05-19-2020, 07:31 | #213 (permalink) |
Junior Member Join Date: Oct 2015
Member: 2475802 Status: Offline Thanks Meter: 1 | Has anyone figured out a fix for 1.5? The client installer wont open at all on windows 10 even with Administrator. Ive tried many different things but I can't seem to get working. |
05-19-2020, 14:30 | #214 (permalink) |
Junior Member Join Date: Jan 2013 Location: Europe
Member: 1868789 Status: Offline Thanks Meter: 1 | Connection failed Windows 7 also not working ,Connection to server failed. Connect time out,what solution??? It looks like support has ended for this product |
05-20-2020, 19:16 | #215 (permalink) |
Freak Poster Join Date: Jul 2007 Location: italy
Member: 548901 Status: Offline Sonork: 100.1644756 Thanks Meter: 51 | Help activaction xtc2 Hi team i have buy today and i can't actived and register my box ...give me error connect to server failed connect time out...i have disable firewall and antivirus ...run at administrator but same result... what happened? |
05-21-2020, 19:22 | #217 (permalink) |
No Life Poster Join Date: Feb 2003 Location: Hungary Age: 42
Member: 22902 Status: Offline Sonork: 100.64924 Thanks Meter: 88 | maybe dead product? :( Hi! xtc2clip Last Activity: 03-10-20 21:02 No solution for registering after new windows install, or using other pc... I think thi is dead product... Need solution backup registration process (backup winreg, or somthing like that, to use if need reistall. Like Advance-box, have solution to use with another computer without register server, just need a valid rsa file and edit hdd id change. Have anyone same solution with xtc2clip? Or jutst temporary problem? I don't think is temporary, because "xtc2clip" not active in this forum long time ago.. WBR qwerthj ps: i need change my pc, but i can't use this dongle if i did it |
05-24-2020, 12:56 | #219 (permalink) |
No Life Poster Join Date: Jun 2015
Member: 2416253 Status: Offline Thanks Meter: 4,162 | Dear customers, We apologize for any interruptions of the servers due to co-location provider issues caused by the current situation. The servers are fully working now and are at your service. We really hope you and your families are safe and healthy, please take care. |
05-26-2020, 00:39 | #220 (permalink) |
Member: 2475802 Status: Offline Thanks Meter: 1 | My issue isn't a server issue. Is that the client application literally won't open at all or install on windows 10. You said a long time ago that the issue would looked into but it was never fixed. I've seen many others here have the same problem. |
05-26-2020, 06:10 | #221 (permalink) |
No Life Poster Join Date: Aug 2011 Location: bagmati pradesh
Member: 1626780 Status: Offline Thanks Meter: 1,275 | Starting FRP unlock procedure Phone detected, reading token... Token detected successfully Checking server connection... Communicating with the XTC 2 Clip ... Connecting to the server... Server connection failed server problem help need |
