GSM-Forum (https://forum.gsmhosting.com/vbb/)
-   xtc2cliP (https://forum.gsmhosting.com/vbb/f961/)
-   -   U11 IMEI repair & SIM unlock instructions (https://forum.gsmhosting.com/vbb/f961/u11-imei-repair-sim-unlock-instructions-2311747/)
bretash 03-09-2018 15:57
paso de imei en la opcion simlock
Sending reboot
rebooting...
Execution time is 0(ms)
Operation finished
Phone DISconnected
Phone connected [FA77E1802473] *** ADB mode
Sending reboot recovery
Phone DISconnected
Your phone should restart now and the process will continue. Please watch it on your phone!
Phone DISconnected
no funciona deberia entrar con el recovery que me he descargado todos los posteados por e xtc2 clip manager, y solo prende y apaga con el aviso en la pantalla
amigo por favor ayudame ninguno de los dos pasos me sirve para reparar el imei tengo oreo bootloader abierto, s on, ya que tampoco he podido hacer s off
para que se acaben estos problemas deberias montar un video con todos estos pasos amigo
thuanmobile896 03-31-2018 09:47
SIM Unlock
U11_recovery_xtc2_new.zip
At this moment we have tested SIM Unlocking only with phones which ASK for unlock code.
How to SIM Unlock your U11
1. Open "U11 IMEI & SIM Unlock" tab in XTC 2 Tools 1.34 or higher
2. Follow built-in instructions.
Should you have any questions - please post it here.
https://i.imgur.com/hBNzDoM.jpg
http://forum.gsmhosting.com/vbb/f961.../#post13052562
aliali87 03-31-2018 15:22
Dears,
i flash the recovery but when i do start nothing happen!!
Please help!
Thanks,
deepakgarg 03-31-2018 16:25
Originally Posted by aliali87 (Post 13053203)
Dears,
Please help!
Thanks,
sir always post problem with fastboot info and full details what steps has gone successfully
Pufi164 04-05-2018 22:52
[OCEAN_UHL_N71_SENSE90GP]
2018.04.05. 23:45:20 Your phone should restart now and the process will continue. Please watch it on your phone!
Phone unlocked.
Work!
Thanks!
timperu 04-12-2018 04:04
Hi have iqual problem different IMEI os with bootloader IMEI please help me
deepakgarg 04-12-2018 04:15
You need to perform step 2 from instructions
Morfy 04-20-2018 05:15
http://forum.gsmhosting.com/vbb/f961.../#post13089466
thoiapple923 04-21-2018 03:50
s-off htc u11 support ??
kapaka 05-10-2018 20:17
help xtc team after doing all steps and press start htc u play is dead only vibrat
kapaka 05-10-2018 20:32
sorry gys it's battery problem
malvarez 05-11-2018 01:05
Amigo, recuerda que una vez que flasheas el recovery , debes de prender el teléfono en modo normal, es decir prende tu cel de forma regular, una vez que ya encendió y estés en el sistema normal de uso, ahora si dale al procedimiento que te dice el clip. A mi me pasó lo mismo y solo haciéndolo de esa forma te va a dar el resultado correcto. Saludos y ahí me avisas si te trabas en algo. Saludos
deepakgarg 05-11-2018 07:04
Friend, remember that once you flash the recovery, you must turn on the phone in normal mode, that is, turn on your cel on a regular basis, once it has already turned on and you are in the normal system of use, now if you give the procedure that you says the clip. The same thing happened to me and just doing it that way is going to give you the right result. Greetings and there you tell me if you get stuck in something. regards
translated via google
please post only in english language
BesTCooL 06-29-2018 15:28
flashing recovery bbuyt exe waiting freeze ı tried via cmd command same prroblem waiting waiting waiting...
g_gsm 07-05-2018 14:31
*********HTC U11 IMEI repair Note done ******
Reading information...
Using Fastboot mode...
Reading common information
(bootloader) kernel: lk
(bootloader) product: htc_ocndugl
(bootloader) version: 1.0
(bootloader) max-download-size: 2399200000
(bootloader) serialno: FA75S1800xxx
(bootloader) slot-count: 0
(bootloader) current-slot:
(bootloader) imei: 3561330804xxxxx
(bootloader) version-main: 2.33.401.10
(bootloader) boot-mode: download
(bootloader) version-baseband: 8998-002772-1711161638
(bootloader) version-bootloader: 1.0.0.0000
(bootloader) mid: 2PZC30000
(bootloader) cid: HTC__J15
all:
Execution time is 5(ms)
Reading CID information
... (bootloader) cid: HTC__J15
OKAY
Execution time is 10(ms)
Reading MEID information
... (bootloader) meid:
OKAY
Reading IMEI1 information
... (bootloader) imei: 3561330804xxxxx
OKAY
Execution time is 7(ms)
Reading IMEI2 information
... (bootloader) imei2: 356133080xxxxx
OKAY
Execution time is 6(ms)
Reading secure flag information
... (bootloader) Device security level S-ON, reboot count 0
OKAY
Execution time is 45(ms)
Reading serial number information
... (bootloader) Device Serial No. is FA75S180xxxx
OKAY
Read information completed.
1. Checking phone connectivity...
Phone connection confirmed!
HTC KEY CARD VERSION: 7
2. Checking Server connectivity...
Server connection confirmed!
3. Checking PowerAdapter connectivity...
Process started
PowerAdapter connected, processing request to adapter...
Starting operation...
Sending oem reboot-download
... OKAY
Execution time is 1(ms)
Waiting for the phone to reboot...
Phone DISconnected
Phone connected [FA75S1800038] *** Fastboot mode
Phone connected
Sending oem writeimei 3576756453xxxxx
... (bootloader) [ERR] Command error !!!
OKAY
Execution time is 4(ms)
Operation completed!
Releasing adapter.
Request completed
Page generated in 0.19473 seconds with 6 queries
