XTC 2 PowerAdapter - How to use (manual) Dear customers, For complete XTC 2 Power Adapter please visit this thread: http://forum.gsmhosting.com/vbb/f961...017-a-2233953/ Here is a short manual on how to use the new PowerAdapter, and in the meantime we will prepare videos and photos for this guide. What do we need? * XTC 2 Tool version 1.31 and higher from here: http://forum.gsmhosting.com/vbb/f961...pport-2238267/ * Drivers for PowerAdapter from here: http://xtc2.net/downloads/driver_poweradapter.zip How to use: 1. Connect XTC 2 PowerAdapter to PC using microUSB cable and install drivers, if not yet installed. 2. Remove smartcard from XTC 2 Clip and insert PowerAdapter instead. Shoul you feel that connection is not tight enough, you may use included stickers to secure the connection. 3. Run XTC 2 Tool and open "PowerAdapter" tab. 4. Connect phone in download mode to PC, and connect XTC 2 Clip to phone's SD slot as for normal S-OFF operation. 5. Process with desired command. Quote:
downloading and trying the new tools. |
htc_ocedugl s-off not work |
What you select from log I see that you do S-ON procedure not S-OFF or maybe software got bad parametr under button. Quote:
That's strange, it did this operation Quote:
1. Checking phone connectivity... Phone connection confirmed! HTC KEY CARD VERSION: 7 2. Checking Server connectivity... Server connection confirmed! 3. Checking PowerAdapter connectivity... Process started PowerAdapter connected, processing request to adapter... Starting operation... Sending oem writesecureflag 0 ... (bootloader) HTC KEY CARD VERSION: 7 Building connection Initiating communication Building connection Data exchange sequence. Requesting information from server Requested sent, waiting 3 seconds for reply... Processing... Data exchange completed Data exchange sequence..... (bootloader) Write security level S-ON OKAY Execution time is 9(s) Operation completed! Releasing adapter. Request completed write security s-on 1. Checking phone connectivity... Phone connection confirmed! HTC KEY CARD VERSION: 7 2. Checking Server connectivity... Server connection confirmed! 3. Checking PowerAdapter connectivity... Process started PowerAdapter connected, processing request to adapter... Starting operation... Sending oem writesecureflag 3 ... (bootloader) HTC KEY CARD VERSION: 7 (bootloader) VERIFY_PASS (0) (bootloader) Partition verify pass Building connection Initiating communication Building connection Data exchange sequence. Requesting information from server Requested sent, waiting 3 seconds for reply... Waiting 3 seconds more... Processing... Data exchange completed Data exchange sequence..... (bootloader) Write security level S-ON OKAY Execution time is 14(s) Operation completed! Releasing adapter. Request completed |
Hello, As we wrote before, there is a stock of phones that does not support permanent S-OFF, you can repair IMEI, change CID, reflash phone, etc, or/and unlock bootloader - unlocked bootloader gives almost same option as S-OFF. There is currently no known option to perform permanent S-OFF, as HTC did not implement this feature. |
我從使用 Tapatalk 的 HTC_M9u 發送 |
xtc 2 clip end update oe not without power adapter |
P.S. Are there any locked U Ultra/Play and U11? Please let me know if you have one. P.P.S. As I already said before, support area will be updated shortly after the official launch of PowerAdapter, which happened today :) |
So what do you want permanent s-off?. While s-off do, your downgrade, sim unlock, etc. Then there is no need to worry, the downgrade or sim unlock will already be done. Enviado desde mi HTC One_M8 mediante Tapatalk |
Maybe japanese model of U11 have simlock, not sure about that. 我從使用 Tapatalk 的 HTC_M9u 發送 |
1. Checking phone connectivity... Phone connection confirmed! HTC KEY CARD VERSION: 7 2. Checking Server connectivity... Server connection confirmed! 3. Checking PowerAdapter connectivity... Process started PowerAdapter connected, processing request to adapter... Starting operation... Sending oem readimei ... (bootloader) imei: 355167080362310 OKAY Execution time is 6(ms) Operation completed! Releasing adapter. Request completed |
