08-29-2017, 15:06 | #61 (permalink) | |
No Life Poster Join Date: Jun 2015
Member: 2416253 Status: Offline Thanks Meter: 4,162 | Quote:
I can only suggest to check how you connect the flex to the phone, and that the flex isn't damaged. According to your logs it's a connection problem between the phone and the clip. | |
08-30-2017, 02:16 | #62 (permalink) | |
Junior Member Join Date: Jul 2016
Member: 2592998 Status: Offline Thanks Meter: 6 | Quote:
So unlike your saying they are NOT alike, apparently they ARE enough to convert to USA unlocked version. Check out Xda U11 forum the posts are all there so apparently they CAN be converted. | |
08-30-2017, 03:15 | #63 (permalink) | |
Junior Member Join Date: Aug 2017
Member: 2750615 Status: Offline Thanks Meter: 4 | Quote:
I successfully M9 its working HTC 10 and U11 is not working In my case, the connection between the flex and the phone was not a problem The file system repair method previously written on the bulletin board did not get better I was able to use it in U11 in this procedure 1) Connect flex to PC and backup SMART_IO CRD to PC 2) Format the flex with Windows (10) (FAT , Standard allocation) 3) Copy the backed up SMART_IO CRD to the clip 4) In Windows explorer, open the property and check the error in the tool tab This procedure is not always suitable for everyone If you can use it without problems with other phones, you should doubt the clip body (filesystem) | |
The Following User Says Thank You to wpandroidios For This Useful Post: |
08-30-2017, 10:21 | #64 (permalink) |
Member: 2752699 Status: Offline Thanks Meter: 5 | can not S-off , please help me 1. Checking phone connectivity... Phone connection confirmed! HTC KEY CARD VERSION: 7 2. Checking Server connectivity... Server connection confirmed! 3. Checking PowerAdapter connectivity... Process started PowerAdapter connected, processing request to adapter... Starting operation... Sending oem writesecureflag 0 ... (bootloader) HTC KEY CARD VERSION: 7 FAILPERMISSION DENY (GT_CONNECT_FAIL) FAILED (remote: PERMISSION DENY (GT_CONNECT_FAIL)) Execution time is 1(s) Operation completed! Releasing adapter. Request completed I tried many time..... |
The Following User Says Thank You to skybon_hp For This Useful Post: |
08-30-2017, 12:06 | #65 (permalink) | |
Please make sure PowerAdapter is inserted into the XTC 2 Clip. Try to remove it and insert again. This error (GT_CONNECT_FAIL) means there is no connection between clip and the PowerAdapter. | |
The Following User Says Thank You to xtc2clip For This Useful Post: |
08-31-2017, 01:55 | #66 (permalink) | |
Junior Member Join Date: Jul 2015
Member: 2420279 Status: Offline Thanks Meter: 22 | Quote:
08-31-2017, 05:37 | #67 (permalink) | |
Member: 2752699 Status: Offline Thanks Meter: 5 | Quote:
After check power adapter and my XTC 2 Clip I saw a problem. Point contact of adapter and XTC unlapped when i insert adapter to the XTC slot. | |
09-01-2017, 09:40 | #69 (permalink) | |
Junior Member Join Date: May 2016
Member: 2578906 Status: Offline Thanks Meter: 0 | Quote:
i have change the new flex and checked it but same error message i got it. but desire 530 s-off was successful. please if anyone can help me to fix this issue. i desperately need to flash the phone. thanks | |
09-01-2017, 13:57 | #70 (permalink) |
Member: 2578906 Status: Offline Thanks Meter: 0 | dear team, i have connect the device and click trusted reboot option first 1. Checking phone connectivity... Phone connection confirmed! HTC KEY CARD VERSION: 7 2. Checking Server connectivity... Server connection confirmed! 3. Checking PowerAdapter connectivity... Process started PowerAdapter connected, processing request to adapter... Starting operation... Sending oem reboot-download ... OKAY Execution time is 2(ms) Waiting for the phone to reboot... Phone DISconnected Phone connected [LC75K1001187] *** Fastboot mode Building connection Initiating communication Building connection Data exchange sequence. Phone connected Requesting information from server Requested sent, waiting 3 seconds for reply... Processing... Data exchange completed Data exchange sequence..... Initiating communication Building connection Data exchange sequence. Requesting information from server Requested sent, waiting 3 seconds for reply... Processing... Data exchange completed Data exchange sequence Sending oem readimei ... (bootloader) imei: 353491081450581 OKAY Execution time is 4(s) Operation completed! Initiating communication Releasing adapter. Request completed then i tried to s-off i clicked write security i got this message 1. Checking phone connectivity... Warning! Your phone does not see the XTC 2 Clip, please try to reconnect it, and then reboot to download/fastboot mode. In case of failure again, check your flex cable for damage. Phone connection confirmed! HTC KEY CARD VERSION: 7 2. Checking Server connectivity... Server connection confirmed! 3. Checking PowerAdapter connectivity... Process started PowerAdapter connected, processing request to adapter... Starting operation... Sending oem writesecureflag 0 ... (bootloader) HTC KEY CARD VERSION: 7 FAILPERMISSION DENY (NOT_FIND_SMART_IO) FAILED (remote: PERMISSION DENY (NOT_FIND_SMART_IO)) Execution time is 5(ms) Warning! Your phone does not see the XTC 2 Clip, please try to reconnect it, and then reboot to download/fastboot mode. In case of failure again, check your flex cable for damage. Operation completed! Releasing adapter. Request completed i have not remove the clip from device . but its saying check your flex cable for damage. flex cable is working please help me some one |
09-01-2017, 21:36 | #73 (permalink) |
Freak Poster Join Date: Jul 2003 Location: Lithuania Age: 51
Member: 34549 Status: Offline Thanks Meter: 41 | Desire D650h s-off not successfull: 1. Checking phone connectivity... Phone connection confirmed! Requested card version not detected, version 6 will be used 2. Checking Server connectivity... Server connection confirmed! 3. Checking PowerAdapter connectivity... Process started PowerAdapter connected, processing request to adapter... Starting operation... Sending oem writesecureflag 0 ... (bootloader) SecuritySDInit: counter = 4 (bootloader) a17uhl_init_sd, SD card already power on (bootloader) a17uhl_init_sd, SD card io already power on (bootloader) sdhci_open: id=0 (bootloader) Initializing MMC host data structure and clock! (bootloader) mmc slot#2 clock enabled (bootloader) sdhci_set_clock: slot 2, freq 192000000 (bootloader) GPLL0 is enabled (bootloader) clock_update_cfg_sd is done (bootloader) sd clock set done (bootloader) sdhci_set_bus_width: bus width 0 (bootloader) sdhci_clk_supply: freq 400000 Building connection Data exchange sequence (bootloader) Error: Command never completed (bootloader) Error: Command timeout error (bootloader) Error: Command completed with errors (bootloader) The response for CMD8 does not match the supplied value (bootloader) Decoded CID fields: (bootloader) Manufacturer ID: 7f (bootloader) OEM ID: 0x0 (bootloader) Product Name: 5270 (bootloader) Product revision: 5.2 (bootloader) Product serial number: B4E (bootloader) Manufacturing date: 2 2015 (bootloader) sdhci_clk_supply: freq 50000000 (bootloader) sdhci_set_bus_width: bus width 1 (bootloader) Done initialization of the card (bootloader) erase_grpsize: 2 (bootloader) erase_grpmult: 96 (bootloader) wp_grpsize: 1 (bootloader) wp_grpen: 1 (bootloader) perm_wp: 0 (bootloader) temp_wp: 0 (bootloader) [Tuxera][Error] No exFAT partition found Data exchange sequence Requesting information from server Requested sent, waiting 3 seconds for reply... Waiting 3 seconds more... Processing... Data exchange completed Data exchange sequence. (bootloader) writesecureflag: Permission denied, value 4 OKAY Execution time is 11(s) Operation completed! Releasing adapter. Request completed |
09-04-2017, 08:00 | #74 (permalink) | |
who can fix this issue. is there any issue in s-off on htc desire 10 pro ?. if not please help me to fix it. is there any other way to s-off methods available please ? | |
