07-12-2017, 16:01 | #34 (permalink) |
Junior Member Join Date: Apr 2016 Location: Mexico
Member: 2557992 Status: Offline Sonork: 100.1673157 Thanks Meter: 11 | HTC A9 S Telcel Mexico S-OFF 12/07/2017 08:58:22 a. m. 1. Checking phone connectivity... 12/07/2017 08:58:24 a. m. Phone connection confirmed! 12/07/2017 08:58:24 a. m. HTC KEY CARD VERSION: 7 12/07/2017 08:58:24 a. m. 2. Checking Server connectivity... 12/07/2017 08:58:27 a. m. Server connection confirmed! 12/07/2017 08:58:27 a. m. 3. Checking PowerAdapter connectivity... 12/07/2017 08:58:28 a. m. Process started 12/07/2017 08:58:28 a. m. PowerAdapter connected, processing request to adapter... 12/07/2017 08:58:31 a. m. Starting operation... 12/07/2017 08:58:31 a. m. Sending oem writesecureflag 0 12/07/2017 08:58:31 a. m. ... (bootloader) HTC KEY CARD VERSION: 7 12/07/2017 08:58:31 a. m. Building connection 12/07/2017 08:58:31 a. m. Initiating communication 12/07/2017 08:58:31 a. m. Building connection 12/07/2017 08:58:31 a. m. Data exchange sequence 12/07/2017 08:58:32 a. m. Data exchange sequence 12/07/2017 08:58:32 a. m. Requesting information from server 12/07/2017 08:58:33 a. m. Requested sent, waiting 3 seconds for reply... 12/07/2017 08:58:37 a. m. Waiting 3 seconds more... 12/07/2017 08:58:41 a. m. Processing... 12/07/2017 08:58:41 a. m. Data exchange completed 12/07/2017 08:58:41 a. m. Data exchange sequence 12/07/2017 08:58:42 a. m. Data exchange sequence 12/07/2017 08:58:42 a. m. Data exchange sequence 12/07/2017 08:58:42 a. m. Data exchange sequence 12/07/2017 08:58:42 a. m. Data exchange sequence 12/07/2017 08:58:42 a. m. Data exchange sequence 12/07/2017 08:58:43 a. m. Initiating communication 12/07/2017 08:58:43 a. m. Building connection 12/07/2017 08:58:43 a. m. Data exchange sequence 12/07/2017 08:58:43 a. m. Data exchange sequence 12/07/2017 08:58:43 a. m. Requesting information from server 12/07/2017 08:58:44 a. m. Requested sent, waiting 3 seconds for reply... 12/07/2017 08:58:48 a. m. Processing... 12/07/2017 08:58:48 a. m. Data exchange completed 12/07/2017 08:58:49 a. m. Data exchange sequence 12/07/2017 08:58:49 a. m. Data exchange sequence 12/07/2017 08:58:49 a. m. Data exchange sequence 12/07/2017 08:58:49 a. m. Data exchange sequence 12/07/2017 08:58:49 a. m. Data exchange sequence 12/07/2017 08:58:50 a. m. Data exchange sequence 12/07/2017 08:58:50 a. m. (bootloader) Write security level S-OFF OKAY |
The Following User Says Thank You to malvarez For This Useful Post: |
07-20-2017, 12:54 | #35 (permalink) | |
Junior Member Join Date: Mar 2016
Member: 2545921 Status: Offline Thanks Meter: 7 | Quote:
This will change status to RELOCKED (currently unable to change back to LOCKED) Please run a RUU first to ensure that your MID and CID are correct (this will wipe DATA) but so will RELOCKing Bootloader (as far as I remember) Enjoy Br | |
07-21-2017, 08:05 | #36 (permalink) |
Junior Member Join Date: Jul 2016
Member: 2592998 Status: Offline Thanks Meter: 6 | Are there any features that work as of yet on the htc U11 ? I see that the product page for xtc2clip power adapter lists the U11 on the list of supported phones and does not list beta U11 only U11 ? If indeed there are no working features for the U11 that really should be noted on that product page as many buyers will see that and purchase and if no features are working for the U11 there will most likely be some upset buyers. I"am hoping there are some features working on it if not at least the sim unlock feature, as on the Sprint U11 they do not even have the option in the software to add an unlock code when putting a non Sprint sim in it, the Sprint U11 will just list its a non Sprint sim and will not work and will not request an unlock code, I guess Sprint is learning nasty practices by watching what Verizon does and trying to lock down some things too. |
The Following User Says Thank You to Roefastford For This Useful Post: |
07-21-2017, 09:56 | #37 (permalink) | |
No Life Poster Join Date: Jun 2015
Member: 2416253 Status: Offline Thanks Meter: 4,162 | Quote:
You can change CID, downgrade, repair IMEI, change serial number, etc. As to Sprint - we haven't tried it yet, Sprint has never asked for unlock code and there are no codes for Sprint, they always use their built-in app for sim unlock. I will pass info about Sprint to our developers, and let's hope they will make solution soon. | |
07-22-2017, 18:28 | #38 (permalink) | |
Junior Member Join Date: Sep 2015 Age: 49
Member: 2464189 Status: Offline Thanks Meter: 4 | Quote:
By the way, the tool has no HTC__034 in the drop-down list, which is used for Eastern European devices for a few years now. | |
07-24-2017, 12:35 | #39 (permalink) |
Junior Member Join Date: May 2013
Member: 1938785 Status: Offline Thanks Meter: 6 | Hi Guys! I have bought 3 Power Adapters recently. Unfortunately I cannot use their capabilities. XTC 2 Tool 1.32 is already installed the driver as well. I am sending a log. 1. Checking phone connectivity... Warning! Your phone does not see the XTC 2 Clip, please try to reconnect it, and then reboot to download/fastboot mode. In case of failure again, check your flex cable for damage. Phone connection confirmed! HTC KEY CARD VERSION: 7 2. Checking Server connectivity... Server connection confirmed! 3. Checking PowerAdapter connectivity... Process started PowerAdapter connected, processing request to adapter... Starting operation... Sending oem writesecureflag 0 ... (bootloader) HTC KEY CARD VERSION: 7 FAILPERMISSION DENY (NOT_FIND_SMART_IO) FAILED (remote: PERMISSION DENY (NOT_FIND_SMART_IO)) Execution time is 15(ms) Warning! Your phone does not see the XTC 2 Clip, please try to reconnect it, and then reboot to download/fastboot mode. In case of failure again, check your flex cable for damage. Operation completed! Releasing adapter. Request completed Could you help me, please! |
07-24-2017, 13:50 | #40 (permalink) | |
Try to do a file system repair and confirm in the XTC2Clip tool that it's detected. Then safely remove the clip from the computer and replace the smart card with the PowerAdapter and use a micro USB cable to attach it to the PC. Connect the phone in download mode to the computer with a suitable USB cable and insert the clip's micro SD flex cable to the phone's SD slot and do your desired operation. | |
07-26-2017, 15:36 | #41 (permalink) | |
Junior Member Join Date: Jul 2017
Member: 2740850 Status: Offline Thanks Meter: 0 | HTC U11 convert to Developer Edition to S-Off? Quote:
With DEV Ruu I get DEV Bootloader right? When i have Dev Bootloader I can S-Off it? Because Dev Bootloader has the S-Off flag in it? Because Dev TEST Phones are S-Off??? Developer/Unlocked OCEAN_WHL (Single SIM) | CID: BS_US001 | MID: 2PZC50000 | |
07-27-2017, 10:37 | #43 (permalink) | |
The production/development flags are stored in OTP memory (fuses), once they are written, they cannot be overwritten back. | |
07-29-2017, 00:25 | #44 (permalink) | |
Member: 2592998 Status: Offline Thanks Meter: 6 | Quote:
The sprint model of U11 is indeed sim locked and its not like previous sim locked Htc phones as previous sim locked Htc phones when you pop in a sim from another carrier the phone would request the unlock code where the sprint U11 will not request an unlock code it will just list that its carrier sim locked and will not accept the other carriers sim card. If it asked for a code one could be bought on ebay for a couple dollars but they removed the option to enter a sim unlock code. My main thing I would like to do is be able to run an RUU for the unlocked U11 and convert my Sprint U11 to an Unlocked version, then be able to repair imei and make the phone 100% working on verizon. To flash firmware other than stock with Htc you always needed to be s-off unlocked and the same for imei repair. So is the imei repair option for the U11 using temporary s-off ? I"am really wondering how easy it might be to brick these phones if using temp s-off. I have never hard bricked a Htc phone knock on wood and hope I never do. | |
07-30-2017, 06:30 | #45 (permalink) | |
Junior Member Join Date: Jul 2015
Member: 2420279 Status: Offline Thanks Meter: 22 | Quote:
http://forum.xda-developers.com/sprint-one-m9/general/nv-unlock-sim-t3314755 | |
The Following User Says Thank You to Zanziman For This Useful Post: |
