U11 problem Reading information... Using Fastboot mode... Reading common information (bootloader) kernel: lk (bootloader) product: htc_ocndugl (bootloader) version: 1.0 (bootloader) max-download-size: 1562400000 (bootloader) serialno: FA7AD1800256 (bootloader) slot-count: 0 (bootloader) current-slot: (bootloader) imei: 35613xxxxxxxxxxx (bootloader) version-main: 1.28.709.33 (bootloader) boot-mode: download (bootloader) version-baseband: 8998-001791-1705231845 (bootloader) version-bootloader: 1.0.0.0000 (bootloader) mid: 2PZC30000 (bootloader) cid: HTC__621 all: Execution time is 20(ms) Reading CID information ... (bootloader) cid: HTC__621 OKAY Execution time is 20(ms) Reading MEID information ... (bootloader) meid: OKAY Execution time is 1(s) Reading IMEI1 information ... (bootloader) imei: 356133084xxxxxx Execution time is 10(ms) Reading IMEI2 information ... (bootloader) imei2: 3561330xxxxxxx OKAY Execution time is 10(ms) Reading secure flag information ... (bootloader) Device security level S-ON OKAY Execution time is 10(ms) Reading serial number information ... (bootloader) Device Serial No. is FA7AD1800256 OKAY Execution time is 10(ms) Read information completed. FIRST cant imei repair be done WITHOUT power adapter? i dont have power power adapter. only had regular xtc2clip secondly im stuck here... Phone connected [FA7AD1800256] *** ADB mode Sending reboot recovery Your phone should restart now and the process will continue. Please watch it on your phone! Phone DISconnected no recovery. nothing i flashed both recoveries posted but its still the same(not boot to revovery even when i try to both manually to recovery,it just stuck on htc logo) Please i need help thanks in advance |
power adapter is must as u can read here flash stock rom to get phone back to normal for now |
1. Checking phone connectivity... Warning! Your phone does not see the XTC 2 Clip, please try to reconnect it, and then reboot to download/fastboot mode. In case of failure again, check your flex cable for damage. Phone connection confirmed! HTC KEY CARD VERSION: 7 2. Checking Server connectivity... Server connection confirmed! 3. Checking PowerAdapter connectivity... Process started PowerAdapter connected, processing request to adapter... Starting operation... Sending oem reboot-download ... OKAY Execution time is 12(ms) Waiting for the phone to reboot... Phone DISconnected Phone connected [FA7AD1800256] *** Fastboot mode Phone connected Sending oem writeimei2 357303432009931 ... (bootloader) [ERR] Command error !!! OKAY Execution time is 13(ms) Operation completed! Releasing adapter. Request completed |
when i insert sd card to the device it detects but when i connect xtc2clip it doesnt detect the sd. but when i remove and connect xtc2clip to sd reader and connect to pc it detect perfectly well. so im sure my flex is perfectly ok. but it doesnt detect on device please help me thanks |
after connecting clip just reboot to download mode again |
