Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > xtc2cliP
Old 07-23-2018, 08:19   #1 (permalink)
duncan99's Avatar
Member: 1322701
Thanks Meter: 122
U11 problem
Reading information...
Using Fastboot mode...
Reading common information
(bootloader) kernel: lk
(bootloader) product: htc_ocndugl
(bootloader) version: 1.0
(bootloader) max-download-size: 1562400000
(bootloader) serialno: FA7AD1800256
(bootloader) slot-count: 0
(bootloader) current-slot:
(bootloader) imei: 35613xxxxxxxxxxx
(bootloader) version-main: 1.28.709.33
(bootloader) boot-mode: download
(bootloader) version-baseband: 8998-001791-1705231845
(bootloader) version-bootloader: 1.0.0.0000
(bootloader) mid: 2PZC30000
(bootloader) cid: HTC__621
all:
Execution time is 20(ms)
Reading CID information
... (bootloader) cid: HTC__621
OKAY
Reading MEID information
... (bootloader) meid:
OKAY
Execution time is 1(s)
Reading IMEI1 information
... (bootloader) imei: 356133084xxxxxx
Execution time is 10(ms)
Reading IMEI2 information
... (bootloader) imei2: 3561330xxxxxxx
OKAY
Reading secure flag information
... (bootloader) Device security level S-ON
OKAY
Reading serial number information
... (bootloader) Device Serial No. is FA7AD1800256
OKAY
Read information completed.
FIRST
cant imei repair be done WITHOUT power adapter?
i dont have power power adapter. only had regular xtc2clip
secondly
im stuck here...
Phone connected [FA7AD1800256] *** ADB mode
Sending reboot recovery
Your phone should restart now and the process will continue. Please watch it on your phone!
Phone DISconnected
no recovery. nothing
i flashed both recoveries posted but its still the same(not boot to revovery even when i try to both manually to recovery,it just stuck on htc logo)
Please i need help
thanks in advance
Old 07-23-2018, 09:08   #2 (permalink)
deepakgarg's Avatar
Member: 220603
Sonork: 100.1624258
Thanks Meter: 1,082
power adapter is must as u can read here
flash stock rom to get phone back to normal for now
Old 08-05-2018, 22:08   #3 (permalink)
duncan99's Avatar
Member: 1322701
Thanks Meter: 122
i have gotten the power adapter but i got this error
1. Checking phone connectivity...
Warning! Your phone does not see the XTC 2 Clip, please try to reconnect it, and then reboot to download/fastboot mode. In case of failure again, check your flex cable for damage.
Phone connection confirmed!
HTC KEY CARD VERSION: 7
2. Checking Server connectivity...
Server connection confirmed!
3. Checking PowerAdapter connectivity...
Process started
PowerAdapter connected, processing request to adapter...
Starting operation...
Sending oem reboot-download
... OKAY
Execution time is 12(ms)
Waiting for the phone to reboot...
Phone DISconnected
Phone connected [FA7AD1800256] *** Fastboot mode
Phone connected
Sending oem writeimei2 357303432009931
... (bootloader) [ERR] Command error !!!
OKAY
Execution time is 13(ms)
Operation completed!
Releasing adapter.
Request completed
Old 08-06-2018, 12:30   #4 (permalink)
deepakgarg's Avatar
Member: 220603
Sonork: 100.1624258
Thanks Meter: 1,082
please check log for this error
Old 08-07-2018, 00:46   #5 (permalink)
duncan99's Avatar
Member: 1322701
Thanks Meter: 122
is there any other way to connect it?
when i insert sd card to the device it detects but when i connect xtc2clip it doesnt detect the sd. but when i remove and connect xtc2clip to sd reader and connect to pc it detect perfectly well. so im sure my flex is perfectly ok. but it doesnt detect on device
please help me thanks
Old 08-07-2018, 08:25   #6 (permalink)
deepakgarg's Avatar
Member: 220603
Sonork: 100.1624258
Thanks Meter: 1,082
after connecting clip just reboot to download mode again
Old 08-07-2018, 11:09   #7 (permalink)
duncan99's Avatar
Member: 1322701
Thanks Meter: 122
yes i did but same problem. SD CARD not mounted
Page generated in 0.33578 seconds with 7 queries
