-   xtc2cliP (http://forum.gsmhosting.com/vbb/f961/)
-   -   Success stories :) (http://forum.gsmhosting.com/vbb/f961/success-stories-1964667/)
.:Abdul-Basit:. 09-17-2015 17:35
HTC Explorer (Pico) S-OFF & SUPER CID DONE
HTC Explorer (Pico) S-OFF & SUPER CID DONE With Direct Mode
1: Just Insert Clip Flex Inside SD Slot
2: Put Phone in Fastboot Mode
3: Open Exe Go To Direct Mode & Change What You Wanna Do :)
see pics below for more details you can contact me @ skype : kbgsmlab
http://i1119.photobucket.com/albums/...pskn6cykqp.jpg
http://i1119.photobucket.com/albums/...psa1svtyr2.png
http://i1119.photobucket.com/albums/...psv539xacl.jpg
sunshine4u 09-18-2015 09:21
HTC DESIRE 500 STUCKED AT LOGO DONE BY S-OFF WRITING SUPER CID AND FLASHED WITH RUU
http://i62.tinypic.com/2due983.jpg
http://i57.tinypic.com/aylnxw.jpg
http://i58.tinypic.com/28iu4aq.jpg
mobile_hotman 09-20-2015 07:22
1 Attachment(s)
I unlocked My HTC_ONE_M7 from UK successfully,,,,But one set from Jappan not done...even i did S-OFF & Changed CID successfully but still no service where do i wrong ???
xtc2clip 09-24-2015 10:15
Hello!
Please don't use this thread to report problem or ask questions, it's not frequently monitored.
As to your question - your phone is HTV21, which will be supported in next release.
allumts 09-24-2015 11:13
This issue of @sunshine4u, post #92 is same issue that have damaged one HTC one S, after S-OFF+Supercid phone Stuck in Logo....flashed other FW with success but always phone damaged...what happen???
Time ago i've thinked was only one my problem, but now seeing other HTC with same issue i'm a little worried....Phones was working 100% first of this S-OFF and Supercid...please ceck where's Bug becouse i've also changed Touch and ceck Hw side and is all ok.
allumts
xtc2clip 09-24-2015 12:47
allumts
I believe that sinshine4u wrote that he repaired phone stuck at logo by "super cid and flashing with RUU" ...
allumts 09-24-2015 13:11
Ops sorry, my mystake reading speed...sorry but is that when i not get out of my shop only one phone NOT Repaired i'm angry...anyway all other are benn managed with success...only this cannot understand...
allumts
mex27m 09-30-2015 01:00
:DHtc desire 626s is done. :)
galijus 10-13-2015 15:22
Htc M8S unlock success
http://i59.tinypic.com/x1mvwg.jpg
lovelyboy 10-30-2015 14:52
HTC One Max Sprint Unlock Done
solution HTC One Max SPRINT UNLOCK (only work with S-OFF)
1) go to the tab "SD mode editor" enable new sec (Security S-OFF).
2) click save to driver.
3) disable S-ON with cable Y and XTC2CLIP
4) once deactivated S-ON go to the tab "SPRINT"
5) Please connect phone in FASTBOOT (vol_down + pwr)
6) click GET SPC Code
7) when you have the SPC click OS
8) enable mode adb
9) go dial write ##3424#, select DM ON
10) click refresh, select port diag
11) click unlock
12) restart the phone
Trying to connect in Sprint mode...
Trying to connect on COM91
Checking server connection...
Communicating with the XTC 2 Clip ...
Connecting to the server...
Please wait, generating unlock hash...
Process finished SUCCESSFULLY
Please restart your phone for the changes to take effect
Phone DISconnected
samkozi 10-31-2015 22:15
htc desire x unlock and s-off
http://postimg.org/image/8ilgxigqp/
allumts 11-01-2015 13:28
HTC M8 S-OFF + SUPERCID+ IMEI REPAIRED ONLY 3 MIN.s in DIRECT MODE, SUCCESS :)
(sorry Bad quality Photo)
XTC2CLIP Connetcted Directly in Sd Card Slot and Phone to Pc
http://i1366.photobucket.com/albums/...psuvfkmqvk.jpg
Procedure with Xtc2Clip with Phone in "Bootloader first"
http://i1366.photobucket.com/albums/...psyenh1qg4.jpg
HERE RESULT OF FULL PROCEDURE IN M8, IMPORTANT: PHONE HAVE LEAVED OFFICIAL, so Receive Update itc... ;)
http://i1366.photobucket.com/albums/...ps455u14c1.jpg
allumts
Faheem Anjum 11-02-2015 13:38
htc One Unlock Super Cid Done!!!!!
nevada1960 11-04-2015 10:51
Thanks for the quick response. My two clips work again. Super servis for Xtc2clip. Thanks again to xtc2clip Product Manager.
kanokh 11-12-2015 07:22
HTC 610 S-Off OKAY
HTC 610 S-Off writesecureflag 0 OKAY
Sending oem writesecureflag 0
... (bootloader) SecuritySDInit: counter = 3
(bootloader) a3ul_init_sd, SD card already power on
(bootloader) a3ul_init_sd, SD card io already power on
(bootloader) a3ul_init_sd: SKU AHD#1 or AHD#2
(bootloader) sdhw_7xxx_open: id=0
(bootloader) clock_update_cfg_sd is done
(bootloader) sd clock set done
(bootloader) [DEBUG] Cmd8 polling status timed out, MCI_STATUS: 0xC0000
(bootloader) [DEBUG] sdcc_command: sdcc_poll_status error, rc: 2
(bootloader) sdcc_init_memory_device done
(bootloader) SD clock freq = 19MHz....
(bootloader) GPLL0 is enabled
(bootloader) [Tuxera][Error] No exFAT partition found
(bootloader) writesecureflag: KeyCard remain count 10000
(bootloader) PID:306
(bootloader) Start Verify: 3
(bootloader) [PGFS] partition_update_pgfs: pg1fs_security
Execution time is 3177(ms)
OKAY
Operation finished
Page generated in 0.26122 seconds with 5 queries
