Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > xtc2cliP
Old 07-15-2017, 04:28   #76 (permalink)
Member: 2494408
Thanks Meter: 29
Wow. That's awesome work. Any such luck with Sprint M9?
thanks
Old 07-23-2017, 03:22   #77 (permalink)
Member: 2574656
Thanks Meter: 7
I cant!!
When i insert the microsd in the A9, the phone goes into a black screen and nothing happend (waited 20 minutes)...
Then , when i try to flash i got this:
Starting flash process...
target rom version: 1.12.617.6
found large-zip header, file count: 23
processing file 1/23...
sending 'zip' (98140 KB)...
OKAY [ 4.870s]
writing 'zip'...
(bootloader) HOSD CL#747079
(bootloader) ERR Model ID not matched
(bootloader) ERR [SD_UPDATE_ERR] MODEL ID NOT ALLOWED
(bootloader) ERR [SD_UPDATE_ERR] sddownload failed: 10
(bootloader) ERR Update zip file failed.
(bootloader) ERR ZIP ERROR, exit read zip loop
(bootloader) Update zip file OK
(bootloader) ERR ZIP ERROR CODE, 10
(bootloader) [email protected]
FAILED (remote: 10 RU_MODELID_FAIL modelid in android-info mismatched )
finished. total time: 7.330s
Flash process completed.
Flash not successfull, reboot will not be done
Old 07-28-2017, 04:02   #78 (permalink)
Member: 2574656
Thanks Meter: 7
Two days later update:
I had to change the MID in order to flash the european ruu...
XTC Flashed everything but now i have tons of errors:
1.- No Wifi
2.- No Signal
3.- No baseband (and no imei of course)
4.- Lots of reboots
I dont know what else to do... Please help.
Old 07-28-2017, 07:30   #79 (permalink)
Member: 2574656
Thanks Meter: 7
Thanks for nothing XTC!
I finally made it after a lot of research, 7.0 with calls and full data (2/3/4g).
Guys PLEASE dont follow this guide...
Old 08-01-2017, 14:54   #80 (permalink)
Member: 2416253
Thanks Meter: 3,647
Hello!
Sorry for late reply, missed your first post really!!!
If you want to help us & other customers, please send us your xtc2log.txt from clip's drive to Skype or email or PM.
Or contact me on skype: xtc2clip
Old 08-16-2017, 08:33   #81 (permalink)
Mr.3.'s Avatar
Member: 962029
Sonork: OEM Lock : ON
Thanks Meter: 3,859
Originally Posted by maremestera View Post
Pls post solution for 01000000 error or fix your software
got same problem any solution ?
Old 08-16-2017, 14:46   #82 (permalink)
maremestera's Avatar
Member: 691388
Thanks Meter: 284
I did unlocked my phone using version 1.15 witch is the first to support A9 unlock.
It was bug in software. I don't know how it works with latest versions
Old 08-17-2017, 03:30   #83 (permalink)
Mr.3.'s Avatar
Member: 962029
Thanks Meter: 3,859
I already converted 1 phone with latest version but others 2 getting this error
Any help ? .
Old 08-22-2017, 12:49   #84 (permalink)
Member: 2416253
Thanks Meter: 3,647
Any help ? .
01000000 is not related to conversion. Please post log and complete description of what are you trying to do (model, operation, etc).
Old 08-22-2017, 16:00   #85 (permalink)
Mr.3.'s Avatar
Member: 962029
Thanks Meter: 3,859
Don't have log at this moment
This is the model and sane error
Sprint conversion FAQ
Old 08-22-2017, 16:18   #86 (permalink)
Mr.3.'s Avatar
Member: 962029
Thanks Meter: 3,859
What am I getting is AES encryptied error when flashing even noughts version
Old 08-23-2017, 04:04   #87 (permalink)
Member: 1382638
Thanks Meter: 5
Yes, all supported bands should work.
this will enable LTE Band 3 on A9 Sprint?
Old 08-23-2017, 13:07   #88 (permalink)
Member: 2416253
Thanks Meter: 3,647
Because you need to flash partial first.
The Following User Says Thank You to xtc2clip For This Useful Post:
Old 10-14-2017, 12:07   #89 (permalink)
orhan5's Avatar
Member: 2621892
Sonork: 1677742
Thanks Meter: 302
any body help
model id ???? can not see all model id
Old 12-28-2017, 20:14   #90 (permalink)
Member: 715066
htc m7 PN0720000
i want to make a conversion of this model how i can proceed ? my sim card is not recononize ... no signal do i need to change model id?
Page generated in 0.40621 seconds with 7 queries
