07-30-2017, 11:49 | #46 (permalink) | |
Insane Poster Join Date: Sep 2011
Member: 1656411 Status: Offline Sonork: Scott Probert Thanks Meter: 29 | Quote:
As for bricking a phone with temp S off,thats a very valid concern. I personally won't do it. It's difficult to predict how any changes that you make will be relieved when the phone becomes S on again and starts doing all of its checks. Without permanent S off,im pretty inclined to leave things well enough alone Sent from my 2PYB2 using Tapatalk | |
The Following User Says Thank You to scotty85 For This Useful Post: |
08-02-2017, 09:11 | #47 (permalink) |
Junior Member Join Date: May 2016
Member: 2578906 Status: Offline Thanks Meter: 0 | XTC 2 PowerAdapter not found error message 1. Checking phone connectivity... Phone connection confirmed! HTC KEY CARD VERSION: 7 2. Checking Server connectivity... Server connection confirmed! 3. Checking PowerAdapter connectivity... XTC 2 Power adapter not found. Please connect it to USB port Request completed |
08-02-2017, 10:55 | #48 (permalink) | |
No Life Poster Join Date: Jun 2015
Member: 2416253 Status: Offline Thanks Meter: 4,162 | Quote:
PowerAdapter must be connected to the USB port of your PC, and drivers must be installed. If you have problems installing the driver - you can provide us with Teamviewer, and we will assist you. | |
The Following User Says Thank You to xtc2clip For This Useful Post: |
08-05-2017, 08:38 | #49 (permalink) |
Registered User Join Date: Aug 2010 Location: Indonesia
Member: 1382638 Status: Offline Thanks Meter: 5 | HTC 10 Verizon OS 7.0 1. Checking phone connectivity... Phone connection confirmed! HTC KEY CARD VERSION: 7 2. Checking Server connectivity... Server connection confirmed! 3. Checking PowerAdapter connectivity... Process started PowerAdapter connected, processing request to adapter... Starting operation... Sending oem writesecureflag 0 ... (bootloader) HTC KEY CARD VERSION: 7 FAILPERMISSION DENY (VERIFY_FAIL) FAILED (remote: PERMISSION DENY (VERIFY_FAIL)) Execution time is 4(s) Operation completed! Releasing adapter. Request completed |
08-05-2017, 09:36 | #50 (permalink) | |
Member: 1382638 Status: Offline Thanks Meter: 5 | Quote:
The Following User Says Thank You to zlebors For This Useful Post: |
08-07-2017, 00:26 | #51 (permalink) | |
Junior Member Join Date: Jul 2016
Member: 2592998 Status: Offline Thanks Meter: 6 | Quote:
I know about the xda forum post on sim unlock as the one member OMJ that I had talked to on xda got it to work for his, but mine kept having dm mode problems and it would not work. As for imei repair Htc devices have always required s-off unlock for that to be possible, unless things have changed but xda does not allow talk of imei repair on their web site so its hush hush on there. If someone could confirm imei repair does work on the Sprint U11 please speak up but I could not get any feature to work on the sprint U11 using my xtc2clip and power adapter. | |
08-07-2017, 00:34 | #52 (permalink) | |
It has been posted all over that the hardware on all U11'S is the same just as it was on the Htc 10 as Beaups had originally came up with the method to convert an Unlocked 10 to a Verizon 10 or just flash the verizon radio to an Unlocked 10, so its only a matter of running the appropriate Htc RUU to get it to the version of U11 you would like it to be. Yes the sprint version does have CDMA but CDMA could be in every U11 but only enabled with the Sprint firmware having been flashed. | |
08-07-2017, 01:42 | #53 (permalink) | |
Junior Member Join Date: Jul 2015
Member: 2420279 Status: Offline Thanks Meter: 22 | Quote:
For the record: All U11s are NOT the same. The Sprint model is different than the Unlocked model. Same thing was true with the HTC 10. Both the Verizon and Unlocked model have the same MID. However, the MID of the Sprint model is different than those as well. | |
The Following User Says Thank You to Zanziman For This Useful Post: |
08-07-2017, 01:51 | #54 (permalink) |
Member: 1656411 Status: Offline Sonork: Scott Probert Thanks Meter: 29 | I was able to get a sprint LTEvo somewhat working on vzw,but I did it by cloning a cheap dumb phone.and even at that it had limited speeds(3g) Even if you can get some or all functionality with your sprint u11 on vzw, given existence of vzw u11s,i fail to see the point. Especially with an expensive new phone. When I did it,i used a $50 Craigslist phone with a bad esn. Sent from my HTC U Ultra using Tapatalk |
08-21-2017, 04:53 | #55 (permalink) | |
I highly doubt they made more changes other than adding the CDMA and tweaks for sprint as most other htc phones can be converted by flashing the desired versions RUU that is with having s-off unlock. Without s-off unlock not sure if you can do much of anything as htc devices usually required s-off unlock also to do imei repair. | |
08-21-2017, 04:54 | #56 (permalink) | |
08-28-2017, 14:48 | #60 (permalink) |
Member: 2578906 Status: Offline Thanks Meter: 0 | Dear team please help me to slove thsi issues. i have tried to s-off htc desire 10 pro/ htc m10 and need to change super cid. i just follow all your guides. but unable to flash it. if you can please help me...... 1. Checking phone connectivity... Warning! Your phone does not see the XTC 2 Clip, please try to reconnect it, and then reboot to download/fastboot mode. In case of failure again, check your flex cable for damage. Phone connection confirmed! HTC KEY CARD VERSION: 7 2. Checking Server connectivity... Server connection confirmed! 3. Checking PowerAdapter connectivity... Process started PowerAdapter connected, processing request to adapter... Starting operation... Sending oem reboot-download ... OKAY Execution time is 3(ms) Waiting for the phone to reboot... Phone DISconnected Phone connected [FA74JBN02509] *** Fastboot mode Phone connected Sending oem readimei ... (bootloader) imei: 354261075874123 OKAY Execution time is 1(s) Operation completed! Releasing adapter. Request completed 1. Checking phone connectivity... Warning! Your phone does not see the XTC 2 Clip, please try to reconnect it, and then reboot to download/fastboot mode. In case of failure again, check your flex cable for damage. Phone connection confirmed! HTC KEY CARD VERSION: 7 2. Checking Server connectivity... Server connection confirmed! 3. Checking PowerAdapter connectivity... Process started PowerAdapter connected, processing request to adapter... Starting operation... Sending oem reboot-download ... OKAY Execution time is 2(ms) Waiting for the phone to reboot... Phone DISconnected Phone connected [FA74JBN02509] *** Fastboot mode Phone connected Sending oem writesecureflag 0 ... (bootloader) HTC KEY CARD VERSION: 7 FAILPERMISSION DENY (NOT_FIND_SMART_IO) FAILED (remote: PERMISSION DENY (NOT_FIND_SMART_IO)) Execution time is 156(ms) Warning! Your phone does not see the XTC 2 Clip, please try to reconnect it, and then reboot to download/fastboot mode. In case of failure again, check your flex cable for damage. Operation completed! Releasing adapter. Request completed i successfully s-off htc 530 with power adapter. its working. please help me to s-off using power adapter for htc desire 10 pro and htc m10 thank |
