you must flash in download or RUU (prefered) mode. | |
The Following 2 Users Say Thank You to xtc2clip For This Useful Post: |
09-15-2016, 12:09 | #10 (permalink) | |
Member: 91995 Status: Offline Thanks Meter: 76 | Quote:
Starting flash process... < waiting for device > Phone DISconnected Phone connected [HT51VYJ00111] *** Fastboot mode Phone DISconnected found large-zip header, file count: 7 processing file 1/7... Phone connected [HT51VYJ00111] *** Fastboot mode Phone DISconnected sending 'zip' (262051 KB)... OKAY [ 13.365s] writing 'zip'... (bootloader) HOSD CL#671758 (bootloader) ERR Model ID not matched (bootloader) ERR [SD_UPDATE_ERR] MODEL ID NOT ALLOWED (bootloader) ERR [SD_UPDATE_ERR] sddownload failed: 10 (bootloader) ERR Update zip file failed. (bootloader) ERR ZIP ERROR, exit read zip loop (bootloader) Update zip file OK (bootloader) ERR ZIP ERROR CODE, 10 (bootloader) end@Done FAILED (remote: 10 RU_MODELID_FAIL modelid in android-info mismatched ) finished. total time: 15.460s Phone connected [HT51VYJ00111] *** Fastboot mode Flash process completed. Flash not successfull, reboot will not be done | |
09-15-2016, 18:39 | #11 (permalink) | |
Please read info, press the model id in XTC 2 Tool and you will be taken to download page. | |
The Following User Says Thank You to xtc2clip For This Useful Post: |
09-22-2016, 10:49 | #12 (permalink) | |
Reading information... Using Fastboot mode... Reading common information and please check the attachment pics | |
09-22-2016, 12:12 | #13 (permalink) |
Member: 2416253 Status: Offline Thanks Meter: 4,162 | It seems that some important data is damaged in your phone. If you can't read info, it means you need to delete old drivers and install new drivers from our web-site. Contact me when you will get your drivers working. Or contact me via Skype: xtc2clip |
09-22-2016, 12:53 | #14 (permalink) | |
i don't know whats wrong with this phone . anyways thanks for your help . and just added you in skype please accept my request BR | |
09-22-2016, 14:12 | #15 (permalink) | |
Please check the signature of your drivers, in your case you had 2 strange drivers signed by some chinese companies, which could be a virus. | |
