04-06-2016, 09:57 | #1 (permalink) |
No Life Poster Join Date: Oct 2010 Location: colombo
Member: 1418524 Status: Offline Thanks Meter: 186 | Vivo flash problem sending 'zip'... (391790 KB) OKAY writing 'zip'... (bootloader) zip header checking... (bootloader) shift signature_size for header checking... (bootloader) zip info parsing... (bootloader) checking model ID... Execution time is 71385(ms) FAIL41 model id check fail FAILED (remote: 41 model id check fail) Checking if phone will restart... Execution time is 0(ms) boot-mode: RUU Flash process completed. Flash not successfull, reboot will not be done PG32IMG_VIVO_ICS_35_S_hTC_Asia_HK_4.10.708.2_Radio _20.74.30.0833U_3831.18.00.11_M_release_321800_sig ned |
04-07-2016, 05:55 | #3 (permalink) | |
Member: 1418524 Status: Offline Thanks Meter: 186 | Quote:
Using Fastboot mode... Reading common information (bootloader) version: 0.5 (bootloader) version-bootloader: 2.02.0002 (bootloader) version-baseband: 3831.18.00.11_M (bootloader) version-cpld: None (bootloader) version-microp: None (bootloader) version-main: 4.08.1400.2 (bootloader) serialno: HT15JTD06141 (bootloader) imei: 35----------42 (bootloader) product: vivo (bootloader) platform: HBOOT-7630 (bootloader) modelid: PG3212*** (bootloader) cidnum: 11111111 (bootloader) battery-status: good (bootloader) battery-voltage: 4368mV (bootloader) partition-layout: Generic (bootloader) security: off (bootloader) build-mode: SHIP (bootloader) boot-mode: FASTBOOT (bootloader) commitno-bootloader: d41e50e7 (bootloader) hbootpreupdate: 12 (bootloader) gencheckpt: 0 Execution time is 15(ms) all: Done! Reading secure flag information ... (bootloader) [ERR] Command error !!! Execution time is 0(ms) OKAY Reading CID information ... (bootloader) [ERR] Command error !!! Execution time is 0(ms) OKAY Reading MEID information ... (bootloader) [ERR] Command error !!! Execution time is 0(ms) OKAY Read information completed. | |
04-09-2016, 07:22 | #8 (permalink) |
Member: 1418524 Status: Offline Thanks Meter: 186 | YES I TRY PG32IMG_Vivo_Gingerbread_S_HTC_ISR_2.35.461.3_Radi o_20.2810.30.085AU_3805.08.03.18_M_release_213091_ signed Starting flash process... sending 'zip'... (266374 KB) OKAY writing 'zip'... (bootloader) zip header checking... (bootloader) shift signature_size for header checking... (bootloader) zip info parsing... (bootloader) checking model ID... Execution time is 50403(ms) FAIL41 model id check fail FAILED (remote: 41 model id check fail) Checking if phone will restart... Execution time is 15(ms) boot-mode: RUU Flash process completed. Flash not successfull, reboot will not be done |
04-10-2016, 18:50 | #9 (permalink) | |
No Life Poster Join Date: Jun 2015
Member: 2416253 Status: Offline Thanks Meter: 4,162 | Quote:
I found the files you need and they are currently being uploaded, I will let you know once done. Thanks. | |
