Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | -= Z3X JTAG PLUS =- | Search | Today's Posts | Mark Forums Read |
![]() | #46 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Jun 2008 Location: Persia Age: 27
Member: 802870 Status: Offline Sonork: 100.1585683 Thanks Meter: 594 | ![]() ![]() ![]() ======= M7_UL S-off & Super CID Done ![]() ![]() ======= M7_U S-off & Super CID Done ![]() ![]() ![]() Thanks For Your Great Tool |
![]() | #49 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Feb 2007
Member: 455296 Status: Online Sonork: g4n0k Thanks Meter: 58 | HTC One M9 - HIMA_UHL - Security Mode: S-DEB Successfully S-OFFed and changed security flag from S-DEB to S-OFF on HTC One M9 - HIMA_UHL Using XTC2Clip Using Direct Mode XTC2CLIP v1.05. THIS IS THE ONE AND ONLY TOOL YOU WILL NEED FOR HTC. BEFORE: ![]() AFTER: Code: Reading information... Using Fastboot mode... Reading common information (bootloader) kernel: lk (bootloader) product: htc_himauhl (bootloader) version: 1.0 (bootloader) imei: XXXXXXXXXXXXXXXX (bootloader) version-main: 1.40.401.5 (bootloader) boot-mode: RUU (bootloader) version-bootloader: 1.0.0.0000 (bootloader) mid: 0PJA10000 (bootloader) cid: 11111111 Execution time is 15(ms) all: Reading secure flag information ... (bootloader) Device security level S-OFF Execution time is 15(ms) OKAY Reading CID information ... (bootloader) cid: 11111111 Execution time is 0(ms) OKAY Read information completed. |
The Following 2 Users Say Thank You to G4N0K For This Useful Post: |
![]() | #54 (permalink) |
Product Supporter ![]() ![]() ![]() Join Date: Apr 2011 Location: "Official Reseller" Age: 52
Member: 1564612 Status: Offline Thanks Meter: 9,989 ![]() | @Farzad.m, if you Upload Immage in this site only one 5% can see you photo, no one photo you has posted is visible...so or try to change site or is useless you post "Success Story".... BR allumts |
![]() | #55 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2009 Location: PAKISTAN Age: 28
Member: 1082907 Status: Offline Sonork: 100.1606954 Thanks Meter: 244 | htc j butterfly s-off and super cid done Reading information... Using Fastboot mode... Reading common information (bootloader) version: 0.5 (bootloader) version-bootloader: 1.41.0000 (bootloader) version-baseband: 1.01.12.1122 (bootloader) version-cpld: None (bootloader) version-microp: None (bootloader) version-main: 1.39.970.3 (bootloader) version-misc: PVT SHIP S-OFF (bootloader) serialno: FA2C1S509371 (bootloader) imei: 990000664439751 (bootloader) meid: 99000066443975 (bootloader) product: deluxe_j (bootloader) platform: HBOOT-8064 (bootloader) modelid: PL9910000 (bootloader) cidnum: 11111111 (bootloader) battery-status: good (bootloader) battery-voltage: 3746mV (bootloader) partition-layout: Generic (bootloader) security: off (bootloader) build-mode: SHIP (bootloader) boot-mode: FASTBOOT (bootloader) commitno-bootloader: 7860e302 (bootloader) hbootpreupdate: 11 (bootloader) gencheckpt: 0 Execution time is 60(ms) all: Done! 8064 detected, reading IMEI2 ... ... (bootloader) [ERR] Command error !!! Execution time is 20(ms) OKAY Reading secure flag information ... (bootloader) secure_flag: 0 Execution time is 10(ms) OKAY Reading CID information ... (bootloader) cid: 11111111 Execution time is 20(ms) OKAY Read information completed. Phone DISconnected |
![]() | #56 (permalink) |
Member: 1082907 Status: Offline Sonork: 100.1606954 Thanks Meter: 244 | M7_WLS s-off supercid done Reading information... Using Fastboot mode... Reading common information (bootloader) version: 0.5 (bootloader) version-bootloader: 1.57.0000 (bootloader) version-baseband: 1.01.20.0904_2 (bootloader) version-cpld: None (bootloader) version-microp: None (bootloader) version-main: 5.05.651.2 (bootloader) version-misc: PVT SHIP S-OFF (bootloader) serialno: FA43WS904748 (bootloader) imei: 990004288931896 (bootloader) meid: 99000428893189 (bootloader) product: m7_wls (bootloader) platform: HBOOT-8064 (bootloader) modelid: PN0720000 (bootloader) cidnum: 11111111 (bootloader) battery-status: good (bootloader) battery-voltage: 3803mV (bootloader) partition-layout: Generic (bootloader) security: off (bootloader) build-mode: SHIP (bootloader) boot-mode: FASTBOOT (bootloader) commitno-bootloader: dirty-0e1af350 (bootloader) hbootpreupdate: 11 (bootloader) gencheckpt: 0 Execution time is 80(ms) all: Done! 8064 detected, reading IMEI2 ... ... (bootloader) [ERR] Command error !!! Execution time is 10(ms) OKAY Reading secure flag information ... (bootloader) secure_flag: 0 Execution time is 10(ms) OKAY Reading CID information ... (bootloader) cid: 11111111 Execution time is 20(ms) OKAY Read information completed. |
![]() | #57 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Jul 2012 Location: Iran < Milad.B >
Member: 1784663 Status: Offline Sonork: 100.1618770 Thanks Meter: 61 | Code: Sending oem writesecureflag 0 ... (bootloader) SecuritySDInit: counter = 2 (bootloader) a5dwg_init_sd, SD card already power on (bootloader) a5dwg_init_sd, SD card io already power on (bootloader) sdhci_open: id=0 (bootloader) Initializing MMC host data structure and clock! (bootloader) mmc slot#2 clock enabled (bootloader) clock_config_mmc: slot 2, freq 192000000 (bootloader) GPLL0 is enabled (bootloader) clock_update_cfg_sd is done (bootloader) sd clock set done (bootloader) sdhci_set_bus_width: bus width 0 (bootloader) sdhci_clk_supply: freq 400000 (bootloader) Error: Command never completed (bootloader) Error: Command timeout error (bootloader) Error: Command completed with errors (bootloader) The response for CMD8 does not match the supplied value (bootloader) Decoded CID fields: (bootloader) Manufacturer ID: 7f (bootloader) OEM ID: 0x0 (bootloader) Product Name: 5270 (bootloader) Product revision: 5.2 (bootloader) Product serial number: B4E (bootloader) Manufacturing date: 2 2015 (bootloader) sdhci_clk_supply: freq 50000000 (bootloader) Decoded CSD fields: (bootloader) cmmc_structure: 0 (bootloader) card_cmd_class: 5f5 (bootloader) write_blk_len: 512 (bootloader) read_blk_len: 512 (bootloader) r2w_factor: 4 (bootloader) sector_size: 128 (bootloader) c_size_mult:2 (bootloader) c_size: 506 (bootloader) nsac_clk_cycle: 100 (bootloader) taac_ns: 70000 (bootloader) tran_speed: 26000 kbps (bootloader) erase_blk_len: 0 (bootloader) read_blk_misalign: 0 (bootloader) write_blk_misalign: 0 (bootloader) read_blk_partial: 1 (bootloader) write_blk_partial: 0 (bootloader) Card Capacity: 4153344 Bytes (bootloader) sdhci_set_bus_width: bus width 1 (bootloader) Done initialization of the card (bootloader) erase_grpsize: 49152 (bootloader) erase_grpmult: 257351520 (bootloader) wp_grpsize: 1 (bootloader) wp_grpen: 1 (bootloader) perm_wp: 0 (bootloader) temp_wp: 0 (bootloader) [Tuxera][Error] No exFAT partition found (bootloader) writesecureflag: KeyCard remain count 10000 (bootloader) PID:297 (bootloader) Start Verify: 3 (bootloader) [PGFS] partition_update_pgfs: pg1fs_security Execution time is 4187(ms) OKAY Operation finished Sending oem writecid 11111111 ... (bootloader) Start Verify: 0 (bootloader) Input CID is super CID (bootloader) Start Verify: 0 Execution time is 15(ms) OKAY Operation finished Reading information... Using Fastboot mode... Reading common information (bootloader) version: 0.5 (bootloader) version-bootloader: 3.19.0.0000 (bootloader) version-baseband: 1.13.3230.16.05 (bootloader) version-cpld: None (bootloader) version-microp: None (bootloader) version-main: 1.56.401.1 (bootloader) version-misc: PVT SHIP S-OFF (bootloader) serialno: FA44RWW00596 (bootloader) imei: 352706060391253 (bootloader) imei2: 352706060391261 (bootloader) meid: 00000000000000 (bootloader) product: a5_dug (bootloader) platform: hTCBmsm8226 (bootloader) modelid: 0P9C70000 (bootloader) cidnum: 11111111 (bootloader) battery-status: good (bootloader) battery-voltage: 0mV (bootloader) partition-layout: Generic (bootloader) security: off (bootloader) build-mode: SHIP (bootloader) boot-mode: FASTBOOT (bootloader) commitno-bootloader: 5534924e (bootloader) hbootpreupdate: 11 (bootloader) gencheckpt: 0 Execution time is 15(ms) all: Done! Reading secure flag information ... (bootloader) secure_flag: 0 Execution time is 15(ms) OKAY Reading CID information ... (bootloader) cid: 11111111 Execution time is 15(ms) OKAY Read information completed. |
