07-03-2017, 16:34 | #1 (permalink) |
Freak Poster Join Date: Oct 2012
Member: 1825048 Status: Offline Thanks Meter: 10 | htc s9u repair imei faileed for xtc2 [SOLVED] htc s9u repair imei fail phone soff read info: Code: Reading information... Using Fastboot mode... Reading common information (bootloader) kernel: lk (bootloader) product: htc_himar2uhl (bootloader) version: 1.0 (bootloader) imei: 35435407025**** (bootloader) version-main: 2.30.709.2 (bootloader) boot-mode: download (bootloader) version-baseband: READ version-baseband ERROR (bootloader) version-bootloader: 1.01.0000 (bootloader) mid: 2PRG20000 (bootloader) cid: HTC__621 all: Execution time is 8(ms) Reading CID information ... (bootloader) cid: HTC__621 OKAY Execution time is 5(ms) Reading MEID information ... FAILREAD MEID ERROR FAILED (remote: READ MEID ERROR) Execution time is 3(ms) Reading IMEI1 information ... (bootloader) imei: 354354070257459 OKAY Execution time is 3(ms) Reading IMEI2 information ... FAILREAD IMEI2 ERROR FAILED (remote: READ IMEI2 ERROR) Execution time is 4(ms) Reading secure flag information ... (bootloader) Device security level S-OFF OKAY Execution time is 4(ms) Read information completed. write imei error here log Code: Sending oem writeimei 35557705428**** ... FAILWRITE IMEI ERROR FAILED (remote: WRITE IMEI ERROR) Execution time is 4(ms) Operation finished |
04-18-2019, 20:38 | #5 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: Chandigarh,India Age: 40
Member: 220603 Status: Offline Thanks Meter: 1,164 | Quote:
Use direct mode tab for s-off than use special unlock tab for imei repair selecting correct model or m9e or m9plus model | |
04-19-2019, 19:10 | #11 (permalink) |
Freak Poster Join Date: Dec 2015 Location: iran
Member: 2500101 Status: Offline Thanks Meter: 2 | i tried in adapter... 1. Checking phone connectivity....... Phone connection confirmed! Requested card version not detected, version 6 will be used 2. Checking Server connectivity... Server connection confirmed! 3. Checking PowerAdapter connectivity... Process started PowerAdapter connected, processing request to adapter... Starting operation... Sending oem writeimei 35******** ... FAILWRITE IMEI ERROR FAILED (remote: WRITE IMEI ERROR) finished. total time: 0.006s htc_fastboot finished Operation completed! Releasing adapter. Request completed |
04-19-2019, 19:25 | #12 (permalink) | |
No Life Poster Join Date: Jun 2015
Member: 2416253 Status: Offline Thanks Meter: 4,162 | Quote:
If you are stuck on "preparing to work", then to filesystem repair of your clip, copy files again and repeat the process please. | |
The Following User Says Thank You to xtc2clip For This Useful Post: |
04-19-2019, 20:20 | #14 (permalink) | |
PowerAdapter cannot be used with this model, it's rather old. Try to repair FS as I advised and repeat the process please. Also, please INSERT regular smart-card into the XTC 2 Clip, I suppose you may have PowerAdapter connected, this way it wont work. | |
04-20-2019, 18:42 | #15 (permalink) |
Member: 2500101 Status: Offline Thanks Meter: 2 | i wrote 2017imge and unable to fs clip error that 2017img doesnt exist in folder.. any social messenger..what up or...that i can send you the image Last edited by m.hossein; 04-20-2019 at 18:50. |
