Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > xtc2cliP
Old 12-15-2018, 07:38   #361 (permalink)
Member: 2776864
Originally Posted by ermannle View Post
Hi guys...Hope you can help..
About 6 months ago I bought a Chinese Juning X6 phone from Amazon. The phone worked great until a couple weeks ago, there was a system corruption, I presume, and the phone now boots into the android image with a red sign on it.
Been trying to get the stock rom for this phone but there is no reference to it anywhere in google.
I opened it up and there is a sticker on the logicboard:
V178C_OHD_V!.0.84_20180427_2009_V1.0.3 Al X6 which I believe is the Rom version, but I cant find this either on google.
If anyone can help, I'd be grateful
you are in the wrong spot my friend
Old 12-28-2018, 11:12   #362 (permalink)
Member: 87364
Thanks Meter: 51
HTC M9 HIMA_UHL flashing sucesfull (repair bootloop):
Starting flash process...
target rom version: 4.17.161.11
found large-zip header, file count: 7
processing file 1/7...
sending 'zip' (224592 KB)...
OKAY [ 14.491s]
writing 'zip'...
(bootloader) HOSD CL#839204
(bootloader) GPT (gpt_main_32g.img) is up-to-dated. [17408]
(bootloader) WARN Skip cmnlib32.img due to unmatched partition name
(bootloader) WARN Skip cmnlib64.img due to unmatched partition name
(bootloader) WARN Skip keymaster.img due to unmatched partition name
(bootloader) WARN Skip bootlocker.img due to unmatched partition name
(bootloader) WARN Skip cir.img due to unmatched partition name
(bootloader) WARN Skip backup_android-info.txt due to unmatched partitio
(bootloader) n name
(bootloader) get 23 images from zip(zip_type=3)
(bootloader) [email protected]
(bootloader) [email protected]%
(bootloader) Update zip file OK
OKAY [ 18.069s]
finished. total time: 32.561s
processing file 2/7...
sending 'zip' (406656 KB)...
OKAY [ 26.021s]
writing 'zip'...
(bootloader) get 1 images from zip(zip_type=3)
OKAY [ 23.190s]
finished. total time: 49.211s
processing file 3/7...
sending 'zip' (453058 KB)...
OKAY [ 29.099s]
writing 'zip'...
OKAY [ 17.720s]
finished. total time: 46.820s
processing file 4/7...
sending 'zip' (438724 KB)...
OKAY [ 28.106s]
writing 'zip'...
OKAY [ 17.740s]
finished. total time: 45.846s
processing file 5/7...
sending 'zip' (453362 KB)...
OKAY [ 29.130s]
writing 'zip'...
OKAY [ 18.133s]
finished. total time: 47.263s
processing file 6/7...
sending 'zip' (290129 KB)...
OKAY [ 19.049s]
writing 'zip'...
OKAY [ 13.683s]
finished. total time: 32.733s
processing file 7/7...
sending 'zip' (13483 KB)...
OKAY [ 1.902s]
writing 'zip'...
(bootloader) get 2 images from zip(zip_type=3)
OKAY [ 7.089s]
finished. total time: 8.992s
rompack updated
Flash process completed.
Restarting phone...
rebooting...
finished. total time: 0.009s
htc_fastboot finished
Phone DISconnected
Old 02-01-2019, 20:55   #363 (permalink)
Member: 520070
Thanks for the quick response. My two clips work again. Super servis for Xtc2clip. Thanks again to xtc2clip Product Manager.
Old 03-24-2019, 15:48   #364 (permalink)
deepakgarg's Avatar
Member: 220603
Sonork: 100.1624258
Thanks Meter: 1,132
HTC D530 unlock done in 5 mins
s-off using power adapter
1. Checking phone connectivity.......
Phone connection confirmed!
HTC KEY CARD VERSION: 7
2. Checking Server connectivity...
Server connection confirmed!
3. Checking PowerAdapter connectivity...
Process started
PowerAdapter connected, processing request to adapter...
Starting operation...
Sending oem writesecureflag 0
... (bootloader) HTC KEY CARD VERSION: 7
Building connection
Initiating communication
Building connection
Data exchange sequence.
Request sent, waiting for reply ... 2 second(s)
Processing...
Data exchange completed
Data exchange sequence.....
(bootloader) Write security level S-OFF
OKAY
finished. total time: 9.652s
Operation completed!
Releasing adapter.
Request completed
sim unlock using special unlock tab
XTC 2 Clip - service tool v2.14
Detected release: A16_UL_M60_DESIRE_SENSE70GP_TMUS
Detected model:
Desire 530 [QCT]
Preparing for work...
Clip ID: 900xxxxx
Security:
S-OFF
Please wait...
Stage 1 done.
Please wait...
Stage 2 done.
Please wait...
Stage 3 done.
Process done 3 steps with 0 errors
Rebooting in 5 seconds ...
Rebooting in 4 seconds ...
Rebooting in 3 seconds ...
Rebooting in 2 seconds ...
Rebooting in 1 seconds ...
The Following User Says Thank You to deepakgarg For This Useful Post:
Old 04-06-2019, 07:23   #365 (permalink)
malka4u's Avatar
Member: 1626780
Thanks Meter: 676
m8s s-off done
4/4/2019 6:32:47 AM Sending oem writesecureflag 0
4/4/2019 6:32:48 AM ... (bootloader) SecuritySDInit: counter = 2
(bootloader) m8qlul_init_sd, SD card already power on
(bootloader) m8qlul_init_sd, SD card io already power on
(bootloader) sdhci_open: id=0
(bootloader) Initializing MMC host data structure and clock!
(bootloader) mmc slot#2 clock enabled
(bootloader) sdhci_set_clock: slot 2, freq 192000000
(bootloader) GPLL0 is enabled
(bootloader) clock_update_cfg_sd is done
(bootloader) sd clock set done
(bootloader) sdhci_set_bus_width: bus width 0
(bootloader) sdhci_clk_supply: freq 400000
4/4/2019 6:32:49 AM (bootloader) Error: Command never completed
(bootloader) Error: Command timeout error
(bootloader) Error: Command completed with errors
(bootloader) The response for CMD8 does not match the supplied value
(bootloader) Decoded CID fields:
4/4/2019 6:32:49 AM (bootloader) Manufacturer ID: 7f
(bootloader) OEM ID: 0x0
(bootloader) Product Name: 5270
(bootloader) Product revision: 5.2
(bootloader) Product serial number: B4E
(bootloader) Manufacturing date: 2 2015
(bootloader) sdhci_clk_supply: freq 50000000
(bootloader) sdhci_set_bus_width: bus width 1
(bootloader) Done initialization of the card
(bootloader) erase_grpsize: -1921008540
(bootloader) erase_grpmult: -1921008668
(bootloader) wp_grpsize: 1
(bootloader) wp_grpen: 1
(bootloader) perm_wp: 0
(bootloader) temp_wp: 0
(bootloader) [Tuxera][Error] No exFAT partition found
4/4/2019 6:32:52 AM (bootloader) writesecureflag: KeyCard remain count 10000
(bootloader) PID:382
(bootloader) Start Verify: 3
4/4/2019 6:32:52 AM (bootloader) [PGFS] partition_update_pgfs: pg1fs_security
(bootloader) TZ_HTC_SVC_ENC ret = 0
(bootloader) [PGFS] partition_update_pgfs: pg2fs_sec_recovery
OKAY
The Following User Says Thank You to malka4u For This Useful Post:
Old 05-24-2019, 18:45   #366 (permalink)
Member: 2185549
Thanks Meter: 494
htc 10 s-off done after flashing twrp
Please wait, preparing your phone...
HTC 10 detected
Android release: 8.0.0
Checking server connection...
Communicating with the XTC 2 Clip ...
Connecting to the server...
Please wait, processing your request...
Finished. Your phone will be S-OFF on restart.
Phone DISconnected
Old 07-09-2019, 05:51   #367 (permalink)
Member: 2233266
Thanks Meter: 181
xtc 2 clip new active
pls anytime help me
Old 07-09-2019, 05:53   #368 (permalink)
cellcare prasad's Avatar
Member: 602547
Sonork: 100.1621466
Thanks Meter: 893
HTC Desire 610 A3_UL LOGO HANG DONE
BRO
PRASAD
Old 07-28-2019, 10:57   #369 (permalink)
mbiborna's Avatar
Member: 770503
Thanks Meter: 1,059
HTC A9 2pq9100 FRP
Starting FRP unlock procedure
Phone detected, reading token...
Token detected successfully
Waiting for the server to process request, it may take up to 5 minutes...
Your request was processed successfully! Unlock token has been obtained
Removing FRP ...
Done. FRP was removed.
Phone DISconnected
Old 07-31-2019, 23:58   #370 (permalink)
Member: 603138
Thanks Meter: 82
Trying to connect in Sprint mode...
Trying to connect on COM518
Please wait, generating unlock hash...
Process finished SUCCESSFULLY
Please restart your phone for the changes to take effect
Note: If your phone is M7 - please do S-OFF first and then unlock again
In case of calls/network problems, please do reset by:
Open phone dialer, type ##786#, wait for the menu to appear
Press MENU in top right corner and select RESET
Enter SPC code
Wait for the phone to verify the code and reboot
Phone DISconnected
Phone connected [FA5CTSY00009] *** ADB mode
HTC SENSE
Old 08-16-2019, 07:03   #371 (permalink)
Member: 2233266
Thanks Meter: 181
htc 728w frp done one click
Removing FRP ...
Phone DISconnected
Detected phone in mass-storage mode, trying to switch to ADB...
Successfully
Successfully
Old 09-11-2019, 07:55   #372 (permalink)
Member: 2233266
Thanks Meter: 181
htc 720 frp done
Removing FRP ...
Phone DISconnected
Old 09-19-2019, 14:26   #373 (permalink)
Member: 2233266
Thanks Meter: 181
... OKAY
Execution time is 33(ms)
imei: 356061061045425
Execution time is 2(s)
FAILunknown command
getvar:modelid FAILED (remote: unknown command)
Execution time is 3(ms)
FAILunknown command
getvar:cidnum FAILED (remote: unknown command)
Execution time is 2(ms)
sending 'zip'... (240356 KB) OKAY
writing 'zip'... (bootloader) HOSD CL#626611
(bootloader) GPT is up-to-dated. [524288]
(bootloader) Perform pre-update
(bootloader) Perform hardware reset
FAIL90 hboot pre-update! please flush image again immediately
FAILED (remote: 90 hboot pre-update! please flush image again immediately)
For "hboot-preupdate" response, restart the same procedure for device LC56TYF05073...
OKAY
sending 'zip'... (348849 KB) OKAY
OKAY
sending 'zip'... (377860 KB) OKAY
OKAY
sending 'zip'... (283458 KB) OKAY
OKAY
sending 'zip'... (300774 KB) OKAY
OKAY
sending 'zip'... (292826 KB) OKAY
OKAY
sending 'zip'... (224097 KB) OKAY
OKAY
sending 'zip'... (154 KB) OKAY
sending time = 15.690 secs
OKAY
Flash Zip Complete
Execution time is 359(s)
sending time = 14.771 secs
sending time = 20.366 secs
sending time = 22.263 secs
sending time = 16.918 secs
sending time = 18.151 secs
sending time = 17.406 secs
sending time = 13.625 secs
sending time = 1.091 secs
rebooting...
Execution time is 4(ms)
Old 09-27-2019, 14:06   #374 (permalink)
Member: 145109
Sonork: 100.97977
Thanks Meter: 12
Desire 820, unlock done in 3 minutes!
Old 09-29-2019, 08:29   #375 (permalink)
GsmKotla's Avatar
Member: 2016954
Thanks Meter: 286
HTC M7 Mini Flash done
target rom version: 7.19.401.51
found large-zip header, file count: 5
processing file 1/5...
sending 'zip' (50228 KB)...
OKAY [ 3.260s]
writing 'zip'...
(bootloader) rom parsing start ...
(bootloader) rom parsing finish ...
(bootloader) zip header checking...
(bootloader) zip info parsing...
(bootloader) checking model ID...
(bootloader) checking custom ID...
Processing [hboot], please wait...
(bootloader) ...... Successful
finished. total time: 5.086s
preupdate done, rebooting...
Phone DISconnected
Phone connected [HT3BVW903125] *** Fastboot mode
resending command...
OKAY [ 3.089s]
writing 'zip'...
Processing [sp1], please wait...
Processing [sbl2], please wait...
Processing [sbl3], please wait...
Processing [tz], please wait...
Processing [rpm], please wait...
Processing [adsp], please wait...
Processing [pg2fs_spcustom], please wait...
Processing [tp], please wait...
Processing [sbl1-1], please wait...
(bootloader) signature checking...
(bootloader) verified fail
(bootloader) ..... Bypassed
Processing [sbl1-2], please wait...
Processing [sbl1-3], please wait...
Processing [cir], please wait...
Processing [sbl1-4], please wait...
Processing [sbl1-5], please wait...
Processing [recovery], please wait...
Processing [boot], please wait...
Processing [radio], please wait...
Processing [rcdata], please wait...
OKAY [ 60.064s]
finished. total time: 63.153s
processing file 2/5...
sending 'zip' (521930 KB)...
OKAY [ 25.692s]
writing 'zip'...
Processing [system], please wait...
OKAY [ 73.199s]
finished. total time: 98.891s
processing file 3/5...
sending 'zip' (552062 KB)...
OKAY [ 25.355s]
writing 'zip'...
OKAY [ 75.220s]
finished. total time: 100.591s
processing file 4/5...
sending 'zip' (25433 KB)...
OKAY [ 2.160s]
writing 'zip'...
OKAY [ 16.546s]
finished. total time: 18.706s
processing file 5/5...
sending 'zip' (499309 KB)...
OKAY [ 23.538s]
writing 'zip'...
Processing [dzdata], please wait...
OKAY [ 21.770s]
finished. total time: 45.309s
rompack updated
HBoot pre-update sequence
Restarting phone...
rebooting...
finished. total time: 0.046s
Phone DISconnected
Page generated in 0.21208 seconds with 8 queries
