04-18-2018, 10:38 | #1 (permalink) |
Freak Poster Join Date: Nov 2004 Location: Türkiye Age: 48
Member: 92779 Status: Offline Thanks Meter: 16 | s-off -xtc 2 clip not work Telif Hakkı (c) 2009 Microsoft Corporation. Tüm hakları saklıdır. C:\Program Files\Minimal ADB and Fastboot>fastboot oem writesecureflag 0 < waiting for device > ... (bootloader) SecuritySDInit: counter = 2 (bootloader) m8qlul_init_sd, SD card already power on (bootloader) m8qlul_init_sd, SD card io already power on (bootloader) sdhci_open: id=0 (bootloader) Initializing MMC host data structure and clock! (bootloader) mmc slot#2 clock enabled (bootloader) sdhci_set_clock: slot 2, freq 192000000 (bootloader) GPLL0 is enabled (bootloader) clock_update_cfg_sd is done (bootloader) sd clock set done (bootloader) sdhci_set_bus_width: bus width 0 (bootloader) sdhci_clk_supply: freq 400000 (bootloader) Error: Command never completed (bootloader) Error: Command timeout error (bootloader) Error: Command completed with errors (bootloader) The response for CMD8 does not match the supplied value (bootloader) Decoded CID fields: (bootloader) Manufacturer ID: 7f (bootloader) OEM ID: 0x0 (bootloader) Product Name: 5270 (bootloader) Product revision: 5.2 (bootloader) Product serial number: B4E (bootloader) Manufacturing date: 2 2015 (bootloader) sdhci_clk_supply: freq 50000000 (bootloader) sdhci_set_bus_width: bus width 1 (bootloader) Done initialization of the card (bootloader) erase_grpsize: -1986507011 (bootloader) erase_grpmult: -1921008668 (bootloader) wp_grpsize: 1 (bootloader) wp_grpen: 1 (bootloader) perm_wp: 0 (bootloader) temp_wp: 0 (bootloader) [Tuxera][Error] No exFAT partition found (bootloader) [JAVACARD_ERR] verify javacard: get signature fail, SW= 6f00 (bootloader) writesecureflag: Permission denied, value 4 OKAY [ 2.467s] finished. total time: 2.469s C:\Program Files\Minimal ADB and Fastboot>fastboot oem writesecureflag 0 ... (bootloader) SecuritySDInit: counter = 3 (bootloader) m8qlul_init_sd, SD card already power on (bootloader) m8qlul_init_sd, SD card io already power on (bootloader) sdhci_open: id=0 (bootloader) Initializing MMC host data structure and clock! (bootloader) mmc slot#2 clock enabled (bootloader) sdhci_set_clock: slot 2, freq 192000000 (bootloader) GPLL0 is enabled (bootloader) clock_update_cfg_sd is done (bootloader) sd clock set done (bootloader) sdhci_set_bus_width: bus width 0 (bootloader) sdhci_clk_supply: freq 400000 (bootloader) Error: Command never completed (bootloader) Error: Command timeout error (bootloader) Error: Command completed with errors (bootloader) The response for CMD8 does not match the supplied value (bootloader) Decoded CID fields: (bootloader) Manufacturer ID: 7f (bootloader) OEM ID: 0x0 (bootloader) Product Name: 5270 (bootloader) Product revision: 5.2 (bootloader) Product serial number: B4E (bootloader) Manufacturing date: 2 2015 (bootloader) sdhci_clk_supply: freq 50000000 (bootloader) sdhci_set_bus_width: bus width 1 (bootloader) Done initialization of the card (bootloader) erase_grpsize: 0 (bootloader) erase_grpmult: -1921008668 (bootloader) wp_grpsize: 1 (bootloader) wp_grpen: 1 (bootloader) perm_wp: 0 (bootloader) temp_wp: 0 (bootloader) [Tuxera][Error] No exFAT partition found (bootloader) [JAVACARD_ERR] verify javacard: get signature fail, SW= 6f00 (bootloader) writesecureflag: Permission denied, value 4 OKAY [ 2.577s] finished. total time: 2.579s not successful |
04-18-2018, 15:27 | #3 (permalink) |
No Life Poster Join Date: Jun 2015
Member: 2416253 Status: Offline Thanks Meter: 4,162 | Hello, It feels like your smartcard is not operating correctly. Please PM your clip ID, I will check. |
The Following User Says Thank You to xtc2clip For This Useful Post: |
05-02-2018, 16:19 | #5 (permalink) |
Member: 92779 Status: Offline Thanks Meter: 16 | (bootloader) SecuritySDInit: counter = 3 (bootloader) m8qlul_init_sd, SD card already power on (bootloader) m8qlul_init_sd, SD card io already power on (bootloader) sdhci_open: id=0 (bootloader) Initializing MMC host data structure and clock! (bootloader) mmc slot#2 clock enabled (bootloader) sdhci_set_clock: slot 2, freq 192000000 (bootloader) GPLL0 is enabled (bootloader) clock_update_cfg_sd is done (bootloader) sd clock set done (bootloader) sdhci_set_bus_width: bus width 0 (bootloader) sdhci_clk_supply: freq 400000 (bootloader) Error: Command never completed (bootloader) Error: Command timeout error (bootloader) Error: Command completed with errors (bootloader) The response for CMD8 does not match the supplied value (bootloader) Decoded CID fields: (bootloader) Manufacturer ID: 7f (bootloader) OEM ID: 0x0 (bootloader) Product Name: 5270 (bootloader) Product revision: 5.2 (bootloader) Product serial number: B4E (bootloader) Manufacturing date: 2 2015 (bootloader) sdhci_clk_supply: freq 50000000 (bootloader) sdhci_set_bus_width: bus width 1 (bootloader) Done initialization of the card (bootloader) erase_grpsize: 0 (bootloader) erase_grpmult: -1921008668 (bootloader) wp_grpsize: 1 (bootloader) wp_grpen: 1 (bootloader) perm_wp: 0 (bootloader) temp_wp: 0 (bootloader) [Tuxera][Error] No exFAT partition found (bootloader) [JAVACARD_ERR] verify javacard: get signature fail, SW= 6f00 (bootloader) writesecureflag: Permission denied, value 4 OKAY [ 2.577s] finished. total time: 2.579s the problem continues |
05-07-2018, 10:54 | #7 (permalink) |
Member: 2416253 Status: Offline Thanks Meter: 4,162 | Hello, I have checked and I don't see any problem with the clip. However, I have enabled an update for you, so please run XTC 2 Client 1.4 and try to upgrade your clip. |
05-07-2018, 15:44 | #8 (permalink) |
Junior Member Join Date: Feb 2011
Member: 1513960 Status: Offline Thanks Meter: 0 | Hi, I have the same problem. I can not do anything with my xtc 2 clip. neither directly nor in SD mode Sending oem writesecureflag 0 ... (bootloader) SecuritySDInit: counter = 2 (bootloader) a11chl_init_sd, SD card already power on (bootloader) a11chl_init_sd, SD card io already power on (bootloader) sdhci_open: id=0 (bootloader) Initializing MMC host data structure and clock! (bootloader) mmc slot#2 clock enabled (bootloader) clock_config_mmc: slot 2, freq 192000000 (bootloader) GPLL0 is enabled (bootloader) clock_update_cfg_sd is done (bootloader) sd clock set done (bootloader) sdhci_set_bus_width: bus width 0 (bootloader) sdhci_clk_supply: freq 400000 (bootloader) Error: Command never completed (bootloader) Error: Command timeout error (bootloader) Error: Command completed with errors (bootloader) The response for CMD8 does not match the supplied value (bootloader) Decoded CID fields: (bootloader) Manufacturer ID: 7f (bootloader) OEM ID: 0x0 (bootloader) Product Name: 5270 (bootloader) Product revision: 5.2 (bootloader) Product serial number: B4E (bootloader) Manufacturing date: 2 2015 (bootloader) sdhci_clk_supply: freq 50000000 (bootloader) sdhci_set_bus_width: bus width 1 (bootloader) Done initialization of the card (bootloader) erase_grpsize: 991103488 (bootloader) erase_grpmult: 49152 (bootloader) wp_grpsize: 1 (bootloader) wp_grpen: 1 (bootloader) perm_wp: 0 (bootloader) temp_wp: 0 (bootloader) [Tuxera][Error] No exFAT partition found (bootloader) [JAVACARD_ERR] verify javacard: get signature fail, SW= 6f00 (bootloader) writesecureflag: Permission denied, value 4 OKAY Execution time is 3(s) Operation finished mode SD SD init OK Reading config.dat [37]Bytes Read MCCMNC file success Open CID file fail Open IMEI file fail Open atsdeb file fail Reading sf.txt file (1) Bytes Read SF file success Open NAME file fail check keycard failed Process done, reboot device? <VOL UP> Yes please help. that's the way with all the devices |
05-08-2018, 09:42 | #10 (permalink) |
Insane Poster Join Date: Jun 2013
Member: 1953702 Status: Offline Thanks Meter: 3 | (bootloader) SecuritySDInit: counter = 3 (bootloader) m8qlul_init_sd, SD card already power on (bootloader) m8qlul_init_sd, SD card io already power on (bootloader) sdhci_open: id=0 (bootloader) Initializing MMC host data structure and clock! (bootloader) mmc slot#2 clock enabled (bootloader) sdhci_set_clock: slot 2, freq 192000000 (bootloader) GPLL0 is enabled (bootloader) clock_update_cfg_sd is done (bootloader) sd clock set done (bootloader) sdhci_set_bus_width: bus width 0 (bootloader) sdhci_clk_supply: freq 400000 (bootloader) Error: Command never completed (bootloader) Error: Command timeout error (bootloader) Error: Command completed with errors (bootloader) The response for CMD8 does not match the supplied value (bootloader) Decoded CID fields: (bootloader) Manufacturer ID: 7f (bootloader) OEM ID: 0x0 (bootloader) Product Name: 5270 (bootloader) Product revision: 5.2 (bootloader) Product serial number: B4E (bootloader) Manufacturing date: 2 2016 (bootloader) sdhci_clk_supply: freq 50000000 (bootloader) sdhci_set_bus_width: bus width 1 (bootloader) Done initialization of the card (bootloader) erase_grpsize: 0 (bootloader) erase_grpmult: -1921008168 (bootloader) wp_grpsize: 1 (bootloader) wp_grpen: 1 (bootloader) perm_wp: 0 (bootloader) temp_wp: 0 (bootloader) [Tuxera][Error] No exFAT partition found (bootloader) [JAVACARD_ERR] verify javacard: get signature fail, SW= 6f00 (bootloader) writesecureflag: Permission denied, value 4 OKAY pls help me all devices problem |
05-11-2018, 21:41 | #14 (permalink) |
Member: 1513960 Status: Offline Thanks Meter: 0 | I have already sent several private messages to the xtc 2 clip team but they do not answer me. I suspect that they do not reach them because when looking at my message tray I do not have any message sent or received. I already send emails to the support and I have not received a response. can you help me send PM for me? I would greatly appreciate it. I really do not know why they do not answer me. I have several devices by unlock and I could not do them. Help me |
05-12-2018, 07:55 | #15 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: Chandigarh,India Age: 40
Member: 220603 Status: Offline Thanks Meter: 1,164 | Quote:
if no upgrade option appears that means clip upgrade is not required | |
