04-26-2018, 22:27 | #1 (permalink) |
Junior Member Join Date: Dec 2008
Member: 932400 Status: Offline Thanks Meter: 0 | sprint htc a9 boot loop after conversion [SOLVED] gave error 0000000010 or something like that. So now I can't get to ftm it just boots and then reboots and reboots, etc. Sometimes it will boot to os but has no Wi-Fi and no activation so it hangs at that screen and then will reboot. Please help. I tried flashing using flash tab but give an error for htc-fastboot exe cannot start. And using flash from sim gives signature error for any I've tried. I'm new to xtc clip and HTC device. Please help. |
04-29-2018, 18:07 | #4 (permalink) |
Member: 932400 Status: Offline Thanks Meter: 0 | still same issue. files to clip succeeded eject flip from pc insert FTM mode 2 yellow lines across top of screen phone reboot sprint animated splash htc one powered by android animated splash solid htc screen reboot and loop Reading information... Using Fastboot mode... Reading common information (bootloader) kernel: lk (bootloader) product: htc_hiaewhl (bootloader) version: 1.0 (bootloader) max-download-size: 1164800000 (bootloader) serialno: HT5BLSZ01265 (bootloader) slot-count: 0 (bootloader) current-slot: (bootloader) imei: 9900057063xxxxx (bootloader) version-main: 2.18.651.2 (bootloader) boot-mode: download (bootloader) version-baseband: 1.1.C40062.1 at 61213 (bootloader) version-bootloader: 1.0.0.0000 (bootloader) mid: 2PQ912000 (bootloader) cid: 11111111 all: Execution time is 0(ms) Reading CID information ... (bootloader) cid: 11111111 OKAY Execution time is 62(ms) Reading MEID information ... (bootloader) meid: 9900057063xxxx OKAY Execution time is 0(ms) Reading IMEI1 information ... (bootloader) imei: 9900057063xxxxx OKAY Execution time is 15(ms) Reading IMEI2 information ... (bootloader) imei2: OKAY Execution time is 0(ms) Reading secure flag information ... (bootloader) Device security level S-OFF OKAY Execution time is 0(ms) Reading serial number information ... (bootloader) Device Serial No. is HT5BLSZ01265 OKAY Execution time is 15(ms) Read information completed. |
05-01-2018, 07:31 | #8 (permalink) | ||
No Life Poster Join Date: Jan 2006 Location: Chandigarh,India Age: 40
Member: 220603 Status: Offline Thanks Meter: 1,164 | Quote:
this must be windows problem Quote:
if flashing doesn't start with xtc2clip software try command prompt method you can contact me on skype (GMT+5.30) | ||
05-28-2018, 02:57 | #9 (permalink) | |
Member: 932400 Status: Offline Thanks Meter: 0 | Quote:
please explain better as I don't understand. I use clip to change phone MID to 2pq91200? then I use command prompt with fastbootexe to flash 516025 from support? what is the command line? I am sorry, I do not have skype. | |
05-28-2018, 08:13 | #10 (permalink) | |
05-28-2018, 13:25 | #11 (permalink) |
Member: 932400 Status: Offline Thanks Meter: 0 | downloaded file, change name to att,zip CONNECT PHONE FASTBOOT USE CLIP TO REBOOT RUU C:\Users\welfa\Documents\fastboot-win>fastboot flash zip att,zip target reported max download size of 1164800000 bytes Invalid sparse file format at header magic error: write_sparse_skip_chunk: don't care size 885791028 is not a multiple of the block size 4096 sending sparse 'zip' 1/2 (1048572 KB)... error: write_sparse_skip_chunk: don't care size 885791028 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 885791028 is not a multiple of the block size 4096 OKAY [ 45.299s] writing 'zip' 1/2... (bootloader) HOSD CL#861755 (bootloader) ERR lzipv2_init : Cannot open file /dev/fastboot_download_x (bootloader) JMpV2 (bootloader) ERR [SD_UPDATE_ERR] update_fb_ZIP_buf: can not find ZIP hea (bootloader) der (bootloader) ERR [SD_UPDATE_ERR] sddownload failed: 22 (bootloader) ERR Update zip file failed. (bootloader) ERR ZIP ERROR, exit read zip loop (bootloader) Update zip file OK (bootloader) ERR ZIP ERROR CODE, 22 (bootloader) endDone FAILED (remote: 22 RU_HEADER_ERROR ) finished. total time: 47. 456s phone reboot and boot loop |
05-28-2018, 15:19 | #13 (permalink) |
Member: 932400 Status: Offline Thanks Meter: 0 | I did this, with same result C:\Users\welfa\Documents\fastboot-win>fastboot flash zip 2PQ9IMG,ZIP target reported max download size of 1164800000 bytes Invalid sparse file format at header magic error: write_sparse_skip_chunk: don't care size 885791028 is not a multiple of the block size 4096 sending sparse 'zip' 1/2 (1048572 KB)... error: write_sparse_skip_chunk: don't care size 885791028 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 885791028 is not a multiple of the block size 4096 OKAY [ 45.440s] writing 'zip' 1/2... (bootloader) HOSD CL#861755 (bootloader) ERR lzipv2_init : Cannot open file /dev/fastboot_download_V (bootloader) DGyts (bootloader) ERR [SD_UPDATE_ERR] update_fb_ZIP_buf: can not find ZIP hea (bootloader) der (bootloader) ERR [SD_UPDATE_ERR] sddownload failed: 22 (bootloader) ERR Update zip file failed. (bootloader) ERR ZIP ERROR, exit read zip loop (bootloader) Update zip file OK (bootloader) ERR ZIP ERROR CODE, 22 (bootloader) end Done FAILED (remote: 22 RU_HEADER_ERROR ) finished. total time: 47. 565s |
