-   xtc2cliP (http://forum.gsmhosting.com/vbb/f961/)
-   -   Success stories :) (http://forum.gsmhosting.com/vbb/f961/success-stories-1964667/)
Farzad.m 07-26-2015 17:50
Desire 300 S-off & Super CID Done;)
http://www.pars-gsm.com/picup.php?fi...sire%20300.jpg
http://www.pars-gsm.com/picup.php?fi...re%20300_2.jpg
M7_UL S-off & Super CID Done;)
http://www.pars-gsm.com/picup.php?fi...9967_M7_UL.jpg
M7_U S-off & Super CID Done;)
http://www.pars-gsm.com/picup.php?fi...9_M7_U%202.jpg
http://www.pars-gsm.com/picup.php?fi...01638_M7_U.jpg
Thanks For Your Great Tool
UNKNOWN GSM 07-26-2015 19:45
Originally Posted by Farzad.m (Post 11186854)
Wow farzad
I thing this amazing tool was the best of my suggestion to you ;)
Luv xtc2clip
Luv u my freind
Farzad.m 07-26-2015 21:05
Originally Posted by UNKNOWN GSM (Post 11186976)
Wow farzad
I think this amazing tool was the best of my suggestion to you ;)
Luv xtc2clip
Luv u my freind
yes it's true my Freind:cool::cool:
G4N0K 07-26-2015 21:51
HTC One M9 - HIMA_UHL - Security Mode: S-DEB
Successfully S-OFFed and changed security flag from S-DEB to S-OFF on HTC One M9 - HIMA_UHL Using XTC2Clip Using Direct Mode XTC2CLIP v1.05.
THIS IS THE ONE AND ONLY TOOL YOU WILL NEED FOR HTC.
BEFORE:
http://i.cubeupload.com/Uecd5n.jpg
AFTER:
Reading information...
Using Fastboot mode...
Reading common information
(bootloader) kernel: lk
(bootloader) product: htc_himauhl
(bootloader) version: 1.0
(bootloader) imei: XXXXXXXXXXXXXXXX
(bootloader) version-main: 1.40.401.5
(bootloader) boot-mode: RUU
(bootloader) version-bootloader: 1.0.0.0000
(bootloader) mid: 0PJA10000
(bootloader) cid: 11111111
Execution time is 15(ms)
all:
Reading secure flag information
... (bootloader) Device security level S-OFF
OKAY
Reading CID information
... (bootloader) cid: 11111111
Execution time is 0(ms)
OKAY
Read information completed.
Faheem Anjum 07-27-2015 12:37
HTC M7_UL
S-off done
cid Done
http://s12.postimg.org/8fm5ggcnt/20110101_034120.jpg
http://s12.postimg.org/5pctj9fyx/20110101_034142.jpg
http://s12.postimg.org/stdabuja1/20110101_034210.jpg
xyzgsm1 07-27-2015 13:13
htc one .. Great Work..
Max1288 07-27-2015 19:53
I just want to know .. someone else know how to change the word in the pink part?
Farzad.m 07-28-2015 09:05
wildfire s s-off & super cid done
http://www.pars-gsm.com/picup.php?fi...ldfire%20s.jpg
http://www.pars-gsm.com/picup.php?fi...re%20s%202.jpg
allumts 07-28-2015 10:53
@Farzad.m,
if you Upload Immage in this site only one 5% can see you photo, no one photo you has posted is visible...so or try to change site or is useless you post "Success Story"....
allumts
hm.faizan 07-28-2015 13:45
htc j butterfly s-off and super cid done
(bootloader) version: 0.5
(bootloader) version-bootloader: 1.41.0000
(bootloader) version-baseband: 1.01.12.1122
(bootloader) version-cpld: None
(bootloader) version-microp: None
(bootloader) version-main: 1.39.970.3
(bootloader) version-misc: PVT SHIP S-OFF
(bootloader) serialno: FA2C1S509371
(bootloader) imei: 990000664439751
(bootloader) meid: 99000066443975
(bootloader) product: deluxe_j
(bootloader) platform: HBOOT-8064
(bootloader) modelid: PL9910000
(bootloader) cidnum: 11111111
(bootloader) battery-status: good
(bootloader) battery-voltage: 3746mV
(bootloader) partition-layout: Generic
(bootloader) security: off
(bootloader) build-mode: SHIP
(bootloader) boot-mode: FASTBOOT
(bootloader) commitno-bootloader: 7860e302
(bootloader) hbootpreupdate: 11
(bootloader) gencheckpt: 0
Execution time is 60(ms)
all: Done!
8064 detected, reading IMEI2 ...
... (bootloader) [ERR] Command error !!!
Execution time is 20(ms)
OKAY
... (bootloader) secure_flag: 0
Execution time is 10(ms)
OKAY
OKAY
Phone DISconnected
hm.faizan 07-28-2015 17:17
M7_WLS s-off supercid done
(bootloader) version-bootloader: 1.57.0000
(bootloader) version-baseband: 1.01.20.0904_2
(bootloader) version-main: 5.05.651.2
(bootloader) serialno: FA43WS904748
(bootloader) imei: 990004288931896
(bootloader) meid: 99000428893189
(bootloader) product: m7_wls
(bootloader) modelid: PN0720000
(bootloader) battery-voltage: 3803mV
(bootloader) commitno-bootloader: dirty-0e1af350
Execution time is 80(ms)
all: Done!
OKAY
OKAY
OKAY
UNKNOWN GSM 07-29-2015 17:20
http://forum.gsmhosting.com/vbb/atta...1&d=1438186672
Sending oem writesecureflag 0
... (bootloader) SecuritySDInit: counter = 2
(bootloader)  a5dwg_init_sd, SD card already power on
(bootloader)  a5dwg_init_sd, SD card io already power on
(bootloader) sdhci_open: id=0
(bootloader)  Initializing MMC host data structure and clock!
(bootloader) mmc slot#2 clock enabled
(bootloader) clock_config_mmc: slot 2, freq 192000000
(bootloader) GPLL0 is enabled
(bootloader) clock_update_cfg_sd is done
(bootloader) sd clock set done
(bootloader) sdhci_set_bus_width: bus width 0
(bootloader) sdhci_clk_supply: freq 400000
(bootloader) Error: Command never completed
(bootloader) Error: Command timeout error
(bootloader) Error: Command completed with errors
(bootloader) The response for CMD8 does not match the supplied value
(bootloader) Decoded CID fields:
(bootloader) Manufacturer ID: 7f
(bootloader) OEM ID: 0x0
(bootloader) Product Name: 5270
(bootloader) Product revision: 5.2
(bootloader) Product serial number: B4E
(bootloader) Manufacturing date: 2 2015
(bootloader) sdhci_clk_supply: freq 50000000
(bootloader) Decoded CSD fields:
(bootloader) cmmc_structure: 0
(bootloader) card_cmd_class: 5f5
(bootloader) write_blk_len: 512
(bootloader) read_blk_len: 512
(bootloader) r2w_factor: 4
(bootloader) sector_size: 128
(bootloader) c_size_mult:2
(bootloader) c_size: 506
(bootloader) nsac_clk_cycle: 100
(bootloader) taac_ns: 70000
(bootloader) tran_speed: 26000 kbps
(bootloader) erase_blk_len: 0
(bootloader) read_blk_misalign: 0
(bootloader) write_blk_misalign: 0
(bootloader) read_blk_partial: 1
(bootloader) write_blk_partial: 0
(bootloader) Card Capacity: 4153344 Bytes
(bootloader) sdhci_set_bus_width: bus width 1
(bootloader) Done initialization of the card
(bootloader) erase_grpsize: 49152
(bootloader) erase_grpmult: 257351520
(bootloader) wp_grpsize: 1
(bootloader) wp_grpen: 1
(bootloader) perm_wp: 0
(bootloader) temp_wp: 0
(bootloader) [Tuxera][Error] No exFAT partition found
(bootloader) writesecureflag: KeyCard remain count 10000
(bootloader) PID:297
(bootloader) Start Verify: 3
(bootloader) [PGFS] partition_update_pgfs: pg1fs_security
Execution time is 4187(ms)
OKAY
Operation finished
Sending oem writecid 11111111
... (bootloader) Start Verify: 0
(bootloader) Input CID is super CID
OKAY
Operation finished
(bootloader) version-bootloader: 3.19.0.0000
(bootloader) version-baseband: 1.13.3230.16.05
(bootloader) version-main: 1.56.401.1
(bootloader) serialno: FA44RWW00596
(bootloader) imei: 352706060391253
(bootloader) imei2: 352706060391261
(bootloader) meid: 00000000000000
(bootloader) product: a5_dug
(bootloader) platform: hTCBmsm8226
(bootloader) modelid: 0P9C70000
(bootloader) battery-voltage: 0mV
(bootloader) commitno-bootloader: 5534924e
all: Done!
OKAY
OKAY
trenac 07-30-2015 18:52
htc desire 510 unlock ok just 20 second neded for operation
http://i61.tinypic.com/9v86ip.png
abdelbassir 08-03-2015 14:24
http://www.4shared.com/download/1a4t....jpg?lgfp=3000
Kiyan1391 08-03-2015 21:35
tnx good
goooooooooooooooooooooood dongle
Page generated in 0.30859 seconds with 6 queries
