10-18-2016, 10:46 | #3 (permalink) | |
No Life Poster Join Date: Jun 2015
Member: 2416253 Status: Offline Thanks Meter: 4,162 | Quote:
Yesterday, 08:32 24 hours? Sorry, sometimes we have to sleep! Did you try to read our guides? Or use search? This, for examaple: http://forum.gsmhosting.com/vbb/f961...-step-1964502/ | |
10-18-2016, 23:33 | #4 (permalink) |
Junior Member Join Date: Oct 2016
Member: 2637743 Status: Offline Thanks Meter: 0 | Hi xtc2clip I tried many times SD mode editor , saving files successfully but when i select sim lock message said SD init ok open MCCMNC file fail open CID file fail open IMEI file fail open atsdeb file fail open SF file fail open NAME faile fail check keycard failed process done , reboot device ! (vol up ) Yes |
10-19-2016, 09:29 | #5 (permalink) | |
Please do this: http://forum.gsmhosting.com/vbb/f961...t-etc-1964648/ and repeat unlock procedure. | |
10-20-2016, 00:07 | #6 (permalink) |
Member: 2637743 Status: Offline Thanks Meter: 0 | I did 1- unlocked bootloader 2-s-off 3-change cid to super cid 4-chang nv only to ruimonly. after all sim card is not working what should i do next !! This is my phone information : Reading information... Using Fastboot mode... Reading common information (bootloader) version: 0.5 (bootloader) version-bootloader: 3.19.0.0000 (bootloader) version-baseband: 1.09.20.0209 (bootloader) version-cpld: None (bootloader) version-microp: None (bootloader) version-main: 2.32.651.11 (bootloader) version-misc: PVT SHIP S-OFF (bootloader) serialno: FA47ZSP01423 (bootloader) imei: 990004298943626 (bootloader) imei2: Not Support (bootloader) meid: 99000429894362 (bootloader) product: mec_whl (bootloader) platform: hTCBmsm8974 (bootloader) modelid: 0PAJ50000 (bootloader) cidnum: 11111111 (bootloader) battery-status: good (bootloader) battery-voltage: 0mV (bootloader) partition-layout: Generic (bootloader) security: off (bootloader) build-mode: SHIP (bootloader) boot-mode: FASTBOOT (bootloader) commitno-bootloader: d0c41a5b (bootloader) hbootpreupdate: 11 (bootloader) gencheckpt: 0 |
10-20-2016, 20:45 | #8 (permalink) |
Member: 2637743 Status: Offline Thanks Meter: 0 | In sprint tape i got spc then entered spc and diag enabled but no com port appears, in spite of com port not appearing in xtc 2 clip software the diagnostics com port appears in DFS software !! |
10-28-2016, 00:14 | #13 (permalink) |
No Life Poster Join Date: Apr 2010 Location: NYC/USA
Member: 1283129 Status: Offline Thanks Meter: 135 | I found this because I was stuck on the same exact step (com port blank unlocking sprint m8) solution........click refresh button next to com =) |
The Following User Says Thank You to cafonabob1 For This Useful Post: |
10-28-2016, 07:14 | #14 (permalink) |
Freak Poster Join Date: Dec 2015
Member: 2502617 Status: Offline Thanks Meter: 42 | Also you need to have admin rights for .exe so that xtc2clip can detect com ports. ->right click exe / properties / Compatibility , then thick "Run this program as an administrator". Problem solved |
The Following 3 Users Say Thank You to beckam_laci For This Useful Post: |
03-19-2017, 17:18 | #15 (permalink) | |
Junior Member Join Date: Mar 2017
Member: 2697090 Status: Offline Thanks Meter: 0 | Quote:
