-   xtc2cliP (http://forum.gsmhosting.com/vbb/f961/)
-   -   Success stories :) (http://forum.gsmhosting.com/vbb/f961/success-stories-1964667/)
zagalo2 12-04-2015 11:37
htc one m9 FRP protection
Removing FRP protection
Rebooting to bootloader mode...
Phone DISconnected
Phone connected [FA591YJ00755] *** Fastboot mode
Phone is S-OFF
SUCCESS. FRP protection was removed
Phone DISconnected
Phone connected [FA591YJ00755] *** ADB mode
kanokh 12-06-2015 11:00
HTC M8 (M8_UL) S-Off super CID
Information...
Reading information...
Using Fastboot mode...
Reading common information
(bootloader) version: 0.5
(bootloader) version-bootloader: 3.19.0.0000
(bootloader) version-baseband: 1.25.21331147A1.06G
(bootloader) version-cpld: None
(bootloader) version-microp: None
(bootloader) version-main: 4.19.707.4
(bootloader) version-misc: PVT SHIP S-ON
(bootloader) serialno: SH43ZWM00344
(bootloader) imei: 358716055148240
(bootloader) imei2: Not Support
(bootloader) meid: 00000000000000
(bootloader) product: m8_ul
(bootloader) platform: hTCBmsm8974
(bootloader) modelid: 0P6B11000
(bootloader) cidnum: HTC__044
(bootloader) battery-status: good
(bootloader) battery-voltage: 0mV
(bootloader) partition-layout: Generic
(bootloader) security: on
(bootloader) build-mode: SHIP
(bootloader) boot-mode: FASTBOOT
(bootloader) commitno-bootloader: 28eb9285
(bootloader) hbootpreupdate: 11
(bootloader) gencheckpt: 0
Execution time is 10(ms)
all: Done!
Reading secure flag information
... (bootloader) secure_flag: 3
Execution time is 3(ms)
OKAY
Reading CID information
... (bootloader) cid: HTC__044
Execution time is 4(ms)
OKAY
Reading MEID information
... (bootloader) meid: 00000000000000
OKAY
Read information completed.
S-Off
Sending oem writesecureflag 0
... (bootloader) SecuritySDInit: counter = 3
(bootloader) m8_init_sd, SD card already power on
(bootloader) [SPEW] GPIO 0 status is 0
(bootloader) sdhci_open: id=0
(bootloader) Initializing MMC host data structure and clock!
(bootloader) mmc slot#2 clock enabled
(bootloader) sdhci_set_clock: slot 2, freq 192000000
(bootloader) GPLL0 is enabled
(bootloader) clock_update_cfg_sd is done
(bootloader) sd clock set done
(bootloader) sdhci_set_bus_width: bus width 0
(bootloader) sdhci_clk_supply: freq 400000
(bootloader) Error: Command never completed
(bootloader) Error: Command timeout error
(bootloader) Error: Command completed with errors
(bootloader) The response for CMD8 does not match the supplied value
(bootloader) Decoded CID fields:
(bootloader) Manufacturer ID: 7f
(bootloader) OEM ID: 0x0
(bootloader) Product Name: 5270
(bootloader) Product revision: 5.2
(bootloader) Product serial number: B4E
(bootloader) Manufacturing date: 2 2015
(bootloader) sdhci_clk_supply: freq 50000000
(bootloader) sdhci_set_bus_width: bus width 1
(bootloader) Done initialization of the card
(bootloader) erase_grpsize: -16777216
(bootloader) erase_grpmult: 261078256
(bootloader) wp_grpsize: 1
(bootloader) wp_grpen: 1
(bootloader) perm_wp: 0
(bootloader) temp_wp: 0
(bootloader) [Tuxera][Error] No exFAT partition found
(bootloader) writesecureflag: KeyCard remain count 10000
(bootloader) PID:272
(bootloader) Start Verify: 3
(bootloader) [PGFS] partition_update_pgfs: pg1fs_security
(bootloader) TZ_HTC_SVC_ENC ret = 0
(bootloader) [PGFS] partition_update_pgfs: pg2fs_sec_recovery
Operation finished
super CID
Sending oem writecid 11111111
... (bootloader) Start Verify: 0
(bootloader) Input CID is super CID
Execution time is 29(ms)
OKAY
Operation finished
kanokh 12-13-2015 07:24
HTC 816 S-OFF
information...
(bootloader) version-bootloader: 3.18.0.0000
(bootloader) version-baseband: 1.13.3230.16.05
(bootloader) serialno: HC46TWW07609
(bootloader) imei: 352246067140072
(bootloader) imei2: 352246067140080
(bootloader) product: a5_dug
(bootloader) platform: hTCBmsm8226
(bootloader) modelid: 0P9C70000
(bootloader) cidnum: HTCCN703
(bootloader) commitno-bootloader: 2351d84b
all: Done!
OKAY
... (bootloader) cid: HTCCN703
OKAY
OKAY
S-OFF
(bootloader) a5dwg_init_sd, SD card already power on
(bootloader) a5dwg_init_sd, SD card io already power on
(bootloader) sdhw_7xxx_open: id=0
(bootloader) [DEBUG] Cmd8 polling status timed out, MCI_STATUS: 0xC0000
(bootloader) [DEBUG] sdcc_command: sdcc_poll_status error, rc: 2
(bootloader) sdcc_init_memory_device done
(bootloader) SD clock freq = 19MHz....
(bootloader) PID:297
Execution time is 3163(ms)
OKAY
Operation finished
super cid
Execution time is 28(ms)
OKAY
Operation finished
kanokh 12-13-2015 08:02
BOOTLODER UNLOCK
Starting bootloader unlock procedure
Phone detected, reading token...
Token detected successfully
Checking server connection...
Communicating with the XTC 2 Clip ...
Connecting to the server...
Waiting for the server to process request, it may take up to 5 minutes...
Your request was processed successfully! Unlock token has been obtained
Sending flash unlocktoken unlocktoken_HC46TWW07609.bin
sending 'unlocktoken' (0 KB)... OKAY
writing 'unlocktoken'... (bootloader) unlock token check successfully
Execution time is 130(ms)
OKAY
Please continue the unlock process on your phone.
Phone DISconnected
kanokh 12-13-2015 08:15
HTC 820u S-OFF Super CID
(bootloader) a51dtul_init_sd, SD card already power on
(bootloader) a51dtul_init_sd, SD card io already power on
(bootloader) erase_grpsize: 3
(bootloader) erase_grpmult: -1921008652
(bootloader) PID:344
Execution time is 4125(ms)
OKAY
Operation finished
Execution time is 17(ms)
OKAY
Operation finished
kanokh 12-13-2015 13:10
HTC 820u Soff CID Operation finished
Operation finished
Execution time is 18(ms)
OKAY
Operation finished
kanokh 12-16-2015 08:36
HTC M8 (M8-UL) S-Off Super CID BY XTC2
(bootloader) version-bootloader: 3.16.0.0000
(bootloader) version-baseband: 1.15.2133156.UA13G
(bootloader) serialno: FA459WM02045
(bootloader) imei: 358714051296964
(bootloader) modelid: 0P6B10000
(bootloader) cidnum: ORANG001
(bootloader) commitno-bootloader: ab0efa49
Execution time is 8(ms)
all: Done!
OKAY
... (bootloader) cid: ORANG001
OKAY
OKAY
S-Off
Execution time is 3167(ms)
OKAY
Operation finished
Write CID
OKAY
Operation finished
elvi806 12-16-2015 09:41
Good box, i have unlocked two HTC 510 and one HTC m8 sprint HK version. Very fast and clear instructions. My only challenge with the M8 is its only working on GSM mode which is very slow. i have tried to set it on WCDMA preffered but when i go to Mobile network only GSM/UTMS is available.
http://s2.postimg.org/qse5tgwtl/2_CF...9_D6118670.jpg
misisipiman 12-16-2015 20:36
I have unlocked the d820n without any problems in less than five minutes great box.
Sent from my HTC_D820u using Tapatalk
kanokh 12-23-2015 14:12
HTC Desire U (T327D) S-Off CID
... (bootloader) readsecureflag: secure flag: ON
(bootloader) writesecureflag: keycard remain count 10000
(bootloader) AMSS is ready
(bootloader) buf_addr:2EE204,buf_size:200,start_sector:173A1
(bootloader) [PROCCOMM] config gpio#88 to 0x0 failed (8)!!
(bootloader) [PROCCOMM] config gpio#89 to 0x0 failed (8)!!
(bootloader) [PROCCOMM] config gpio#19 to 0x0 failed (8)!!
(bootloader) [PROCCOMM] config gpio#20 to 0x0 failed (8)!!
(bootloader) [PROCCOMM] config gpio#21 to 0x0 failed (8)!!
(bootloader) [PROCCOMM] config gpio#108 to 0x0 failed (8)!!
(bootloader) [PROCCOMM] config gpio#90 to 0x0 failed (8)!!
(bootloader) [PROCCOMM] config gpio#91 to 0x0 failed (8)!!
(bootloader) [PROCCOMM] config gpio#92 to 0x0 failed (8)!!
(bootloader) [PROCCOMM] config gpio#93 to 0x0 failed (8)!!
(bootloader) HWIO_SDC1_MD_REG_ADDR=0xA86000A0
(bootloader) HWIO_SDC1_NS_REG_ADDR=0xA86000A4
(bootloader) HWIO_SDC3_MD_REG_ADDR=0xA86000B0
(bootloader) HWIO_SDC3_NS_REG_ADDR=0xA86000B4
(bootloader) phys_to_virt(HWIO_SDC1_MD_REG_ADDR)=0xD32000A0
(bootloader) phys_to_virt(HWIO_SDC1_NS_REG_ADDR)=0xD32000A4
(bootloader) phys_to_virt(HWIO_SDC3_MD_REG_ADDR)=0xD32000B0
(bootloader) phys_to_virt(HWIO_SDC3_NS_REG_ADDR)=0xD32000B4
(bootloader) [PROCCOMM] config gpio#88 to 0x1C4 failed (8)!!
(bootloader) [PROCCOMM] config gpio#89 to 0x147 failed (8)!!
(bootloader) [PROCCOMM] config gpio#90 to 0x147 failed (8)!!
(bootloader) [PROCCOMM] config gpio#91 to 0x147 failed (8)!!
(bootloader) [PROCCOMM] config gpio#92 to 0x147 failed (8)!!
(bootloader) [PROCCOMM] config gpio#93 to 0x147 failed (8)!!
(bootloader) [PROCCOMM] config gpio#19 to 0x14F failed (8)!!
(bootloader) [PROCCOMM] config gpio#20 to 0x14F failed (8)!!
(bootloader) [PROCCOMM] config gpio#21 to 0x14F failed (8)!!
(bootloader) [PROCCOMM] config gpio#108 to 0x14F failed (8)!!
(bootloader) [ERR] Cmd5 polling status timed out, MCI_STATUS: 0x0
(bootloader) [ERR] sdcc_command: sdcc_poll_status error, rc: 2
(bootloader) [ERR] Cmd8 polling status timed out, MCI_STATUS: 0x0
(bootloader) [ERR] Cmd55 polling status timed out, MCI_STATUS: 0x0
(bootloader) Finish write sector address 173A1 ...
(bootloader) writesecureflag: set security flag off successfully
Execution time is 23036(ms)
OKAY
Operation finished
... (bootloader) cid: HTC__038
OKAY
OKAY
... (bootloader) tjHTCE
(bootloader) Done!
(bootloader) sdc_ns_reg value=0xFF9E0B58
(bootloader) sdc_ns_reg value=0xFE2B0B5A
(bootloader) Wait for AMSS ready
(bootloader) buf_addr:2FC300,buf_size:200,start_sector:1739D
(bootloader) Finish write sector address 1739D ...
(bootloader) writecid: successfully
Execution time is 22262(ms)
OKAY
Operation finished
iPhoneUnlocke 12-27-2015 06:50
Today Unlock Done HTC M9 Sprint
iPhoneUnlocke 12-27-2015 07:50
Another HTC A9 Sprint Unlock Done
CANNYCOMPUTERS 12-27-2015 16:51
HTC D626X S-OFF DONE
(bootloader) a32dcgl_init_sd, SD card already power on
(bootloader) a32dcgl_init_sd, SD card io already power on
(bootloader) erase_grpsize: -1921008425
(bootloader) erase_grpmult: -1921008452
(bootloader) PID:381
Execution time is 4231(ms)
OKAY
Operation finished
allumts 12-29-2015 19:30
HTC DESIRE 820n S-OFF+SUPERCID DONE !!!!
S-OFF + SuperCID:
Execution time is 30(ms)
OKAY
Operation finished
... (bootloader) [PGFS] partition_update_pgfs: pg1fs_security
Execution time is 90(ms)
OKAY
Operation finished
(bootloader) version-baseband: 01.01.010_U10305041_08.01.41222_2
(bootloader) version-main: 1.28.73.2
(bootloader) version-misc: PVT SHIP S-OFF
(bootloader) serialno: HTXXXXXX
(bootloader) imei: 3XXXXXXXXXX
(bootloader) product: a51_ul
(bootloader) platform: hTCBmsm8939
(bootloader) modelid: 0PFJ40000
(bootloader) cidnum: 11111111
(bootloader) security: off
(bootloader) commitno-bootloader: eae94f74
(bootloader) mfg-name: 0001
Execution time is 20(ms)
all: Done!
... (bootloader) secure_flag: 0
OKAY
... (bootloader) cid: 11111111
OKAY
OKAY
http://i1366.photobucket.com/albums/...psfwqq4kuq.jpg
All INFO IN ADB MODE
Using ADB mode...
Sending shell getprop
[DEVICE_PROVISIONED]: [1]
[af.resampler.quality]: [4]
[audio.offload.buffer.size.kb]: [1024]
[audio.offload.gapless.enabled]: [false]
[av.offload.enable]: [0]
[dalvik.vm.heapgrowthlimit]: [96m]
[dalvik.vm.heapmaxfree]: [8m]
[dalvik.vm.heapminfree]: [2m]
[dalvik.vm.heapsize]: [256m]
[dalvik.vm.heapstartsize]: [8m]
[dalvik.vm.heaptargetutilization]: [0.75]
[dalvik.vm.stack-trace-file]: [/data/anr/traces.txt]
[debug.composition.type]: [gpu]
[debug.egl.hw]: [1]
[debug.egl.trace]: []
[debug.force_rtl]: [0]
[debug.hwui.overdraw]: []
[debug.hwui.profile]: []
[debug.hwui.show_non_rect_clip]: []
[debug.mdpcomp.logs]: [0]
[debug.nfc.fw_boot_download]: [false]
[debug.nfc.fw_download]: [true]
[debug.sf.hw]: [1]
[dev.akmd]: [false]
[dev.alarm.id]: []
[dev.alarm.time]: []
[dev.bootcomplete]: [1]
[dev.bootreason]: []
[dev.defaultwallpaper]: [/system/customize/resource/wallpapers_00.jpg]
[dev.pm.dyn_samplingrate]: [1]
[dev.silent_reboot]: [0]
[dev.zcharge]: [false]
[dhcp.wlan0.autoip]: [0]
[dhcp.wlan0.dns1]: []
[dhcp.wlan0.dns2]: []
[dhcp.wlan0.dns3]: []
[dhcp.wlan0.dns4]: []
[dhcp.wlan0.gateway]: []
[dhcp.wlan0.ipaddress]: []
[dhcp.wlan0.leasetime]: []
[dhcp.wlan0.mask]: []
[dhcp.wlan0.ooxx]: []
[dhcp.wlan0.pid]: []
[dhcp.wlan0.reason]: []
[dhcp.wlan0.result]: []
[dhcp.wlan0.server]: []
[drm.service.enabled]: [true]
[gsm.current.phone-type]: [1]
[gsm.network.type]: [Unknown]
[gsm.operator.alpha]: []
[gsm.operator.iso-country]: []
[gsm.operator.isroaming]: [false]
[gsm.operator.numeric]: []
[gsm.radio.power]: [true]
[gsm.sim.state]: [ABSENT]
[gsm.timezone.isvalid]: [false]
[gsm.version.baseband]: [01.01.010_U10305041_08.01.41222_2_F]
[gsm.version.ril-impl]: [Qualcomm RIL 1.0]
[htc.audio.beats.support2v]: [0]
[htc.audio.first.bootup]: [1]
[htc.audio.global.speaker]: [1]
[htc.audio.global.state]: [4]
[htc.audio.google.volume]: [6]
[htc.audio.hw_standby]: [1]
[htc.audio.skiplowlatency]: [7]
[htc.audio.srs.defaultbundleHS]: [HS250]
[htc.audio.swalt.enable]: [1]
[htc.audio.swalt.mingain]: [3284]
[htc.audio.txpid]: [0]
[htc.build.stage]: [2]
[htc.htcmode.state]: [offline]
[init.svc.adbd]: [running]
[init.svc.atfwd]: [stopped]
[init.svc.audiod]: [running]
[init.svc.bootanim]: [stopped]
[init.svc.cand]: [running]
[init.svc.config_bluetooth]: [stopped]
[init.svc.debuggerd]: [running]
[init.svc.dhcpcd_wlan0]: []
[init.svc.drm]: [running]
[init.svc.flash_recovery]: [stopped]
[init.svc.gyrocali_init]: [stopped]
[init.svc.hcheck]: [stopped]
[init.svc.healthd]: [running]
[init.svc.htc_dk]: [running]
[init.svc.htc_dlk]: [running]
[init.svc.htc_ebdlogd_rel]: [running]
[init.svc.installd]: [running]
[init.svc.irsc_util]: [stopped]
[init.svc.keystore]: [running]
[init.svc.media]: [running]
[init.svc.netd]: [running]
[init.svc.netmgrd]: [running]
[init.svc.network_init]: [stopped]
[init.svc.p2p_supplicant]: [running]
[init.svc.pnpmgr]: [running]
[init.svc.ptt_socket_app]: [stopped]
[init.svc.qcamerasvr]: [running]
[init.svc.qcom-c_core-sh]: [stopped]
[init.svc.qcom-c_main-sh]: [stopped]
[init.svc.qcom-post-boot]: [stopped]
[init.svc.qcom-sh]: [stopped]
[init.svc.qcomsysd]: [running]
[init.svc.qmuxd]: [running]
[init.svc.qrngd]: [running]
[init.svc.qrngp]: [stopped]
[init.svc.qseecomd]: [running]
[init.svc.read_dap_cert]: [stopped]
[init.svc.rfs_access]: [running]
[init.svc.ril-daemon]: [running]
[init.svc.rmt_storage]: [running]
[init.svc.sdcard]: [running]
[init.svc.servicemanager]: [running]
[init.svc.sfc_daemon]: [stopped]
[init.svc.surfaceflinger]: [running]
[init.svc.thermal-engine]: [running]
[init.svc.time_daemon]: [running]
[init.svc.ueventd]: [running]
[init.svc.usbdiag_init]: [stopped]
[init.svc.vold]: [running]
[init.svc.wpa_supplicant]: []
[init.svc.zygote]: [running]
[keyguard.no_require_sim]: [true]
[media.aac_51_output_enabled]: [true]
[media.hwhevccodectype]: [0]
[media.stagefright.enable-aac]: [true]
[media.stagefright.enable-fma2dp]: [true]
[media.stagefright.enable-http]: [true]
[media.stagefright.enable-player]: [true]
[media.stagefright.enable-qcp]: [true]
[media.stagefright.enable-scan]: [true]
[media.swhevccodectype]: [0]
[mm.enable.qcom_parser]: [168563]
[mmp.enable.3g2]: [true]
[net.active_wan]: [-1]
[net.bt.name]: [Android]
[net.change]: [net.usb0.isharing.host2]
[net.dns.cache_size]: [512]
[net.dns.cache_ttl]: [600]
[net.frisbee.enabled]: [0]
[net.hostname]: [android-129c5b77d42fa7dd]
[net.http.getzip]: [1]
[net.http.idle_cache.shutdown]: [true]
[net.http.idle_cache.size]: [40]
[net.http.threads]: [10]
[net.nw.cache.orderby]: [weight]
[net.nw.cache.prioadvstep]: [86400000]
[net.nw.cache.weightadvstep]: [3600000]
[net.qtaguid_enabled]: [1]
[net.tcp.buffersize.default]: [4096,87380,110208,4096,16384,110208]
[net.tcp.buffersize.edge]: [4093,26280,35040,4096,16384,35040]
[net.tcp.buffersize.evdo]: [4094,87380,262144,4096,16384,262144]
[net.tcp.buffersize.evdo_b]: [8188,174160,524400,64860,129720,1220608]
[net.tcp.buffersize.gprs]: [4092,8760,11680,4096,8760,11680]
[net.tcp.buffersize.hsdpa]: [4096,174760,1572864,4096,225280,1220608]
[net.tcp.buffersize.hspa]: [4096,174760,1572864,4096,225280,1220608]
[net.tcp.buffersize.hspap]: [4096,174760,1572864,4096,225280,1220608]
[net.tcp.buffersize.hsupa]: [4096,174760,1572864,4096,225280,1220608]
[net.tcp.buffersize.lte]: [524288,1048576,5120000,4096,221184,3461120]
[net.tcp.buffersize.umts]: [4096,174760,1572864,4096,225280,1220608]
[net.tcp.buffersize.wifi]: [524288,2097152,4194304,262144,524288,1048576]
[net.tcp.default_init_rwnd]: [60]
[net.usb0.isharing.host2]: [all]
[net.webkit.cache.maxdeadsize]: [4194304]
[net.webkit.cache.mindeadsize]: [4194304]
[net.webkit.cache.size]: [12582912]
[net.wifi.restrit]: [false]
[net.wlan0.dns1]: []
[net.wlan0.dns2]: []
[persist.audio.fluence.speaker]: [true]
[persist.audio.fluence.voicecall]: [true]
[persist.audio.fluence.voicerec]: [false]
[persist.camera.antibanding]: [50]
[persist.camera.forceuseaudio]: [0]
[persist.camera.tuning_spec]: [htc]
[persist.cne.UseCne]: [vendor]
[persist.cne.UseSwim]: [false]
[persist.cne.bat.based.rat.mgt]: [false]
[persist.cne.bat.range.low.med]: [30]
[persist.cne.bat.range.med.high]: [60]
[persist.cne.bwbased.rat.sel]: [false]
[persist.cne.loc.policy.op]: [/system/etc/OperatorPolicy.xml]
[persist.cne.loc.policy.user]: [/system/etc/UserPolicy.xml]
[persist.cne.rat.acq.retry.tout]: [0]
[persist.cne.rat.acq.time.out]: [30000]
[persist.cne.snsr.based.rat.mgt]: [false]
[persist.cne.sync.swim.mode]: [false]
[persist.data.netmgrd.qos.enable]: [true]
[persist.debug.wfd.enable]: [1]
[persist.demo.hdmirotationlock]: [false]
[persist.fuse_sdcard]: [true]
[persist.gps.qc_nlp_in_use]: [0]
[persist.htc.audio.dqlog.dci]: [1]
[persist.htc.audio.pcm.channels]: [2]
[persist.hwc.enable_vds]: [1]
[persist.hwc.mdpcomp.enable]: [true]
[persist.preload.common]: [0]
[persist.radio.adb_log_on]: [1]
[persist.radio.eons.enabled]: [false]
[persist.radio.fill_eons]: [1]
[persist.radio.htc_mfg_code]: [GRY01]
[persist.radio.prefer.network]: [9]
[persist.radio.sap_silent_pin]: [1]
[persist.rild.nitz_long_ons_0]: []
[persist.rild.nitz_long_ons_1]: []
[persist.rild.nitz_long_ons_2]: []
[persist.rild.nitz_long_ons_3]: []
[persist.rild.nitz_plmn]: []
[persist.rild.nitz_short_ons_0]: []
[persist.rild.nitz_short_ons_1]: []
[persist.rild.nitz_short_ons_2]: []
[persist.rild.nitz_short_ons_3]: []
[persist.service.adb.enable]: []
[persist.sys.cnd.wqe]: [2]
[persist.sys.country]: [US]
[persist.sys.dalvik.vm.lib]: [libdvm.so]
[persist.sys.flipfontpath]: [default]
[persist.sys.htcthemeid]: [3]
[persist.sys.language]: [en]
[persist.sys.localevar]: []
[persist.sys.pms.oobe.done]: [1]
[persist.sys.profiler_ms]: [0]
[persist.sys.timezone]: [Europe/Rome]
[persist.sys.usb.config]: [adb]
[persist.sys.usb.hsm_detect]: [0]
[persist.sys.vzwlogger.zygote]: []
[persist.sys.wifi.band]: [0]
[persist.timed.enable]: [true]
[persist.wifi.v6.rs.count]: [5]
[persist.wifi.v6.rs.timeout]: [5]
[persist.wifi.v6]: [true]
[persist.zygote.preload_threads]: [3]
[qemu.hw.mainkeys]: [0]
[ril.data.radio_tech]: []
[ril.ecclist]: [911,112,000,08,110,999,118,119]
[ril.imei.lock]: [0]
[ril.qcril_pre_init_lock_held]: [0]
[ril.reload.count]: [1]
[ril.socket.reset]: [1]
[ril.subscription.types]: [NV,RUIM]
[rild.libargs]: [-d /dev/smd0]
[rild.libpath]: [/system/vendor/lib/libril-qc-qmi-1.so]
[ro.aa.cidlist]: [ORANG202]
[ro.aa.customizationid]: [1038971]
[ro.aa.maincid]: [ORANG202]
[ro.aa.mainsku]: [73]
[ro.aa.modelid]: [0PFJ40000]
[ro.aa.project]: [A51_UL_K44_DESIRE_SENSE60]
[ro.aa.report]: [com]
[ro.aa.rid]: [159]
[ro.aa.romver]: [1.28.73.2]
[ro.aa.skulist]: [73]
[ro.aa.taskid]: [420793]
[ro.adb.secure]: [1]
[ro.allow.mock.location]: [0]
[ro.baseband.arch]: [msm]
[ro.baseband]: [01.01.010_U10305041_08.01.41222_2]
[ro.bc_tmo]: [300]
[ro.bluetooth.remote.autoconnect]: [true]
[ro.bluetooth.request.master]: [true]
[ro.board.platform]: [msm8916]
[ro.boot.baseband]: [01.01.010_U10305041_08.01.41222_2]
[ro.boot.batt_poweron]: [good_battery]
[ro.boot.bootdevice]: [7824900.sdhci]
[ro.boot.bootloader]: [3.19.0.0000]
[ro.boot.dq]: [FAIL]
[ro.boot.keycaps]: [azerty]
[ro.boot.mode]: [normal]
[ro.boot.podt]: [0x3E8]
[ro.boot.rom_type]: [NORMAL]
[ro.boot.serialno]: [HT55BYC00151]
[ro.bootloader]: [3.19.0.0000]
[ro.bootmode]: [normal]
[ro.bt.bdaddr_path]: [/sys/module/htc_bdaddress/parameters/bdaddress]
[ro.bt.ble_tag]: [1]
[ro.build.changelist]: [481486]
[ro.build.characteristics]: [default]
[ro.build.date.utc]: [1423033225]
[ro.build.date]: [三  2月  4 15:00:25 CST 2015]
[ro.build.description]: [1.28.73.2 CL481486 release-keys]
[ro.build.display.id]: [KTU84P release-keys]
[ro.build.fingerprint]: [htc/a51ul_orange_fr-b2b/htc_a51ul:4.4.4/KTU84P/481486.2:user/release-keys]
[ro.build.host]: [ABM105]
[ro.build.id]: [KTU84P]
[ro.build.languageremove]: [0]
[ro.build.product]: [htc_a51ul]
[ro.build.project]: [A51_UL_K44_DESIRE_SENSE60:420793]
[ro.build.sense.version]: [6.0]
[ro.build.sku]: [Orange FR]
[ro.build.tags]: [release-keys]
[ro.build.type]: [user]
[ro.build.user]: [buildteam]
[ro.build.version.codename]: [REL]
[ro.build.version.htcsdk]: [HTCExt:HTCExtension_Sense60_443_5;SDK:6.25;hdkbase:19.2]
[ro.build.version.incremental]: [481486.2]
[ro.build.version.release]: [4.4.4]
[ro.build.version.sdk]: [19]
[ro.carrier]: [ORANGE-French]
[ro.chk_prd]: [1]
[ro.cid]: [ORANG202]
[ro.com.android.dataroaming]: [false]
[ro.com.google.clientidbase.am]: [android-orange-{country}]
[ro.com.google.clientidbase.gmm]: [android-htc]
[ro.com.google.clientidbase.ms]: [android-orange-{country}]
[ro.com.google.clientidbase.yt]: [android-htc]
[ro.com.google.clientidbase]: [android-htc]
[ro.com.google.gmsversion]: [4.4_r5]
[ro.config.alarm_alert]: [Alarm_Classic.ogg]
[ro.config.notification_sound]: [pixiedust.ogg]
[ro.config.ringtone]: [Ring_Synth_04.ogg]
[ro.crypto.fuse_sdcard]: [true]
[ro.crypto.state]: [unencrypted]
[ro.customer.ORANG202]: [PROJECT_O0002_flag, 0x0071]
[ro.cwkey]: [ORANG202]
[ro.dap_index]: [6]
[ro.debuggable]: [0]
[ro.device.fp]: [false]
[ro.devicerev]: [2]
[ro.di]: [7JB1l2KyJBCgMbRtOh6Xa9FjapuCZU6S]
[ro.efuse_info]: [H]
[ro.emmc]: [1]
[ro.factorytest]: [0]
[ro.fm.transmitter]: [false]
[ro.fuse_sdcard]: [true]
[ro.getebd]: [0]
[ro.gps.agps_provider]: [1]
[ro.hardware]: [qcom]
[ro.hlog_ofs]: [628]
[ro.htc.bluetooth.sap]: [true]
[ro.htc.htcmode.socket.type]: [LocalSocket]
[ro.hwui.renderer.disable_opaque]: [true]
[ro.installbysim]: [1]
[ro.language.ORANG202]: [LANGUAGE_FR_flag, 0x000B]
[ro.lb]: [1]
[ro.metropcs.ui]: [0]
[ro.mid]: [0PFJ40000]
[ro.min_freq_0]: [800000]
[ro.min_freq_4]: [499200]
[ro.mvp.features]: [srvc,mvpdaff,grbks2,vpncrt,vpn,mvpdsec]
[ro.net.apnroamingwhitelist]: [mms]
[ro.net.apnwhitelist]: [mms]
[ro.onecid]: [1]
[ro.opengles.version]: [196608]
[ro.pagesize]: [2048]
[ro.pip.gated]: [0]
[ro.product.bluetooth]: [4.0]
[ro.product.board]: [msm8939]
[ro.product.brand1]: [orange]
[ro.product.brand]: [htc]
[ro.product.cpu.abi2]: [armeabi]
[ro.product.cpu.abi]: [armeabi-v7a]
[ro.product.device]: [htc_a51ul]
[ro.product.display_resolution]: [5.5 inch 720p resolution]
[ro.product.front_camera]: [8M]
[ro.product.hwreset.timer1]: [6]
[ro.product.hwreset.timer2]: [9]
[ro.product.hwreset]: [1]
[ro.product.locale.language]: [fr]
[ro.product.locale.region]: [FR]
[ro.product.main_camera]: [13M]
[ro.product.manufacturer]: [HTC]
[ro.product.model]: [HTC Desire 820]
[ro.product.name]: [a51ul_orange_fr-b2b]
[ro.product.processor]: [Octacore]
[ro.product.ram]: [2GB]
[ro.product.version]: [1.28.73.2]
[ro.product.wifi]: [802.11 a/b/g/n]
[ro.prot]: [true]
[ro.qc.bluetooth.stack]: [bluedroid]
[ro.qc.sdk.audio.fluencetype]: [none]
[ro.qc.sdk.audio.ssr]: [false]
[ro.qc.sdk.izat.premium_enabled]: [0]
[ro.qc.sdk.izat.service_mask]: [0x0]
[ro.qf_st]: [1]
[ro.qualcomm.bluetooth.dun]: [false]
[ro.qualcomm.bluetooth.ftp]: [true]
[ro.qualcomm.bluetooth.hfp.wbs]: [false]
[ro.qualcomm.bluetooth.hfp]: [true]
[ro.qualcomm.bluetooth.hsp]: [true]
[ro.qualcomm.bluetooth.map]: [true]
[ro.qualcomm.bluetooth.nap]: [true]
[ro.qualcomm.bluetooth.opp]: [true]
[ro.qualcomm.bluetooth.pbap]: [true]
[ro.qualcomm.bluetooth.sap]: [true]
[ro.qualcomm.bt.hci_transport]: [smd]
[ro.qualcomm.cabl]: [0]
[ro.rb_dly]: [0]
[ro.revision]: [0]
[ro.ril.air.enabled]: [0]
[ro.ril.def.agps.mode]: [2]
[ro.ril.disable.cpc]: [1]
[ro.ril.disable.fd.plmn.prefix]: [23402,23410,23411,23420,23594,27202,27205]
[ro.ril.disable.mcc.filter]: [1]
[ro.ril.disable.reattach]: [1]
[ro.ril.disable.sync_pf]: [1]
[ro.ril.enable.a52]: [0]
[ro.ril.enable.a53]: [0]
[ro.ril.enable.amr.wideband]: [1]
[ro.ril.enable.isr]: [1]
[ro.ril.enable.pre_r8fd]: [1]
[ro.ril.enable.r8fd]: [1]
[ro.ril.enable.sdr]: [0]
[ro.ril.fast.dormancy.rule]: [1]
[ro.ril.fd.pre_r8_tout.scr_off]: [3]
[ro.ril.fd.pre_r8_tout.scr_on]: [0]
[ro.ril.fd.r8_tout.scr_off]: [3]
[ro.ril.fd.r8_tout.scr_on]: [5]
[ro.ril.gsm.to.lte.blind.redir]: [1]
[ro.ril.hsdpa.category]: [24]
[ro.ril.hsupa.category]: [6]
[ro.ril.hsxpa]: [4]
[ro.ril.ltefgi.rel9]: [3229614080]
[ro.ril.ltefgi]: [1561329280]
[ro.ril.svdo]: [false]
[ro.ril.svlte1x]: [false]
[ro.runtime.firstboot]: [1451408362675]
[ro.secure]: [1]
[ro.serialno]: [HT55BYC00151]
[ro.setupwizard.mode]: [OPTIONAL]
[ro.sf.lcd_density]: [320]
[ro.sf]: [1]
[ro.storage_encryption_type]: [2]
[ro.storage_structure]: [10]
[ro.td]: [1]
[ro.td_ofs]: [328]
[ro.telephony.call_ring.multiple]: [false]
[ro.telephony.default_network]: [9]
[ro.telephony.ipv6_capability]: [1]
[ro.un]: [unknown]
[ro.ur]: [unknown]
[ro.usb_host]: [1]
[ro.use_data_netmgrd]: [true]
[ro.vendor.extension_library]: [/vendor/lib/libqc-opt.so]
[ro.wifi.channels]: []
[service.bootanim.exit]: [0]
[service.bootanim.ready]: [0]
[service.policy.camera]: [1]
[supolicy.loaded]: [1]
[sys.boot_completed]: [1]
[sys.media.vdec.sw]: [0]
[sys.psaver.bright]: [false]
[sys.psaver.gap]: [15]
[sys.psaver.haptic]: [false]
[sys.psaver.stat]: [normal]
[sys.settings_global_version]: [17]
[sys.settings_secure_version]: [8]
[sys.settings_system_version]: [12]
[sys.stt.ssr.no_prompt]: [1]
[sys.sysctl.extra_free_kbytes]: [10800]
[sys.usb.config]: [mtp,mass_storage,adb]
[sys.usb.state]: [mtp,mass_storage,adb]
[sys.zygote.first.init]: [1]
[telephony.lteOnCdmaDevice]: [1]
[tunnel.audio.encode]: [false]
[use.voice.path.for.pcm.voip]: [true]
[voice.playback.conc.disabled]: [true]
[voice.record.conc.disabled]: [false]
[voice.voip.conc.disabled]: [true]
[vold.ext_sdcard_mounted]: [false]
[vold.post_fs_data_done]: [1]
[wifi.country]: [DE]
[wifi.interface]: [wlan0]
[wifi.miracastconcurrent.scan]: [WCN3680]
[wifi.miracastlock]: [0]
[wifi.miracaston]: [0]
[wifi.softap.interface]: [wlan0]
[wifi.softapconcurrent.interface]: [softap.0]
[wifi.supplicant_scan_interval]: [15]
[wifi.wpa_supp_ready]: [1]
[wlan.crda.country]: [DE]
[wlan.custom.assocmode]: [0]
[wlan.driver.status]: [ok]
[wlan.sim.enabled]: [0]
Sending shell dumpsys iphonesubinfo
Phone Subscriber Info:
  Phone Type = GSM
  Device ID = *******xxxxxxx1
allumts
mastershex 12-31-2015 19:06
what can I say ?????
HTC Desire EYE s-off and super cid done with this incredible tool
hope this tool wont stop updating like other htc tool in the market :(
12/31/2015 3:03:18 PM Phone connected [FA57DY800380] *** Fastboot mode
12/31/2015 3:03:21 PM Sending oem writesecureflag 0
12/31/2015 3:03:21 PM ... (bootloader) [JAVACARD_ERR] SD/USBDISK Init error
(bootloader) writesecureflag: Permission denied, value 1
Execution time is 7(ms)
OKAY
12/31/2015 3:03:27 PM Sending reboot-bootloader
12/31/2015 3:03:27 PM Execution time is 15(ms)
rebooting into bootloader... OKAY
12/31/2015 3:03:27 PM Operation finished
12/31/2015 3:03:28 PM Phone DISconnected
12/31/2015 3:04:00 PM Phone connected [FA57DY800380] *** Fastboot mode
12/31/2015 3:04:02 PM Reading information...
12/31/2015 3:04:02 PM Using Fastboot mode...
12/31/2015 3:04:02 PM Reading common information
12/31/2015 3:04:02 PM (bootloader) version: 0.5
(bootloader) version-baseband: 1.27.213311581.09G
(bootloader) version-main: 2.19.401.1
(bootloader) serialno: FA57DY800380
(bootloader) imei: 355282061240268
(bootloader) product: eye_ul
(bootloader) modelid: 0PFH11000
(bootloader) cidnum: HTC__J15
(bootloader) commitno-bootloader: 36917be4
Execution time is 12(ms)
all: Done!
12/31/2015 3:04:02 PM Reading secure flag information
12/31/2015 3:04:02 PM ... (bootloader) secure_flag: 3
Execution time is 6(ms)
OKAY
12/31/2015 3:04:02 PM Reading CID information
12/31/2015 3:04:03 PM ... (bootloader) cid: HTC__J15
Execution time is 5(ms)
OKAY
12/31/2015 3:04:03 PM Reading MEID information
12/31/2015 3:04:03 PM ... (bootloader) meid: 00000000000000
OKAY
12/31/2015 3:04:03 PM Read information completed.
12/31/2015 3:04:05 PM Sending oem writesecureflag 0
12/31/2015 3:04:05 PM ... (bootloader) SecuritySDInit: counter = 3
(bootloader) eyeul_init_sd, SD card already power on
12/31/2015 3:04:06 PM (bootloader) Error: Command never completed
12/31/2015 3:04:09 PM (bootloader) writesecureflag: KeyCard remain count 10000
(bootloader) PID:346
12/31/2015 3:04:10 PM (bootloader) [PGFS] partition_update_pgfs: pg1fs_security
Execution time is 4282(ms)
OKAY
12/31/2015 3:04:10 PM Operation finished
12/31/2015 3:04:20 PM Phone DISconnected
12/31/2015 3:04:23 PM Phone connected [FA57DY800380] *** Fastboot mode
12/31/2015 3:04:38 PM Sending oem writecid 11111111
12/31/2015 3:04:39 PM ... (bootloader) Start Verify: 0
Execution time is 31(ms)
OKAY
12/31/2015 3:04:39 PM Operation finished
12/31/2015 3:04:47 PM Phone DISconnected
12/31/2015 3:04:51 PM Phone connected [FA57DY800380] *** Fastboot mode
Page generated in 0.51671 seconds with 5 queries
