10-23-2015, 03:20 | #1 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Santiago de Cuba Age: 46
Member: 220595 Status: Offline Thanks Meter: 355 | Trying to repair imei on htc first (mystul ) it was boot loader locked, s-on and don't remember the CID. I setup the clip to do the job and after trying to s-off and repair imei I got this (Except the bootloader, which I unlocked later) And the imei number is much different from the one I set, the imei umber has a lot of zeroes. Also, the os is not loading, it now has gone to a boot - loop after I unlocked the boot-loader. I am afraid it will be hard to flash a stock RUU since the CID is not a super cid and not a CID at all. So, I think it will not accept any RUU. Any help please? Enviado desde mi SM-N900T mediante Tapatalk |
10-23-2015, 03:21 | #2 (permalink) |
Member: 220595 Status: Offline Thanks Meter: 355 | Trying to repair imei on htc first (mystul ) I received this phone to repair imei, but looks like some one was messing with its security or something because in bootloader screen it always say TAMPERED. it was boot loader locked, s-on and don't remember the CID. I setup the clip to do the job and after trying to s-off and repair imei I got this (Except the bootloader, which I unlocked later) And the imei number is much different from the one I set, the imei umber has a lot of zeroes. Also, the os is not loading, it now has gone to a boot - loop after I unlocked the boot-loader. I am afraid it will be hard to flash a stock RUU since the CID is not a super cid and not a CID at all. So, I think it will not accept any RUU. Any help please? Enviado desde mi SM-N900T mediante Tapatalk |
10-23-2015, 03:23 | #3 (permalink) |
10-23-2015, 03:23 | #4 (permalink) |
10-23-2015, 03:27 | #5 (permalink) |
10-23-2015, 03:29 | #6 (permalink) |
Member: 220595 Status: Offline Thanks Meter: 355 | Delete threads Please a mod delete my repeating threads, it was a connection problem in tapatalk which made me repeat the postings. Sorry Enviado desde mi SM-N900T mediante Tapatalk |
10-26-2015, 18:03 | #7 (permalink) |
Member: 220595 Status: Offline Thanks Meter: 355 | Not even a reply or suggestion from anyone? I now tried to write stock RUU, but could not succed, obviously because CID is not correct. I get this: Enviado desde mi SM-N900T mediante Tapatalk |
10-26-2015, 19:21 | #9 (permalink) |
Member: 220595 Status: Offline Thanks Meter: 355 | Hi, I solved the issue, without repairing clip. This is what I did. Since the phone is s-off I can run oem commands... So, I repaired Cid by: fastboot oem writecid 11111111 Then repaired imei by: fastboot oem writeimei 15-digits-imei Phone did not boot, so I tried: fastboot oem lock Then phone started with both Cid and imei fixed. I really don't Need to unlock bootloader since I will not write any custom rom or recovery to the phone, so I will keep it relocked. About TAMPERED status, it is still there, as far as I know it would be removed only by writing ruu, but ruu is not willing to write this phone even after relocking bootloader, I don't know why. About the clip not repairing the phone well, I think it has to do with the tampered status, I say this because there is an error when you run the comand: fastboot getvar all The command returns some variables but not all, probably the software xtc or clip are having a bug processing this command and then fails to continue. I tried to fix with irkey suite 5, and this software could not even read the phone in fastboot mode and after trying to read the phone got completely frozzen, the volume keys stopped working. Just my 0.2 cents to the xtc developers. Thanks again for this awesome tool. uploadfromtaptalk1445883602326.jpg Enviado desde mi SM-N900T mediante Tapatalk |
10-26-2015, 19:50 | #10 (permalink) |
No Life Poster Join Date: Jun 2015
Member: 2416253 Status: Offline Thanks Meter: 4,162 | As I wrote you in PM - the "RESPONSE" CID is just a filesystem mess, we don't know why it happens sometimes, but filesystem repair helps to solve this problem. As to TAMPERED, you are right - the firmware should update the tampered status on the first start, but it may not, I don't know all the reasons yet, try to master-reset the phone. Thanks for your detailed description of the solution, anyway. |
10-26-2015, 23:52 | #11 (permalink) | |
Member: 220595 Status: Offline Thanks Meter: 355 | Quote:
Take a look at this After this, the phone is stuck, I had to forcely shut it down, maybe something happens if the clip run the command or if the clip try to access a var inside the problematic area. Enviado desde mi SM-N900T mediante Tapatalk | |
10-27-2015, 09:53 | #12 (permalink) |
Member: 2416253 Status: Offline Thanks Meter: 4,162 | Trust me - it's a filesystem problem. The phones are different, so the FAT handling is different on older firmwares aswell. I didn't get the problem - you've read the phone info and it's stuck now? |
10-28-2015, 02:06 | #13 (permalink) | |
