Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > xtc2cliP
Old 01-09-2020, 15:42   #1 (permalink)
usernome's Avatar
Member: 19723
Thanks Meter: 352
U11 unbrick help [SOLVED]
Reading information...
Using Fastboot mode...
Reading common information
(bootloader) kernel: lk
(bootloader) product: htc_ocndugl
(bootloader) version: 1.0
(bootloader) max-download-size: 1560000000
(bootloader) serialno: FA77R1801933
(bootloader) slot-count: 0
(bootloader) current-slot:
(bootloader) imei: 356133083073139
(bootloader) version-main: 3.22.709.3
(bootloader) boot-mode: download
(bootloader) version-baseband: 8998-200321-1902271647
(bootloader) version-bootloader: 1.0.0.0000
(bootloader) mid: 2PZC30000
(bootloader) cid: HTC__621
all:
finished. total time: 0.005s
htc_fastboot finished
Reading CID information
... (bootloader) cid: HTC__621
OKAY
finished. total time: 0.012s
Reading MEID information
... (bootloader) meid:
OKAY
finished. total time: 0.006s
Reading IMEI1 information
... (bootloader) imei: 35xxxxxxxxxx
OKAY
Reading IMEI2 information
... (bootloader) imei2: 35xxxxxxxxxxxxxx
OKAY
Reading secure flag information
... (bootloader) Device security level S-ON, reboot count 0
OKAY
finished. total time: 0.046s
Reading serial number information
... (bootloader) Device Serial No. is FAxxxxxxxxxxxx
OKAY
Reading color information
... (bootloader) COLOR ID: DEF00
OKAY
Read information completed.
I wanted to get back to stock in order to make an update .
Old 01-10-2020, 11:54   #2 (permalink)
Member: 2416253
Thanks Meter: 4,097
Hello,
Does it boot to download mode?
Old 01-10-2020, 15:55   #3 (permalink)
usernome's Avatar
Member: 19723
Thanks Meter: 352
Yes . Bootloader , recovery , download .
The problem is that I don't have Power Adapter .
Old 01-11-2020, 09:57   #4 (permalink)
deepakgarg's Avatar
Member: 220603
Sonork: 100.1624258
Thanks Meter: 1,146
flash file number 539931
but u will need locked bootloader for that
Old 01-11-2020, 11:46   #5 (permalink)
usernome's Avatar
Member: 19723
Thanks Meter: 352
Starting flash process...
target rom version: 3.22.709.3
found large-zip header, file count: 26
processing file 1/26...
sending 'zip' (366732 KB)...
OKAY [ 13.797s]
writing 'zip'...
(bootloader) HOSD CL#1011554
(bootloader) ERR check AES encrypted magic string failed.
(bootloader) [email protected]
Flash process completed.
Flash not successfull, reboot will not be done
The bootloader is unlocked from very beginning
(bootloader) max-download-size: 1560800000
(bootloader) serialno: FAxxxxxxxx
(bootloader) version-main: 1.00.000.0
(bootloader) boot-mode: RUU
(bootloader) cid: 11111111
all:
finished. total time: 0.016s
... (bootloader) cid: 11111111
OKAY
OKAY
finished. total time: 0.000s
OKAY
OKAY
OKAY
... (bootloader) Device Serial No. is FA77R1801933
OKAY
OKAY
Old 01-12-2020, 14:56   #6 (permalink)
Member: 2416253
Thanks Meter: 4,097
Hello!
It's strange that in your first log version-main is 3.x.x, and now it's 1.x.x
Does this phone power on?
You can try to flash it with the oldest firmware, otherwise I can upload hboot flash file for you, so that you can upgrade your bootloader first and then full flash.
But it will be better to flash it with lower (current version) first, and then take OTA.
Old 01-12-2020, 15:51   #7 (permalink)
usernome's Avatar
Member: 19723
Thanks Meter: 352
I managed to get a Power Adapter and I reset software and changed CID to 11111111 .
Tell me the exact flash file to try , please .
Thanks !
Old 01-12-2020, 16:41   #8 (permalink)
Member: 2416253
Thanks Meter: 4,097
Thanks !
Perfect, supercid is a good idea.
There are 3 Android versions for your phone, 7.1, 8.0 and 9.0
Please download any N71 firmware (you can choose from the desired region/operator), try to flash it, if it's not going to work, flash it with any O80 firmware. Because the file you've tried (539931) is Android 9.0, so you don't have to try this one once again.
Old 01-13-2020, 13:42   #9 (permalink)
usernome's Avatar
Member: 19723
Thanks Meter: 352
I managed to revive it with :
2PZCIMG_OCEAN_DUGL_O80_SENSE90GP_MR_hTC_Asia_TW_2. 42.709.86_Radio_8998-002772-1712011153_release_531433_signed_2_4.zip
Thanks !
Old 01-13-2020, 17:26   #10 (permalink)
Member: 2416253
Thanks Meter: 4,097
Perfect, thank you for reporting.
The Following User Says Thank You to xtc2clip For This Useful Post:
Page generated in 0.30608 seconds with 7 queries
