12-13-2018, 21:27 | #1 (permalink) |
Freak Poster Join Date: Mar 2006 Location: COL
Member: 242451 Status: Offline Thanks Meter: 63 | U11 repair imei I have done "Power Adapter Tools" procedure but no result, first I copy files with new imei information to clip, then I connect xtc2clip sd to phone and I connect power adapter to xtc2clip, phone in fastboot and start: Starting PowerAdapter procedure: Special recovery file is available 1. Checking phone connectivity....... Phone connection confirmed! HTC KEY CARD VERSION: 7 2. Checking Server connectivity... Server connection confirmed! 3. Checking PowerAdapter connectivity... Process started PowerAdapter connected, processing request to adapter... Rebooting to boot-loader: Waiting for the phone... Phone DISconnected Phone connected [FA76F1805163] *** Fastboot mode Executing operation... Starting operation... HERE I cannt see anything on screen phone, Its black just light and phone stays in that condition Releasing adapter. Request completed What is wrong in this procedure? I have changed flex sd and formated it. I have clean conection on power adapter. Can I downgrade to 7? Reading information... Using Fastboot mode... Reading common information (bootloader) kernel: lk (bootloader) product: htc_ocndugl (bootloader) version: 1.0 (bootloader) max-download-size: 2399200000 (bootloader) serialno: FA76F1805163 (bootloader) slot-count: 0 (bootloader) current-slot: (bootloader) imei: 3561xxxxxxxx (bootloader) version-main: 2.42.400.3 (bootloader) boot-mode: download (bootloader) version-baseband: 8998-002772-1712011153 (bootloader) version-bootloader: 1.0.0.0000 (bootloader) mid: 2PZC30000 (bootloader) cid: HTC__060 all: finished. total time: 0.020s htc_fastboot finished Reading CID information ... (bootloader) cid: HTC__060 thanks in advance |
12-14-2018, 20:57 | #2 (permalink) |
No Life Poster Join Date: Jun 2015
Member: 2416253 Status: Offline Thanks Meter: 4,162 | Hello, You can't downgrade if the procedure is not working, as you need to reset firmware version first. You say that phone stays in black-screen, does it hang in this condition? Or does it restart in a while? Can it boot to OS? |
12-14-2018, 21:02 | #3 (permalink) |
Member: 242451 Status: Offline Thanks Meter: 63 | OS condition is ok, phone is working normally, it hang in that condition until I reboot download mode (I waited a little and no response), but phone is connected fastboot mode while is black-screen. Can you tell me what the problem is? I was trying many times and no success |
12-15-2018, 10:33 | #4 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: Chandigarh,India Age: 40
Member: 220603 Status: Offline Thanks Meter: 1,164 | Quote:
The Following User Says Thank You to deepakgarg For This Useful Post: |
12-15-2018, 18:36 | #6 (permalink) | |
Member: 242451 Status: Offline Thanks Meter: 63 | Quote:
thanks, I did it many times and I tested making soff on htc m9. I tried recovery method but same, and repeat process and no success on phone. Is there any evidence about repair imei on htc u11 android 8 using this process? cause I didnt find any post about it, maybe Im doing something bad so I need someone with experience here. I mean what should the phone show during the process on screen? Starting PowerAdapter procedure: Detected model: HTC U11 (Android 8.x) Special recovery file is available 1. Checking phone connectivity....... Phone connection confirmed! HTC KEY CARD VERSION: 7 2. Checking Server connectivity... Server connection confirmed! 3. Checking PowerAdapter connectivity... Process started PowerAdapter connected, processing request to adapter... Rebooting to boot-loader: Phone DISconnected Waiting for the phone... Phone connected [FA76F1805163] *** Fastboot mode Executing operation... Starting operation... Operation completed! Releasing adapter. Request completed | |
12-20-2018, 01:16 | #7 (permalink) |
Member: 242451 Status: Offline Thanks Meter: 63 | I downgraded to 7.0 version and whole process was ok but phone just fixed first imei, second was null. I repeated process and it finished but phone hang logo after reboot. I´m looking on twrp log and it shows devlog partition bad. I used .zip for flash phone but phone still hangs logo. What can I do? |
12-20-2018, 15:16 | #8 (permalink) |
Member: 242451 Status: Offline Thanks Meter: 63 | Phone is on again, but script just fixed imei 1, It detects phone as single sim. I can read new imei 2 in fastboot but unknown in OS. Can you fix that script for fixing dual sim please? thanks in advance |
12-20-2018, 20:49 | #9 (permalink) | |
Member: 2416253 Status: Offline Thanks Meter: 4,162 | Quote:
Are you on 1.37? If yes, please contact me on skype: xtc2clip I will help you. Thanks!!! | |
12-22-2018, 07:44 | #11 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Colombia
Member: 614683 Status: Offline Sonork: 100.1605379 Thanks Meter: 370 | i have same problem my htc U11 Starting PowerAdapter procedure: Special recovery file is available 1. Checking phone connectivity....... Phone connection confirmed! HTC KEY CARD VERSION: 7 2. Checking Server connectivity... Server connection confirmed! 3. Checking PowerAdapter connectivity... Process started PowerAdapter connected, processing request to adapter... Rebooting to boot-loader: Waiting for the phone... Phone DISconnected Phone connected [FA76P0500692] *** Fastboot mode Executing operation... Starting operation... Operation completed! Releasing adapter. Request completed Reading information... Using Fastboot mode... Reading common information (bootloader) kernel: lk (bootloader) product: htc_ocnwhl (bootloader) version: 1.0 (bootloader) max-download-size: 1560800000 (bootloader) serialno: FA76P0500692 (bootloader) slot-count: 0 (bootloader) current-slot: (bootloader) imei: 35818208xxxxx (bootloader) version-main: 2.42.617.7 (bootloader) boot-mode: download (bootloader) version-baseband: 8998-002772-1801181737 (bootloader) version-bootloader: 1.0.0.0000 (bootloader) mid: 2PZC50000 (bootloader) cid: BS_US001 |
12-22-2018, 16:30 | #13 (permalink) | |
To fix it please download this file: https://xtc2.net/downloads/tmp/htc58diag and replace the one you have on the clip. Then repeat the IMEI repair process via PowerAdapter tools tab. | |
The Following 3 Users Say Thank You to xtc2clip For This Useful Post: |
